Question about ASUS EN8400GS SILENT/HTP/256M PCI-E TV-OUT HDTV-OUT DVI-I VGA, PCI Express Video Card
My Moniter Is Blank
Hello, I recently bought new parts to create my own PC but I cam among a problem. Everything is hooked up correctly yet the moniter doesn't display anything with two diffrent moniters. The little light turns green and about 5 seconds after startup turns yellow and nothing appears.
Parts: 1 x ASUS M2N-MX SE Plus Micro ATX AMD Motherboard 2 x Kingston 512MB PC-5300 DDR2 Desktop Memory 1 x ASUS EN8500GT SILENT MAGIC 512MB GeForce Video Card 1 x AMD Athlon 64 X2 6000+ 3.1GHz Processor 1 x Sony Black 20x DVD+/-RW SATA DVD Burner 1 x 2-2B Black/Silver ATX Mid Tower Computer Case 1 x Samsung SpinPoint T Series 500GB SATA Hard Drive
  • 3 more comments
  • Joshua He Jan 01, 2009
    Yes, I have tried this but for some reason it doesn't show on either.
    Here is a pic of the port that I place the monitor plug in if the video card is not connected. "http://i42.tinypic.com/2i8y939.jpg"
    Ok, I have tried this and my moniter now shows video an such but a new problem has occured.."Reboot and select proper Boot Device or insert Boot Media and press any key!"
  • Joshua He Jan 02, 2009
    Ok, Just did that and everything booted up fine but when I put in the CD the same thing appeared.
    Well, when I turn it on you can hear the PC booting up via all of the confirming beeps. Then it goes to a black screen with a little white line beeping and does nothing so I put in my cd then it displays the same boot message.
  • Vern Haynes
    Vern Haynes May 11, 2010
    This board has an oboard video adapter; have you tried connecting your display to it instead of the video card?
  • 281 Answers
First make sure that you have the P4 connector (the square one at the top of the board connected to your P4 power from the power supply.
From here I would disconnect the data cables from the hdd, optical drives, and remove all video/peripheral cards. You should have only the RAM, CPU, and power connected, then try to boot again.
If this works, then add 1 device at a time until it fails to start. This will isolate the component that is giving you problems.
With a single stick of RAM, try to get the computer to POST. (if possible, test the ram in another machine first to ensure that RAM is good)
Posted on Jan 01, 2009
  • 1 more comment
  • Vern Haynes
    Vern Haynes Jan 01, 2009
    OK,
    So it's powering up. Add you hard drive, then power it up. If it works, then do your CD-ROM drive.
    If that works then install the video card.
    Once you get all your components installed then you can put your Windows disk in, and boot from it. That should get your windows install running.
  • Vern Haynes
    Vern Haynes Jan 02, 2009
    Could you clarify"Ok, Just did that and everything booted up fine but when I put in the CD the same thing appeared." What appeared? DId the PC boot off the disc?
    Did it crash or blue screen instead?
  • Vern Haynes
    Vern Haynes Jan 03, 2009
    You need to tell the computer to boot from the CD; there may be an option in the POST screen to do this; otherwise you will need to enter the BIOS and set the CD-ROM as the primary boot device. From there, look for the prompt, "press any key to boot from CD" and tap any key to boot...
    President:
  • 948 Answers
Remove the video card you added, then try again.
Help Me! I recently bought a ASUS EAH5450 SIlent, but when i put it into my computer, the screen just stays blank! What is wrong?
If the pc works with another video card then the one you just bought is defective - take it back and have it replaced.
Apr 18, 2011 | ASUS EAH5450 SILENTDI1GD2 graphics adapter...
Problems with 8400GS graphics card
First, you need to be sure you have installed the correct drivers for the card that corresponds to your OS.
Second, you need to go into the control panel (assuming you are running Windows of course) and tell the computer you now have a new graphics card installed and to use it instead of the default one detected when the OS was installed.
Reattach the monitor to the GeForce card and reboot. All should be OK.
Jan 06, 2010 | HP NVIDIA GeForce 8400GS - Graphics...
Blank screen
Hey I am also facing same problem.But My card was woorking fie before yesterday.
I bought a new CPU cabinet> so had to remove nad reinsert the GFX card and it giving me the same problem as you are facing....
i.e. the fan is moving but screen is blank
Help plz.
Apr 18, 2009 | XFX NVIDIA GeForce 8600 Graphics Card
Radeon R9600/XT GRAPHICS CARD
Yes, they both will act independently if you choose to use it that way or they will show the same picture, one is a DVI output and the other is VGA. Use the ATI’s CATALYST software suite provides the ultimate software required to enjoy the full acceleration of your ATI Graphics Accelerator card. You can use it to separate your Primary video from your Secondary video.
Jan 03, 2009 | Abit R9600XT-VIO RADEON 9600 XT, (256 Mb)...
What dvi cable do i need?
Any bog standard dvi cable should work. As should a dvi to vga converter. Dvi is by far the better interface, and I would highly recommend using it, without any converters. I don't believe you can up convert vga to dvi, but you can certainly downgrade a dvi signal to vga, but i can't see why you would want to...
Oct 17, 2008 | Computers & Internet
Home screen blank
have you recently installed any new hardware? If so what did you install and did this problem start after the installation?
Aug 20, 2008 | Computers & Internet
Please tell me how to install Gigaware PC Cam on my Vista Computer?
check the manufacturer site for Gigaware PC Cam and download the vista driver
Jul 07, 2008 | Computers & Internet
8800 gtx graphic card blank screen or pc reboot if i start any game
have had similar problem try pulling card out and refit a couple of times
Mar 23, 2008 | Computers & Internet
ASUS EN8400GS SILENT/HTP/256M PCI-E TV-OUT HDTV-OUT DVI-I VGA,  PCI Express Video Card Logo
425 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
