Volume screen doesn't go away when its adjusted
I have a HP dv2988nr and whenever i adjust the volume the little volume indicator does not go away and it freezes or lags everything else that i am doing. It eventually goes away after several minutes.
  • 1 more comment
  • scorpion31 Jan 01, 2009
    The laptop is new by the way, we just opened it up to test it and this is what happened.
  • consultantgr Jan 10, 2009
    I have the same laptop (HP Pavilion Entertainment) and once the keyboard volume button is pressed the icon only goes away immediatelly as long as you are not running anything else. If you do it takes something like 5 minutes and everything slows down.This is an issue only with the volume buttons on the keyboard. This is a brand new laptop which I bought just a few days ago. Other than that, it is a great laptop and very fast. I am sure it is a software issue and an update should be available soon.
  • scorpion31 Jan 10, 2009
    Problem solved! There was a driver update available and it fixed it. Works great now!
  • 3 Answers
This is what I read and it works great
"..have the same problem and did a little looking around. I found a way to avoid the problem not to fix it. I have a dv9933cl with Vista (64bit). Go the the search bar under the menu and search 'msconfig'. Under one of the tabs on the screen that appears after clicking 'Open msconfig' there will be a list of checked items. One of the items is named 'Quick Touch On Screen Display' deselect this item. Click 'Ok'. It should then prompt you to restart your computer. Do so. Your volume Touch Sensitive keys should now work properly with any application open but you will not get a display.."
Posted on Jan 10, 2009
    Novelist:
  • 146 Answers
Uninstall the driver and audio software associated with the soundcard, and reinstall with the latest drivers from the HP site. That may remedy the problem. You also might want to scan the hard drive for errors. It is possible that the driver or the utility got corrupted by improper shutdown.
Check for viruses and spyware. I hope you have a decent anti-virus installed. Norton, McAfee and Trend Micro don't really do much and they don't detect a lot of stuff. AVG is a free AV/AS software that works well and updates daily. Kaspersky is also good, but they have no free version and if you are not careful it can disable important Windows functions.
Last ditch would be reinstall Windows and see if it fixes it. If it doesn't then there is an issue with the sound card or the motherboard.
Cheers and best wishes
Posted on Jan 01, 2009
  • Shayne Schecht Jan 01, 2009
    I would check with HP tech support to see if they have an update for the system or if it is a defect that needs to be addressed. The other option is to return it for a replacement.
    Sorry I could not tell you more.
    Cheers
I am having problems adjusting volume
What type of laptop HP , ASUS , COMPAQ , ACER ?..........
Up the Volume on My HP Laptop
Open the "Start" menu and click on the "Control Panel" icon.
Locate and open the icon that deals with sound.
Depending on your version of Windows, it will say either "Sounds and Audio Devices" or "Adjust System Volume."
Adjust the volume under the "Speakers" icon.
To do this, click on the slider bar and move it up on the slider.
If you need to decrease the volume, simply move the slider bar down.
Click on "OK" when finished and close the "Control Panel" window.
Click on the speaker icon in the bottom-right corner of the screen for a faster volume adjustment. Simply move the slider bar up to increase the volume and move it back down to decrease the volume.
Volume on an Acer Laptop
Acer laptops are typically sold with pre-installed Windows operating systems that offer sound-adjustment features for increasing the volume on the laptop's built-in stereo speakers.
These same functions can also be used in tandem with external speakers or headphones to increase the volume, as well as mute all sound on the laptop.
If the computer should output an unusually low volume, fixing the problem may be no more involved than sliding a control switch with the computer mouse. Click once on the speaker icon in the taskbar on the lower-right corner to open a rectangular window with a slide control.
Click and hold the left mouse button on the slide control to drag it upward, increasing the volume to the laptop's maximum setting.
Click the "Mixer" button below the slider control to open another window with volume controls for "Speakers" and "Applications," adjusting each slide control upward to increase the volume.
Be sure the speaker icon below each control is not accidentally muted.
Click once on each speaker icon to remove the red circle with a slash through it, which will restore audio.
Click the Microsoft flag or "Start" button in the lower-left corner if the shortcut speaker icon is missing from the taskbar.
Click "Control Panel" to select "Adjust Sounds" from the Hardware and Sounds category.
Aug 10, 2013 | Computers & Internet
How to adjust auto volume on 2008 nissan pathfinder stereo
go to MENU the guide to setup the AUDIO, and adjust with the indication Screen.However you must read the owner manual for better intructions.
God bless you
Jul 17, 2013 | 2008 Nissan Pathfinder SE
On screen volume indicator missing
Which operating system ?
Click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume in XP
Mar 08, 2013 | Gateway Computers & Internet
I have a 9-month-old HP destop PC on which I have never been able to adjust volume. Whenever I push what seems to be a volume button on the front of the monitor, I ALWAYS get the "OSD Lockout"...
Down by the clock on the bottom right of the screen is a volume control click on it and you should be able to adjust the volume.
There is a nice video here:
http://www.youtube.com/watch?v=hWlVRGAwpKk
It shows you on windows xp, but it is pretty much the same on vista and 7 too.
Hope this helps.
May 18, 2011 | Computers & Internet
LHow do I increase the volume as the phone is very quiet
Hello there,
Adjusting the volume on an HP Officejet All-in-One
Follow these steps to adjust the volume of the various fax sounds.
Adjust the rings and beep volume
1.Press the Setup button P(wrench).
2.Press the arrow buttons (Left and right) to select Basic Fax Setup , and then press OK .
3.Press the arrow buttons (Left and right) to select Rings and Beep Volume , and then press OK .
4.Press the arrow buttons (Left and right) to adjust the volume, and then press OK .
Adjust the phone line and monitor volume
1.Press the Setup button (wrench).
2.Press the arrow buttons (Left and right ) to select Basic Fax Setup , and then press OK .
3.Press the arrow buttons (Left and right ) to select Phone Line, Monitor Volume , and then press OK .
4.Press the arrow buttons (Left and right ) to adjust the volume, and then press OK .
Adjust the handset volume
When you receive a call, pick up the handset of the product, and then press the arrow buttons (Left and right ) to adjust the handset volume.
Please feel free to leave a testimonial if this works and please do not forget to click 4 thumbs.
Cheers!
Mar 22, 2011 | HP J3680 Officejet All In One Printer
How do i turn up volume on hp officejet all in one
Adjust the volume
The HP All-in-One provides three levels for adjusting the Ring and Beep Volume and
the Phone Line Monitor Volume.
The ring volume is the volume of the phone rings. The beep volume is the level of
button press and error beeps. The default Ring and Beep Volume setting is Soft.
The Phone Line Monitor Volume is the volume of dial tones and fax tones. The
default Phone Line Monitor Volume is Medium.
To adjust the Ring and Beep Volume from the control panel
1. Press Setup.
2. Press 4, and then press 4 again. This selects Basic Fax Setup and then selects Ring and Beep Volume.
3. Press to select one of the options: Soft, Loud, or Off.
4. Press OK.
To adjust the Phone Line Monitor Volume from the control panel
1. Press Setup.
2. Press 4, and then press 5. This selects Basic Fax Setup and then selects Phone Line Monitor Volume.
3. Press to select one of the options: Medium, High, or Low.
4. Press OK.
Trust this is helpful. Please vote. :)
Dec 14, 2010 | HP Officejet 4355 All-In-One InkJet...
Volume on tv adjusts automaticly
is the volume of your tv adjust automatic with a volume indicator on the screen appear?if that the case clean the volume controls on the mainboard with a contact cleaner..2nd is is the volume adjust with no volume indicator on the screen?your problem might be onthe sound if section.adjust the sound IF with a plastic screwdriver clockwise or counter clockwise until the soun stabilises..adjust the IF with a power is on.
May 17, 2010 | Televison & Video
To adjust volume down in right corner of screen next to the battery charge indicator I had a volume indicator that I can click on and adjust my volume today it is missing
You need to go to control panel and open the volume control in there..Then look carefully it will have an option where it says place volume control on the task bar...so click or check on that which in turn will give you back the volume control at the bottom, next to the battery indicator.
Nov 03, 2009 | Dell Inspiron 1501 Notebook
Whenever i use software like sype to make internet calls it keeps telling me my microphone volume is low. i then ran the test hardware wizard for my sound and the microphone does not pick up any sound....
Try adjusting the volume settings in your mic.
Go to Start->Control Panel->Sounds and Audio Devices-> Click on Voice Tab->Voice Recording ->Then adjust volume
Oct 30, 2009 | HP Pavilion dv1000 Notebook
Shortage?
There is a ribbon cable between the laptop & the screen. It sounds like you have a short in that cable. If you're not good with tedius electronic repairs, it would be best to have a shop repair it.
Mar 25, 2009 | Gateway Computers & Internet
Computers & Internet Logo
163 people viewed this question
David Payne
David Payne
