Question about GE 25865 Cordless Phone
I only seem to get Caller I.D.records for calls to line 1
I cannot get C.I.D records for line  2 when I go to menu/caller I.D.
  • 57 Answers
Go into the menu option under set up and go step by step and it will bring you to caller id option. There , you should be able to turn on the caller id for both lines. I just went through this with my parents phones. after you do it you wont believe how easy it was.
Posted on Jan 04, 2009
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
Tip
How do I Block a Caller on my Android Phone
<p>Here we discuss how an Android phone callers to block. These steps can be useful where you want unwanted calls directly instead of manually reject the call blocking. Follow these simple steps to block a caller making a call to the phone. Please note that the various steps may be other manufacturers like Samsung and Sony Ericsson and HTC. But the base should be almost identical. <br /> <p><br /> <p>Option 1 Steps <br /> <p>1. On the All Apps menu, click Blocked callers<br /> <p><br /> <p><span> </span>2. Click Add caller.<br /> <p><br /> <p><span> </span>3. Select from people (which are your on phone book) or just add the caller (if you remember the number).<br /> <p><br /> <p><span> </span>4. If you like people, click Save to finish.<br /> <p><br /> <p>5. If you add the caller number, click ok to finish.<br /> <p><br /> <p>Option 2 Steps <br /> <p><span> </span>1. All applications menu, click Find People. <br /> <p><br /> <p><span> </span>2. Select the caller wishes to block. <br /> <p><br /> <p><span> </span>3. Calling on the Block, "switching to. <br /> <p><br /> <p><span> </span>4. Click OK to close the. <br /> <p><br /> <p>This "Blocked Caller" function can be disabled, as shown <br /> <p><span> </span>1. All applications menu, click people blocked. <br /> <p><br /> <p><span> </span>2. Select the caller that you want to release. <br /> <p><br /> <p><span> </span>3. About Block caller, change On Off. <br /> <p><br /> <p><span> </span>4. Click OK to close. <br />
on Aug 18, 2011 | Google Android
How to get caller id for missed calls for Panasonic kx-t7730
Panasonic KX-TA624/824 automatic Caller ID logging How to set up automatic Caller ID logging
in the KX-TA624 phone system with KX-T7735 phones. (for dash four and five, and KX-TA824)
System Programming:
  1. In System Program number 900, enable Caller ID for the lines you have Caller ID on. (To get into system programming, press Program * # 1234.)
  2. In System Program number 901, select your own area code and any other area codes that don't have to be dialed when making a call. The area code digits are removed from Caller ID log information so you can return a call without dialing unnecessary digits which would mess up the call.
  3. In System Program number 902, if necessary, indicate the number of digits to be removed, and a particular digit (usually 1) that might have to be added, when returning a local phone call. The default programming is to remove the first three digits, and add nothing; which is correct for most locations.
  4. In System Program 903, if necessary, indicate the number of digits to be removed, and up to 4 digits that might have to be added, when returning a long distance phone call. The default programming is to not remove any digits, and add a 1; which is correct for most locations.
  5. In System Program number 909, enable Call Log Assignment for each phone where you want to log Caller ID information. You can use * to indicate you want logging at all phones.
  6. Get out of system programming. (Press Hold or End, then Program.)
Phone Programming:
  1. Program a button for Caller ID Indication on each phone where you want to log Caller ID information. Press Program, then the button you want to use for Caller ID Indication (we recommend the top button in the left column), then 96, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 6 instead of 96.)
  2. At each phone where you want to log all calls, press intercom, then 7382#.
User Tips:
  • The Caller ID Indication button will light up only when the system has logged UN-answered calls.
  • Use the Navigator Key at the lower right corner of the phone to scroll through Caller ID information.
  • You can erase the entire Caller ID log by pressing Intercom, then 70**#
  • You can erase an individual Caller ID record by pressing Transfer while the information is displayed.
  • If your phone does not have a Navigator Key, you can program an available button for Caller ID Selection. Press Program, then the button you want to use for Caller ID Selection, then 97, then Store, then Hold, then Program. (If you want a phone to record Caller ID information individually, rather than for the whole system, use 7 instead of 97.)
  • To call a number displayed on the Caller ID log, pick up the handset or press the speakerphone button, and press the Caller ID Indication button.
Jul 01, 2015 | Panasonic KX-T7730 Corded Phone
No caller ID. TP company says I have service.
  • Did you fully charge your phone? - Make sure you fully charge for 16-24 hours .
  • Is the battery old? - Replace the battery.
  • Is the electrical outlet switch turned on? - If you are using AC (electrical) power, make sure that the unit is connected to a non-switched electrical outlet.
  • Are the connecting wires tight - Unplug the AC power converter from the unit and plug it back in.
  • Do you have Caller ID service with your telephone company - In order to receive Caller ID records, you must subscribe to the standard name and number Caller ID service available through your local telephone company. If the Caller ID works for normal calls but not on Call waiting calls, then you must contact your phone company to get the combined CID/CW service.
  • Caller ID shows up after second ring - Be sure to wait until the second ring before answering. Caller ID signals comes through after the first ring, if caller pick ups phone too soon Caller ID signal will not be transmitted to the handset.
  • Confirm that caller ID is still working on that particular line by checking another phone on the same line - If Caller ID is not coming through contact your phone company provider.
If this does not fix your problem, contact your authorized Service Center.*
Oct 16, 2010 | Uniden DECT 6.0 Cordless Phone ID
NO MANUAL HOW DELETE CALLERS IN LOG ?
You can download the owners manual in PDF format from this link.
412CID 4 Line Telephone
To answer you question - From the owners manual:
Erasing Caller ID Records
In order to delete a specific Caller ID record in the log:
1. Using the [<] or [>] key, find the particular record you would like to delete..
2. Press the [ERASE] key. The LCD display will indicate that the record has been deleted.
3. You may erase all caller information records simultaneously by pressing [ERASE] from the summary
Call ID display.
Hope this Helps.
Sep 25, 2009 | Bell BE-412CID Corded Phone
On screen caller id failure
common problem on 625 receiver. Have you hit menu 6-1-2 to enable caller id? If so call Dish and have them send you a new receiver out and give it a try. I'm sure it won't work every time, but it has to be better than what you have.
Apr 25, 2009 | DISH Network DVR-625 DTV Receiver /...
Lines 2,3 & 4...caller ID working fine. Line 1 says ''No DATA'' when I get calls... how can I fix it ?
Call your phone company as see if they have caller ID on that line. If it works on all of the other lines then the phones seem to be wroking properly so I'd go to the phone company.
Mar 24, 2009 | RCA 25414RE3 Corded Phone
No caller id
Is caller ID enabled on your line, usually this is an extra provided by the phone company, software won't function without it usually.
Apr 23, 2017 | Jaton WinCOMM V.92 Modem
INCOMING CALLS
Not sure it this is a solution for ALL your problems, but...
I had a similar issue: Phone rings, caller ID info displays then seems to hesitate, then displays only "INCOMING CALL."
The issue seemed to be caused by interference with other devices on the same line (in my case, an alarm system).
Tech support had me change a setting on my TRU9466 base unit (this is one of the PowerMax 5.8ghz models). This is how we did it step-by-step on the base unit:
MENU
GLOBAL SETUP
IN-USE LINE SETUP
select LINE 1
switch to TYPE B
This seems to have solved the Caller ID "interference" issue -- my Caller ID now displays as it should. The Tech Support person suggested trying that TYPE A/TYPE B setting on "OFF" if TYPE B didn't solve the problem, but thankfully, it did.
Now Cheryl, it sounds like your issue is more involved than this -- I didn't have any connection problems -- but perhaps they're related -- you might try my solution.
Mar 07, 2008 | Uniden 5.8GHz Cordless Phone
Tg5632
Check your settings in your answering machine menu. 1) is it on? 2) number of rings? 3) is it set to take messages or answer only? If the machine is ringing and never answers look for a problem under items 1 and 2. If it answers, plays your greeting then hangs up on the caller, look at number 3. If all those settings are correct, power it down, repower it back up, wait a few minutes to call it.
Jan 29, 2008 | Panasonic KX-TG5632 Phone
GE 25865 Cordless Phone Logo
80 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
