Question about Sony KP-57WS520 57" Rear Projection HDTV-Ready Television
Stand-by flashing Occasionally the the stand-by button will flash nine times and the TV will not come on. After some time the TV will come on, unplugging it some times seems to to help. It has been getting worse as time goes by. Any help would be appreciated. Thanks Tony
  • tony hamblen May 06, 2007
    My bad. Sony kp-57ws520
    Thanks Tony
  • migadore Aug 01, 2008
    stand by light flashes and tv wont turn on.
Your high voltage splitter is going bad. g board is not your problum
Posted on May 08, 2007
    President:
  • 1,284 Answers
You will need the G board replaced, part number A-1054-157-A. The board is no longer available but you can contact PTS at http://www.ptscorp.com and have them rebuild the board you have in the TV.
Posted on May 07, 2007
How do I solve a problem with my Hp Probook, whenever I press the power button, the power light flashes nine times?
On that particular model you need to press the power button nine additional times waiting for the light to Blink 9 times each and then after the 9th time the procedure is as follows... Press the button 4 times hold for seconds on the fifth button push then release for 4 seconds then press the button twice and it should blink 8 times repeat this procedure continuously until the button only lights up once. After the button lights only once then you are ready to place the item into a garbage bag and throw it into the dump
Feb 08, 2018 | HP Computers & Internet
Turn on tv the screen turns red flashes a few times and thenshuts off. if hold all buttons the green light flashes once then nine times
the problem is your tv is cold soldered (electronics parts is loosens) so do not use first the tv because if you use it again again the tv is destory any parts is change.try to go the expert technician
Apr 13, 2010 | RCA HD52W59 HDTV Projection Television
MY TV RCA MODEL R52WH74 WHEN YOU PUSH THE POWER BUTTON ON IT FLASHES ONCE AND THEN FLASHES NINE TIMES
CK 3 capacitors on Deflection board bootom board to he left if cp150 2200uf 16v is puffed up it is bad other 2 are 220uf 35v cp114 cp120
Nov 12, 2009 | Televison & Video
Will not power up, stand by light flashes 9 times, then restarts flashing but never powers up
If your a novice at TV repair don't try it. A Sony authorized repair station knows what this problem is and should be cheaper in the long run for them to repair it.
May 25, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
WON'T TURN ON
nine blinks means that there is a short inside the set you will have to find a tech to troubleshoot the set most probably is the G pcb
Aug 23, 2008 | Sony KP-46WT520 46" Rear Projection...
Standby light flashes nine times and tv will not turn on
I had the same problem with Sony KV-32fs120 with 9 blinks. Replaced D645 and D647 on main board with 1.5A1KV diodes from Radio Shack which did the trick.
Jul 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The stand by timer flash 9 times stop and start again
you have a regulator problem my friend in the power supply or there is a fault in the G board. This is not a repair an untrained person should attempt, please get a pro to assist you in this repair.
Jun 05, 2007 | Sony FD Trinitron WEGA KV-32FS320 32" TV
Sony KP-57WS520 57" Rear Projection HDTV-Ready Television Logo
296 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
