Need fuse box layout on ford bantam 2004
On this website (link below) you find fuse box diagram and description for Ford Bantam
Ford Bantam 2002 fuse box diagram Auto Genius
SOURCE: FUSE PANEL LAYOUT
Download and go to page 153.
http://www.motorcraftservice.com/pubs/content/~WO3RAN/~MUS~LEN/40/03Ranog3e.pdf
SOURCE: Fuse box layout for a 2002 VW Cabrio
Fuse colors
30 A-green25 A-white20 A-yellow15 A-blue10 A-red7,5 A-brown5 A-beige3 A-violetFuse locations
Fuse Location
Fuse locations for options not shown can be found in the corresponding wiring diagrams.
Amp.
1-Headlight, Low Beam, Left (56b)102-Headlight, Low Beam, Right (56b)103-License Plate Lights (58) 104-Rear Window Wiper And Washer System155-Windshield Wiper/Washer156-Fresh Air Blower, A/C (X)207-Tail Lights, Right (58R)108-Tail Lights, Left (58L)109-Rear Window Defogger2010-Fog Lights1511-Headlight, High Beam, Left (56a)1012-Headlight, High Beam, Right (56a)1013-Horn (15)1014-Back-Up Lights1015-Engine Electronics (15)1016-Power Sunroof, Front Map/Reading Light1517-Emergency Flashers (15)1018-Fuel Pump (FP), Heated Oxygen Sensor (HO2S) Control Module2019-Coolant Fan, A/C Relay (30)3020-Brake Lights (30)1021-Interior Lights, Clock, Luggage Compartment Light (30)1522-Cigarette Lighter, Radio, Luggage Compartment Release10Separate Fuses
(Located above the relays)
-Fuse for ABS hydraulic pump relay30-Fuse for ABS main relay30-Fuse for A/C30-Fuse for power windows20-Fuse for cruise control5-Fuse for cigarette lighter15In the engine compartment above the brake booster:
-Glow plugs50
SOURCE: vw polo fuse box layout 2004
you might find the fuse diagram on the inside of the fuse box cover under the hood.....hope this helps.....cheers
