Question about LG VOYAGER VX10000 Cellular Phone
Can't hear other end
When I make a call I can't tell if it connects unless I look at the screen to see.other end can hear me but I can't hear them.
  • Anonymous Jan 03, 2009
    The outbound on my phone sounds scratchy but only during phone calls! I tested the ringer and music play and both work!
    Problem Solver:
  • 8 Answers
You may try to turn up the volume while a call is in progress, this could be a possible solution.
Posted on Jan 01, 2009
Can not hear dial tone or hear caller / can hear on speaker call
Most likely that it is the speaker on the handheld part of the phone. Your sound comes from the base itself when you put your current connection on Speaker-Call. So if you cannot hear the dial tone OR the person on the other end unless on "speaker" it's just the handheld and I believe there are places online you can purchase JUST that part if needed.
Oct 19, 2014 | AT&T ATT-1855 Corded Phone
Connecting dvd
First, are you sure the cable is good? can you try it somewhere else? Second make sure your DVD is setup to output via component and the TV is using the input your connecting to.
Jun 01, 2008 | Televison & Video
Where are the grease fittings 2004 santa fe
Unless a front end part has been replaced there are no grease zeros on the factory suspension parts.
Jan 18, 2012 | 2004 Hyundai Santa Fe
Where is the horn relay located found fuse horn will not cut off unless u take fuse out drawing down battery trying to check to see if relay bad cannot find it
The horn relay is located under the hood with the fuses. look inside the lid when you remove it from the fuse/relay box and it will tell you where the relay is located. To test the relay use an ohm meter and connect one end to 87a and the other end of meter to 30. there should show continuity. then check between 87 and 30 and there should be no continuity. if all of this checks out then check resistance between terminals 85 and 86. It should read 70/80 ohms. if not replace relay. If it shows good then connect a jumper wire between battery positive terminal to 86 and a ground jumper to 85 terminal. You should hear a click or clicking sound. If not replace relay. hope this will help you.
May 11, 2010 | 2004 Dodge Ram 1500
My 1996 ford ranger oil meter was low and a ticking noise in engine for a week. today the ticking went crazy and the truck shut down. how much to fix oil pump
This is not what you wanted to hear. I had a Ranger (Emerald Green) The low oil pressure was caused most likely by a rod end bearing that was for some reason worn therefore leaving a gap in the bearing mating survaces so oil was running out the sides of the rod end bearing causing the low oil presure. The ticking that went crazy was the rod end bearing that destroyed itself and fell into the oil pan.
Quite possibly you now have a broken connecting rod as for the reason it shut down unless the engine computer sensed ZERO oil pressure and shut off the ignition.
I can tell you your problem is probably not the oil pump.
I see the following instore for you
1. head removal / valve resurfacing
2. crankshaft polishing
3. rod end bearing replacement and possibly resizing
The oil pump is the least of your problems.
Just being honest so you can understand what could be instore for you. Sadly it is not cheap.
Jan 30, 2010 | 1996 Ford Ranger SuperCab
Can't hear callers on my mobile phone
Your handset thinks that you have headphones connected.
Make sure there is nothing stuck in the headset connector port, and make sure it is clean.
If thats not the problem, then it may be cured via a software upgrade or it may need a hardware repair.
Either way your gonna have to take it to a shop to be done, unless youve got the required equipment to hand.
Jan 04, 2010 | Nokia 6200
No Sound during phone call
The sound might be MUTED... check it in the option during the call (you can only check it during the call) if so unmute it ... this solves your problem...
If still problem persists then try giving restore factory settings... this will surely solve the problem ..
any queries you can get back to me...
Regards
-Dileep Bradley
Rate my solution according to your satisifaction...
Mar 20, 2009 | HTC Touch HD Smartphone
Volume control
the ear piece may be dead or if its a flip phone check the flex cable
Nov 29, 2008 | Sanyo Katana SCP-6600 Cellular Phone
CPU Fan not running
If the system is a couple of years old, the fan may be clogged with dust so the blade can't turn; these little suckers don't have much torque.
You can find the little fan pretty easy since (unless you have a high-end video or sound card) it will be the only one actually on the system board.
If you know how to access the BIOS on your particular computer, you may have one that monitors the CPU temperature and tells you in degrees.
Watch the screen at bootup for a message about entering 'Setup.'
This will give you the key to press and it often must be done very quickly; it's often F1 or F2.
Some BIOS will call the function Advanced or System something.
Don't make any changes you don't understand and when you exit, don't 'Save' any changes.
Aug 13, 2008 | AMD (WBK38) CPU Fan
There are running line on the screen
Only thing to do is turn the system off
then on wait til the red light is on press and hold the power button until it beeps and resets itself.. i hope it helps!
Jul 02, 2008 | Sony Playstation 3 (PS3) Console
LG VOYAGER VX10000 Cellular Phone Logo
52 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
