Question about Sony Playstation 3 (PS3) Console
PS3 does not play any sound, HDMI or Optical
Dear Support,
Happy New Years!
My new Sony PS3 (6 months old or so) has some sound issues that have only gotten worse. In the beginning games and movies would have regular periods of a second of silence during play. Recently, a few weeks ago, my PS3 has stopped all its sound. I haven't changed any of the configuration or hardware at all. The PS3 was originally connected to a speaker system via optical. To troubleshoot I tried using the HDMI to have sound directly from the TV speakers. This does not work either. Please advise on how to get my sound working again.
Thanks,
-Joshua Polier
  • joshuapolier Jan 01, 2009
    I checked out the video. Already tried the 10 second reset... doesn't work... my sound also cuts out for like a second every minute or few minutes its not as frequent as in the video, different problem I think. Also I have used the Linear PCM settings and tried a few others. I think my hardware crapped out. Not sure though.
  • 903 Answers
I have found this vid on youtube.
http://uk.youtube.com/watch?v=9XOyYnuCItQ
The vid isn't that explanatory but if you read the viewers comments there are a few remedy suggestions.
I hope this helps
Posted on Jan 01, 2009
Was palying game console on a Tv with HDMI and optical set-up. #1Moved console to new tv and just used HDMI. I now have no audio output when game loads.This is on new TV.Game plays but after loading sound...
Try resetting your PS3 video/audio settings.
ress and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until you here 3 beeps. Let go.
It should ask you to connect your controller via usb and press the PS button in
the middle of your controller. There will be a menu with 6 options. Try 2-5.
Jan 21, 2011 | Sony Playstation 3 (PS3) Console
What cables do i need to connect my ps3 to my sony recevier.
do you wan the suround sound to play sound for what the tv is displaying or just the ps3
for just ps3
connect hdmi to ps3 and tv
connect optical to ps3 and suround sound
change video settings to hdmi
change sound settings to optical
it asks to set settings automatically you have tyo doo it manually
if you want to play every thing that tv displays then
connect ps3 to tv with hdmi
connect suround sound with hdmi to tv
(this might not work)
if it dont work then
and your tv should have sound out or something along those lines it should be two phono plugs in the back of the tv connect that to the suround sound
Dec 31, 2009 | Sony HT-DDWG700 Theater System
No surround sound when playing PS3 through HTDDWG700 via 2 HDMI
The HTDDWG700 does not transfer the audio through the HDMI cable that the vision goes through. To solve the problem i got an optical cable and connected the PS3 to the receiver with the optical and put the HDMI cable from the PS3 to the tv.
Oct 18, 2009 | Sony Playstation 3 (PS3) Console
No audio
stupid answer but did u check the audio settings in the main menu from the ps3? i reset my ps3 on accident n the audio changed to component but picture stayed on HDMI
Jul 13, 2009 | Sony Playstation 3 (PS3) Console
Simultaneous Optical & HDMI Audio on PS3
I'm almost positive it cannot stream the sound through two outputs by design. However if your TV has a digital optical output you can run it to the TV via HDMI and from the TV to the receiver go with the optical. It shouldn't bother the quality at all being HDMI is also a digital interface, you're just passing it through your TV.
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
Connect PS3 for playing/viewing blue-ray thru surround sound
I just finished setting up my system last night and was facing similar problems with sound/video from my PS3. The only option I could get working was to have the HDMI cable connected from the PS3 to the TV and then connect the Optical cable to the receiver for sound. I was under the impression that HDMI handles sound and video but for whatever reason the PS3 does not agree.
I have DTS sound and fantastic picture now through my PS3, hope this helps.
Cheers
Oct 05, 2008 | Sony DAV-HDX500 System
HDMI sound?
I had the same problem with my PS3. I have a HD cable box with HDMI out, a Sony DVD player with HDMI out. The Sony receiver STR-DG800 only has the HDMI inputs (sat/tv and dvd) and the HDMI is only a pass through port and will not decode audio.
I purchase a HDMI 4 port switch from Newegg (HS-41A0 http://www.newegg.com/Product/Product.aspx?Item=N82E16812168003&Tpk=HS-41A0) to hook up the DVD and PS3 to the DVD HDMI and switch between the DVD player and the PS3. It took me several days to figure out how to make this work with the settings on the reciver.
1 the DVD player must use the coaxial in jack for sound on the receiver.
2. the PS3 must use the optical connection on video1
3. the sound settings in the PS3 must be set to PCM
4. set the sound setting on the receiver to the following
a. on the remote press AMP button then the MENU button, next press the down arrow to you see 5- AUDIO SET - then press enter.
b.set sound decode priorty to PCM
c. next scroll down to you see digital assign - press enter
assign VID1 OPTICAL to DVD ( this allows the pcm output from the PS3 to play through the receiver), next assign DVD to COAXIAL setting DVD to DVD (this allows the digital sound to play from your DVD player).
So when you use your remote and select DVD, you can use your PS3 or DVD through the 1 DVD HDMI port.
Feb 04, 2008 | Audio Players & Recorders
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Connect the PS3 to your TV with the hdmi cable and to the surround sound system with a digital optical cable, then set your PS3 to output sound through the optical port (through the sound options menu) and you're good to go!
Oct 27, 2007 | Sony DAV-HDX500 System
Ps3 using digital optical and hdmi cables together
There is a conflict in the fact that HDMI gives you the digital surround sound without the need for the optical lead and when you allocate the optical for the sound thats when the conflict starts, you can only use one or the other.
Jul 31, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
129 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
