Question about SanDisk Sansa e200 MP3 Player
I got my sansa a week ago, today i turn it on and go to video to play it but it just went all black
I also plug it into my computer and it doesnt even read the player!!!WAT DO I DOOOOO????????????????
  • 4 more comments
  • abi manivannan May 09, 2007
    thanks
    should i not even get a sansa next if its causing so many problems then?
    thanks
    im not sure if i want to buy a sansa again if it is causing so many problems
  • thebeard Dec 14, 2007
    computer does not recognise device
  • Anonymous Dec 24, 2007
    my computer is not reading that my sansa e260 what should i do?
  • okwatanzinwa Dec 25, 2007
    unrecognized device it says
    unrecognized device
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
Samsung syncmaster 245b lights up and then turns black...
more than likely your video card has gone bad .. try to get a new video card and install it or take computer to your computer shop and have them replace it for you
May 17, 2017 | Samsung SyncMaster 245BW Monitor
This is my final cry: My mp3 sansa wont turn on, i made the mistake of dropping it a week ago and it wont turn on. Ive tried the reset the method(15-30secs) but it doesnt work...... at all. it wont turn...
You could try the Updater program and see if you can un-brick the chip. Go to the SanDisk site and download the Updater program, follow all instructions. That is the only thing that might work, as it may have broken an internal circuit.
Apr 04, 2010 | SanDisk Sansa Fuze MP3 Player
Borrowed a flip video to tape daughters
camcorders don't generally charge from pc's as the voltage is much higher.they won't switch on when the battery is low or i should below a certain voltage..try charging it using its charger it will probably be fine .good luck farr64[colin]
Dec 29, 2009 | Pure Digital Flip Video Ultra Camcorder
My Sansa e280 won't turn on
Hold down the menu bottom for about 20-30 secs. Should power back on.
Mar 17, 2009 | SanDisk Sansa E280 MP3 Player
SANSA EXPRESS
Not sure but it could be dead, but dont worry till you do a hard reset by pressing and holding down the "select(Square button)"and "volume up" buttons.
I just got mine today and been looking through the sandisk forum.
Hope that helps bye :)
Jun 15, 2008 | SanDisk Sansa MP3 Player
It doesn't turn on!!
I'm having the same kind of problem. Its really wierd and i'm really worried about it bcoz its my first mp3 player.
Apr 15, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Mp3 player wont play songs or anything
Only 2 suggestions here: 1) Make sure your HOLD switch is not enabled. 2) Try to update the firmware If neither of these work, time to send the unit back to Sandisk
Aug 09, 2007 | SanDisk Sansa e250 MP3 Player
Backlight wont work?
Check the backlight settings in the menu - yes, cracked screen would definitely cause such a problem
May 30, 2007 | SanDisk Sansa e260 MP3 Player
My RCA Lyra RD1072A just doesnt play songs
it freezes at the start menu just saying RCA and others times it plays a song and freezes when i turn the volume up or down can someone anyone help me please...thanx
May 16, 2007 | RCA Lyra RD1072 MP3 Player
Freezing
These units are noted for this problem. They cannot be fixed. I bought to for Christmas presents and after 2 days one was stuck on the "Initialization" Screen. Went back to Circuit & exchanged them both because there was a major hardware/firmware upgrade on the new ones. After about a week, same problem. Now I'm just going to return them. You can only return it or throw it away.
Jan 04, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
