Question about Dell Inspiron E1505 Notebook
Battery light flashes red 4 times
My battery indicator light flashes red 4 times then goes solid green for @ 1/2 sec. Then repeats over and over again.
  • Anonymous Feb 15, 2009
    i saw several posts which indicate that the charging circuit on the motherboard is defective. need to replace the system board is what dell told me.
  • Casper2009 May 18, 2009
    DELLRD8508 Battery meter not showing charging when on AC power. Error code 3600:0123 in XP Diagnostics. Was showing charging yesterday with unknown charge remaining, yet still could not run off AC power. My wife has same problem with her DELL, as well as my mother. Motherboard issue, or what? Would this be a manufacturer's issue?
  • 741 Answers
Check your users manual. Normally if it is blinking it is powering up, but may be different depending on model.
Posted on Jan 01, 2009
I have a brand new Ryobi kit put battery in the charger the red light goes on and the green light flashers on and off is this charging or should the green light go off until battery is charged.
When the battery is charged the green will be steady on and the red will go off. Flashing green is an indication that it is charging.
hope this helps?
Jan 19, 2016 | Ryobi 18v Combo Kit P845 4-tools/...
Line 1 disconnects people on hold
Try these first and let me know
Intercom does not function correctly
• Make sure line 1 is connected properly and common to all phones on the system.
• Make sure all phone ID’s (station numbers) involved have been assigned.
Transfer does not function correctly
• Make sure receiver phones (stations) have same line connected.
Intercom indicator turns red and green alternately
• The station address needs to be re-assigned due to a duplicate station address in the system. See “Changing the Phone ID (Station Address)”.
Good luck,
Jun 17, 2008 | GE RCA 4-Line Speakerphone
Flashing red light on Morphy Richards 732000 Supervac
If it is supposed to go green then the battery is not being fully charged. Unit is under warranty and now is the time to have matter addressed.
Aug 20, 2015 | Vacuums
Greetings Gurus. I have Makita charger model DC18RC, battery model is 18v BL1815...manual is of limited help. I'm trying to understand what the indicator lights mean, what the time is for charging,
I agree that the pictographs are not very helpful. You probably have one of the new chargers. I have an old one, which is a little easier to figure out.
From top to bottom
1. The flashing green light with the electric plug indicates that the unit is plugged in and ready to go.
2. The flashing red little fan means that the battery is too warm so it is just cooling it and not charging it at that moment.
3. The solid red empty battery outline means that it is charging but hasn't got very far, less than 80% full.
4. The mostly full battery outline with both solid red and green lights at the same time means it is 80% full or more
5. The full battery outline and solid green with the musical notes means it is full up.
6. The broken battery outline with flashing red and green means you've got a broken battery.
7. The yellow light with the wrench means the charger is "conditioning" the battery, whatever that means.
8. The yellow light with the fan means "cooling abnormality."
Hope this helps
Nov 01, 2014 | Drills
My question is related to an Invacare-Nutron R51.Production date 1-7-03,joystick[MKIV R11] flashes red 1 time, than green 5 times repeatedly? Can you please tell me what this means.?
Ranch well the red flash indicates a low battery and the 5 flashes indicate a bad left brake. Now try charging the batteries until you get a green light on your charger then turn on the chair it shouldn't flash the red if the batteries are accepting the charge. If your batteries are 2-3 years old it could be time to change them. If Medicare paid for your chair then they will pay most of the repair costs. You can contact your provider for help or a service company like Roadrunner Mobility @ 1-800-467-2668 or Repair Xpress @ 1-877-581-3733. If Medicare did buy the chair then you are eligible for a new chair every 5 years and yours is almost 8 years old. Contact a local provider that you trust to check into getting you a new chair. Hope this helps you
Sep 29, 2010 | Invacare Pronto M51 Power Wheelchair
I bought a house with a Night Sentry Solid State Timer model # EJ341 and have no instructions on setting or programming the unit.
rapid Programming.
1. Move control lever to OFFCLEAR for at least 5 seconds
• red indicator light goes off
• all time settings are
2. Move control lever to ON.
• red indicator light will start
3. Check a clock; then turn pushbutton time dial clockwise at least one click.
• stop at the half hour nearest to present time (note
AM or PM).
Note: When turning pushbutton time dial, do NOT
accidentally PRESS at the same time.
4. Press pushbutton time dial once to enter present time.
• red indicator light goes off (present time has been
5. Turn pushbutton time dial clockwise to desired
ON time.
• red indicator light blinks with each click.
6. Press pushbutton to enter ON time.
• controlled light(s) will turn on.
7. Turn pushbutton time dial clockwise to desired
OFF time.
8. Press pushbutton time dial to enter OFF time.
• controlled light(s) turn off.
9. Repeat 5-8 for other on/off times.
10.Turn pushbutton time dial for at least 2 more turns
from the first ON time to complete this program
• red indicator light will turn on and stay on (steady
light means timer is in automatic).
Note: Pushbutton time dial does not turn
automatically after setting to indicate time of day
Aug 22, 2010 | Hardware & Accessories
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
Batt light flashes 4 red and 1 green over and over vostros laptop
Hi there. If your battery light is flashing 4 red and one green on the battery light indicator (as in the one next to the power and hdd led), then this is an indication that your battery is nearing the end of it's life, and it's time to get a new one. It will last a bit longer, depending on how much you use your laptop, but there will come a time when it won't work at all.
Apr 20, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
Dell Inspiron E1505 Notebook Logo
958 people viewed this question
Alun Cox
