Question about LG RUMOR Cellular Phone
Usb connection on by itself and stuck on
My phone suddenly reads "USB Connection"on the display screen. ALL by itself. And now it won't disconnect and I can't talk to sprint because now no one can hear me when I'm using the phone.
Son's was doing the same thing. Read on another site that this means the USB is making a connection somehow, usually from getting a little moisture in there where the USB (or battery charger) plugs in. Wrapped a tissue around a toothpick and wiped it out good. Phone is now ok.
Posted on Jan 02, 2009
Cant see my android on pc when connecting a usb cable
You can open "settings" on your phone and click "developer options" and click "USB debugging" under the "Debugging" options.
Also, I found Amazing Way to Connect Android to PC Mac Windows recently:
1)Download and install "Airmore" and then open it.
2)Visit "airmore.net" on PC and click "scan to connect" on the phone to scan the code. Remember the PC and phone must under the same wifi.
3)Click "accept" on your phone
4)Transfer files between PC and android.
Actually I also transfer contacts, manage apps and SD card on PC.
Sep 18, 2015 | Android Cell Phones
Dead nokia 2700 classic usb connection disconnects automatically ?
1. Please make sure your USB cable is working fine. better to connect your phone using another USB cable.
2. Change the phone's battery, or make sure its more than 80% charged and in good condition.
3. Try to connect with different USB Port on your PC.
Hope your problem will be solved.
thanks
Dec 02, 2012 | Nokia Classic 2700 Cell Phone
Usb connection from phone to computer
To connect the phone to your PC, simply attach one end of the supplied USB connection cable to the USB port in your computer, and the other to the slot on the right-hand side of your LG Shine (you'll have to remove the small cover to access the slot).
When you connect the cable, the LG screen will display the heading 'Mass storage' and the words 'Call and message are not available'. This means you won't be able to make or receive calls or texts on the phone while it's connected to your PC.
The phone will now be mounted on your PC or Mac as a disk drive. On a PC, click on the Start menu and open My Computer - the Phone will appear there as an external USB drive (usually alongside the letters E, F or G, depending on your configuration).
On a Mac, the drive will appear as a disk icon on your desktop and also in your Finder window.
Double-click on the drive's icon on either Mac or PC to see the phone's folder structure. This is the same as the My stuff section in the Main menu (click Menufrom standby mode and highlight My stuff and click OK, or press 7).
You'll notice the following folders:
  • images
  • Sounds
  • Videos
  • Documents
  • Others
To copy a file from phone to PC, simply open the relevant folder and drag and drop the file to your desktop.
To copy a file from PC to phone, drag and drop or copy the file into the relevant folder. If you put an image, video, sound or document file in the wrong folder, you might not be able to open it on the phone itself, assign it as a ringtone or use it as an ID Photo.
Good Luck
Jun 27, 2011 | LG KP500 Cookie black on T-Mobile U-Fix...
How do i use my samsung c5212 as a modem to pc and to connect to internet.
Follow the below mentioned steps : 1. Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
2 Launch Internet Sharing, found in the Start menu on your Samsung cell phone. Open the application.
3 Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than is showing on the display.
4 Start the Internet Sharing connection. On your Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
5 Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
May 14, 2011 | Cell Phones
I need to use this phone as a modem for internet. How?
  • Connect the Samsung cell phone and computer. If you are connecting via USB, connect one end of the USB cable to your Samsung phone and the other end to your computer. It may take a few seconds for the proper drivers for the AT&T Samsung phone to install. If pairing via Bluetooth, make sure Bluetooth is enabled on your Samsung phone and start a search for devices on your Bluetooth-enabled computer by right-clicking the Bluetooth icon in your taskbar.
  • Launch Internet Sharing, found in the Start menu on your AT&T Samsung cell phone. Open the application.
  • Configure Internet Sharing. The status menu should read "Disconnected." Under the PC Connection setting, select the method you will use to connect your cell phone to the computer--USB and Bluetooth PAN are the choices. You shouldn't need to change anything under Network Connection, unless a network other than AT&T is showing on the display.
  • Start the Internet Sharing connection. On your AT&T Samsung device, press the Connect soft key. It may take up to 30 seconds for the connection to be negotiated, during which the status line may say "Check USB cable connection"; this is normal.
  • Connect the computer to the Internet sharing phone. If your computer and phone are paired via USB, no further pairing is needed. You will see the shared Internet connection as a wired connection in your Network and Sharing control panel on the computer. If you are connected to the Internet Sharing application via a Bluetooth personal area network, the computer must be synced to the phone. Right-click on the Bluetooth icon in the taskbar and select "Connect to a PAN" or similar, based on the version of Windows you are using. A list of all Bluetooth PAN connections within range is shown; select your AT&T Samsung phone. The PAN connection will be negotiated, and the Internet connection will be shared.
Feb 04, 2011 | Samsung SGHE250i Cell Phone
N73ME firmware disconnect
Can i know whether ur phone is in warranty period or not. If its in warranty period, you can always claim for warranty cover from Nokia and get a brand new mobile for you. Because while updating itself, the warning message will get flashed like connection should not get disconnected and all. Once it gets disconnected, your phone will be dead and you cannot use it anymore without servicing it. It will cost you around 500INR if its not under warranty
Aug 01, 2010 | Nokia N73 Cellular Phone
I have a LG Cu920 model and bought a micro sd 8GB card and used the USB data cable to connect to the PC and i am unable to get connection established as it displays connecting to mass storage device and...
When it displays insert memory card for connecting as mass storage device, switch off the phone and reconnect so the phone will perform as a memory storage device.
Good luck.
Mar 16, 2010 | LG Vu CU920 Cellular Phone
My Mobile has a Powering problem and it doesn`t work because it was connected to my PC via USB and disconnected suddenly
contact nokia or a local phone shop to find out where to get it repaired.
www.nokia.com
You can try removeing the battery for 30minutes and trying again.
Jul 26, 2008 | Nokia N73 Cellular Phone
Can't download photo's onto computer
Are you connecting your phone as a Mass Storage Device?
  1. From the home screen, attach one end of the Motorola Original Enhanced USB cable to your phone and the other end to a USB port on your computer.
  2. On your phone, press Yes to use the phone as a portable USB storage device.
    Note: When connected as a storage device the phone cannot perform regular phone activities. Disconnect to resume normal operation.
  3. On the PC, open the My Computer window and find where your phone displays as a Mass Storage icon.
    Double click the Mass Storage Device icon.
  4. Drag and drop files between your computer and phone.
  5. When finished, remove the phone safely from your computer. Right click the "Safely Remove Hardware"
    icon at the bottom of your computer screen, then select "USB Mass Storage Device" and click Stop.
  6. Select USB Mass Storage Device and click OK.
    Now it is safe to disconnect the cable. When the cable is disconnected, the phone restarts
Jan 02, 2008 | Motorola Mobility W375 Cellular Phone
Can not connect using LG Mobile Sync
I have the same problem like everyone else in this forum! here is the solution:
1. The USB modem driver came with the CD may or will not work, so get the latest drivers for it.
2. Before install the new drivers, change your phone setting under " setting -> USB connection -> from MASS STORAGE to DATA LINK.
3. Plug the usb cable to the phone and to your PC, it should do anything or give any message if it does just cancel it for now.
4. Install the new USB driver you just download, while install it will said something like " does not work with XP " just click OK don't panic.
5. After it finished installed you will see by the clock that it find the USB LG blah blah...and ding ding sound if you have sound on.
6. Now go back to LG Sync software and click on Connect & choose LG modem com port whatever it there.
7. You're done !!!
Here the link where to get the new USB driver:
http://it.lgmobile.com/web/web.product.manualSoftwareRF.laf
Yeah the link is all Italian ...don't panic, I couldn't read it either LOL...just click on the picture where you see the phone and the PC with wrap around with arrow, then follow instruction will be in English.
Good Luck!
Keep posting good answer that you find and help out other just like US!
Sep 20, 2007 | LG Prada KE850 Cellular Phone
LG RUMOR Cellular Phone Logo
125 people viewed this question
Top LG Cell Phones Experts
kenneth njonjo
Vorked Entertainment...
IT Solution
IT Solution
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
