Question about Tools & Hardware - Others
Senco SN4 misfiring intermittently
My Senco SN4 intermittently fails to drive a nail. I have checked and cleaned the gun, changed nail sticks, changed nail size, checked magazine spring tension, oiled the air barrel ... everything looks fine, except the firing pin is not be returning, after firing, sometimes ... ?
  • 2,176 Answers
This is a discontinued tool by Senco but there are still parts available for it. It sound to me that the o rings and possibly the firing valve need to be replaced. I would recommend going to Senco.com and you will find a complete parts diagram in their discontinued tool section. They also have a toll free number if needed and you can talk to their air pro. I have rebuilt quite a few of these and they are not that hard just make sure to clean all the parts and use lube when replacing O rings.
Posted on Jan 01, 2009
Sn4 drives nails too deep
Proberbly the bump stop needs replacing here, the reference is BB0018 but as this is a discontinued tool, you may have difficulty finding one.
Apr 02, 2014 | Senco Tools & Hardware - Others
I have a Senco SN70 framing nail gun. The gun
One question is do you regularly put oil in the gun? Also you need to make sure that the screw holding the 'clip' near the barrel is tight and not loose. These are the 2 main problems when a gun is misfiring.
Oct 02, 2013 | Senco Air Tools & Compressors
My senco frame nail gun isn`t working
First get an exploded view of gun and parts list and numbers from senco.com,,take nail gun apart,,,take a good look at the rubber bumper stop to see if it is broken,,look at the driver nut to see if it is tight,,,,you can go to juldan.com once you have gotten a list of the worn parts,,,juldan sells complete o ring kits along with nearly all parts needed for your repair
Jan 18, 2013 | Senco Air Tools & Compressors
Senco fram pro 602 nail gun firers but no nail just a hole from firing pin
First, check that you are using the proper nails. The FP602 needs Full Round Head nails with plastic collation. If you are using Clipped Head nails with the paper tape collation the angle of the nails not let the driver catch the next nail and drive it into your work.
If you have the correct nails, check the magazine to make sure the nails are feeding all the way up to the driver. If there is anything blocking the way or if the spring on the feeder isn't taught enough to pull the clip all the way up the driver won't be able to catch the next nail and drive it in.
May 05, 2012 | Senco Tools & Hardware - Others
I have seen many nails that supposedly fit the senco sn4 nail gun. Some are 31 degree, some are 33 degree. All have paper collating. What angle nails should I search for to fit the senco sn4?
Senco uses 33 degree paper tape clip head, however many generic brands will label their box 30-34 degree to fit several nailers. This practice causes jams in some guns and others work fine. The goal is to save money but could cost more in the long run if gun is damaged. You can use generic (other than 33) if you take a strip of nails and place them against the outside of the rails aligned with either the line of driver path of angle of the rails. This will give you a visual as to the alignment. Best result is when the complete nail is in line with the path of driver. Next best result is when the head is in the path of driver and point of nail is slightly away from path, worst is when point hits path and head is back. Good luck
Mar 26, 2011 | Senco Air Tools & Compressors
I just rebuilt my Senco SN4 nail gun because it leaked air.
I think that you are referring to the firing valve and no it should not be split. I suggest going to Senco.com and typing in your model number fora breakdown for this tool. They offer different kits for various failures. Let me know if you need more help
Nov 23, 2009 | Tools & Hardware - Others
Senco framepro 502 repeatedly fails to advance 8d 2 3/8 nails. Nail heads seem to hang up on the driver. Had it for about a year and ran about 7000 nails mostly 16d with some misfires. Is there any...
There is not an adjustment for this. You can buy an o-ring kit for this gun that comes with instructions and is easy to install. When the O-rings get worn or to much dirt and grit build up inside the piston and driver will not return all the way up after firing.
Nov 09, 2009 | Senco 4D0001N Framepro 502 Framing Nailer
Senco SN4 nailer not feeding
ther isn't a spring, it works on air to pull the driver back up. Have you tried oiling the tool as recommended (about 6 drops a day) If not then you have a problem with either o rings that are dried out or worn so they cannot keep the suction required for the tool to operate properly. Might also be a bent driver (doubtful). Go to Senco.com and type in your model number and they list rebuild kits for this tool. If you need more assistance let me know and if I have helped with your request would you please rate this accordingly.
Sep 11, 2009 | Senco Air Tools & Compressors
The Senco SFN-1 gun will drive one nail and then not retract
sounds like time for a rebuild i do this once a year on all of my guns i buy a seal kit and replace them at that time and oil the interior oparts and check for worn or broken parts
Sep 03, 2009 | Senco Tools & Hardware - Others
Tools & Hardware - Others Logo
687 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
