Question about Clarion DXZ545MP CD Player
Hi! My DXZ545MP CD Player had some buttons pushed by my dog in the car and now the volume no longer works. There is no sound at all regardless of the volume levels and it simply stopped playing music once my dog accidentally pushed whatever buttons. I've tried turning the volume up then down, shutting off the system and turning it on again, removing the face plate and reattaching it, pushing every button on the front panel, but nothing seems to get the sound back regardless of whether it is on CD, Tuner or Mcatcher...the rest of the device works just fine, just no sound! Any suggestions would be great!! Thanks! Kelly
    Brigadier General:
  • 5,158 Answers
First kelly... if you don't already have it .. here's the manual...
http://www.clarion.com/ca/en/MungoBlobs/754/615/DXZ545MP(Manual),1.pdf
you can reset that by unhooking the battery for about 10 minutes and hooking it back up... if that is an anti-theft type radio make sure you know the code and how to enter it. you'll have to set the pre-set stations again too.
Robert
Please take a moment to rate this solution thanks.
p.s. just noticed how long ago you posted this. you probably have it fixed by now... but the manual may come in handy to you
Posted on Apr 19, 2009
Problem with JVC Kw-xr610 Car CD / USB/ MP3 Player Cd player works and volume control all other buttons won't
Have a tech open the ftont cover and check for cracked board. This board cracks when pushing the volume control too hard
Sep 28, 2013 | JVC Kw-xr610 Car CD / USB/ MP3 Player
2003 cadillac cts will not eject cd
Hi, Worst thing you done was to remove the battery, but ref: CD player look under the volume control (on/off) you should find a very small hole enough for a paper clip to be pushed in & eject the cd check your fuse since removing battery may have caused quick short touched & blown fuse. Please give feedback at crossflowspeed@hotmail.co.uk Thanks, Malcolm Campbell.
Sep 27, 2017 | 2003 Cadillac CTS
Clarion DXZ545MP in yacht . charter client usedan mp3, pulled it out and the receiver would no longer get satelite radio, It also wqould not receive satelite radio from tv receiver qwhen on AUX. The name...
Have you tried 1st to pull the unit out of the wall using the little metal "keys" to release the deck from the mounting cage and than pull the power plug AND the Satillite plug as well and wait for 10 minutes or so and replug it but first hit the reset button and see what happens. I run into this frequently with Clarion's in boats/yacht, not sure why but i guess it could be result of a voltage surge. Now the display is saying that you have a blown speaker or more than likely a wire that is grounded out. I highly doubt the charter client caused the head unit to shut down other than the simple act or ejecting a cd. We quit selling Clarion for that very reason, an abnormal rate of repair occurances. And I would wager you have the hard wired remote controls either on the bridge or in the rear at the swim platform or both locations. These too could be the problem. I can't tell you how many hours i have spent running down a shorted speaker wire. Because if one is shorted in the "slightest" you get the message "amp guard". If push comes to shove Captain i recommend a small amplifier and use only the pre-outs (rca cables) instead of speaker wire. Good luck and let me know if i can assist you because i work on a lot of watercraft believe it or not in Arizona and most are over 34' Cuddys like SeaRay SunDancers etc. good luck... Mark @ Sounds Good to Me remarkable53@aol.com if you want to reach me direct. I still have Clarion contacts too.. mark
Aug 18, 2009 | Clarion DXZ545MP CD Player
Setting the time
here is the owners manual for that stereo
please take a moment to rate this solution.. thanks
Apr 19, 2009 | Clarion DXZ545MP CD Player
Clarion dxz545mp amp guard issues
, the message you are getting is "amp guard". This is the mesage it will display when a short in a speaker wire or speaker with low impedence is hooked to the internal amp and sends it into protect mode, shutting down the amplifier section while the rest of the unit continues to work.
check all of your speakers
Jan 16, 2009 | Clarion DXZ545MP CD Player
Jan 16, 2009 | Clarion DXZ645MP CD Player
CLARION DXZ545MP
No, the RCA plugs are used for connecting to an amplifier only, they are not powerful enough to drive speakers directly.
Oct 06, 2008 | Clarion DXZ545MP CD Player
I can't get any sound out of my monitor. when I push the select I get the speaker w/music, select that.My color on th volume is green. I get no sound. I try to push the 1-2 reset button and nothing changes...
First use a try testing another source of sound, (say an Ipod or cd player) instead of your computer.
If that works the try troubleshooting the mute and volume controls on your computer.
Mar 13, 2008 | NEC AccuSync LCD223WXM Monitor
Jensen vm9311 dvd indash volume is loud when i turn on car
Heres the best way to fix; Quote from manual "Programmable Turn-On Volume (Pg.12) This feature allows the user to select a turn-on colume setting regardless of the colume setting prior to turning the unit off. To program a specific volume level, push and hold the VOL/LOC/DV know (6) while the yellow volume bar is displayed on the screen. The unit will beep two times to confirm your turn-on volume setting." Ah i had the same problem. I turned to the manual and it worked for me :) Good Luck, Ern
Oct 23, 2006 | Jensen VM9410 Car DVD Player
Clarion DXZ545MP CD Player Logo
141 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
