Question about KitchenAid KUIS18NNT 18" Automatic Ice Maker with 35lbs. Storage Capacity, Drop Down Door & Accepts Custom Panels
Under counter ice maker water pickup problem
My under counter ice maker continues to try and circulate water, after the tank is empty. the machien makes noice, as it cannot pick up any water. After a while the cycle starts, and the tank is filled. Is it not getting enough water, or is the cycle out of adjustment
  • Ice ice babe Feb 16, 2009
    "My under counter ice maker continues to try and circulate water, after the tank is empty. The machine makes noice, as it cannot pick up any water. After a while the cycle starts, and the tank is filled.  Is it not getting enough water, or is the cycle out of adjustment?"
    I have the same problem with my icemaker.
  • wsbmlb Mar 15, 2009
    I have the same problem with the cutting grid type ice machine.
    Bill
    Thank you
    Guru:
  • 462 Answers
Most likely your plastic curtain is not keeping the water in the sump area. ( I'm assuming it makes round cubes)? Look under the sump for any dripping if its a pretty steady drip replace your water curtain and the holder that's with it.
If you have a cutting grid type ice machine this is all together different and I need to tell you separately about that.
Posted on Mar 12, 2009
How do I empty the water from the main reservoir?
  • Turn off the Keurig coffee maker, and unplug the power cord. Allow the unit to cool for 30 minutes before emptying the water. This gives the water inside the hot water tank an opportunity to cool, helping to prevent accidental scalding when emptying.
  • Pull the lid off the top of the water reservoir. Lift the water reservoir straight up and to the right of the coffee maker. Pour out any remaining water in the reservoir into the sink.
  • Turn the small thumb screw on the back of the Keurig coffee maker counterclockwise with your fingers, and pull off the rear access panel. If the screw is too tight to turn with your fingers, use a flat-head screwdriver to turn the screw. Once you remove the access panel, a tube with a plug on the end is visible. Pull the tube out of the plastic clip holder.
  • Place a large pitcher behind the coffee maker. Hold the end of the tube over the pitcher, and pull the plug out of the tube. Allow the water to drain into the pitcher. If necessary, maneuver the coffee maker to the edge of the counter, and hold the pitcher alongside the counter with the top at counter level.
  • Push the plug back into the end of the tube once no more water drains from the hot water tank. Empty the pitcher of water into the sink, and push the tube back into the plastic clip holder. Position the back access panel onto the coffee maker and secure with the thumb screw knob.
  • How to Empty the Water Reservoir on Keurig Coffee Maker eHow
    Apr 08, 2015 | Keurig B60 Coffee Maker
    Tip
    Ice maker stopped working
    When the ice bin fills up, it won't let the arm all the way down. The arm must go down for more ice to drop into bin. Sometimes an ice cube or two will get caught under the arm and prevent it from cycling. Continuing to use the ice maker will empty bin but no new ice is made. Clear any ice cubes from under the arm and the cycle will start again. My ice maker takes about twelve hours to fill after it has been emptied but ice from the door is available almost imediately.
    on Aug 23, 2010 | Refrigerators
    I have a whirlpool model ED25PWXBN00 refrig and the ice maker is making ice but the part that holds and dispenses the ice has broken and no longer dispenses ice. what part do i need?
    That depends if the ice maker continues to fill with water or just sits there with the ice slots empty. Sometimes it is the dual water control valve=> 4318046 Water Control Valve
    and sometimes the ice maker itself. Does not hurt to have an extra part of each if you are a ice user like myself. If ice slots are empty fill with tap water and allow to freeze. If the ice drops and slots do not refill with water then replace the dual water control valve. 4317943 Ice Maker Assembly.
    Oct 02, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
    Auto Ice maker in Whirlpool fridge, not producing ice. I suspect the water feed line might be frozen since it was working fine two days ago. I haven't heard the water fill and the tray is empty.
    Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
    The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
    Oct 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
    I have the exact same problem, curious if you have any answer...
    If the ice melts in the ice maker I think something strange is going on with the heating element below the ice maker. It comes on only for a few seconds before the ice drops. And is used to loosen the ice. But if water continues to flow from the water control valve while the ice maker is full it has no where to go but into the freezer and refreeze. Sometimes the water control valves have trash buildup inside the valve and will not shut and allows the water to continue to flow. About the only way to solve that is replace the water control valve and place a pre-filter in the line before the water reaches the valve. Thanks, Sea Breeze
    Aug 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
    Water leaking from the tank & down the outside of the Magic DeLux
    I have a Saeco Magic Deluxe that does/did the same. The water tank, when filled would empty down the side of the machine and all over the counter top.
    I recognized that the lid on the water tank, when pressed firmly in place, created a back-pressure because air was not able to get into it and level out the pressure. I've resolved this problem by leaving the lid slightly ajar allowing air to circulate into the water tank itself. I've also thought about drilling a tiny hole into the lid itself but have not done that yet for I don't want to comprimise the plastic.
    Peter (Detroit, MI)
    Feb 21, 2009 | Saeco Magic De Luxe Espresso Machine
    Sub-Zero Under Counter Ice Maker not making Ice
    ice stat defective
    hot gas solenoid vavle defective
    pls post make /model.
    if ignis / whirlpool then above points should the trick.
    lastly reclaim gas replace both driers recharge with fresh gas to spec( liquid by weight).
    Feb 20, 2008 | Freezers
    KitchenAid KUIS18NNT 18" Automatic Ice Maker with 35lbs. Storage Capacity, Drop Down Door & Accepts Custom Panels Logo
    701 people viewed this question
    Top KitchenAid Refrigerators Experts
    John Tripp
    John Tripp
    vince
    mike cooper
    Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
