Question about Gateway 7210GX Notebook
Keyboard unresponsive after returning from hibernation
I have a Dell 7210GX laptop. When I try to re-use the computer after it has been in hibernation, I can usually hit the 'backspace' button and it continues to work as normal. Now, the keyboard is completetly un-responsive after hibernation and I have to shut the computer off and then use it again. Help?
How to Customize Dell Media Direct Button to Hibernate?
Uninstall any programs having to do with Dell Media Direct from your computer.
Install Microsoft Intellitype Keyboard Software and Keytweak
26318734-bxzhjmonsmllydp0qa2riq2g-2-2.jpg Open Keytweak to remap the Dell Media Direct button to make your computer think you are actually hitting the "calculator" button on a multimedia keyboard even though we are using your standard-issue laptop keyboard.
  1. Click on Tools in the top menu and select Half Teach Mode.
Press the Scan Single Key button and then push your Dell Media Direct button. 26318734-bxzhjmonsmllydp0qa2riq2g-2-9.jpg
Select Calculator from the drop down list and hit Remap. 26318734-bxzhjmonsmllydp0qa2riq2g-2-14.jpg
Click on Apply and restart.
Give your Media Direct button a push and calculator should open up.
Right-click on the desktop and select New, Text Document. Don't worry about what to name it here because we will be saving as something different later.
In the text file, type: @echo off RUNDLL32.EXE PowrProf.dll,SetSuspendState
  • Lettering is case and space-sensitive!
26318734-bxzhjmonsmllydp0qa2riq2g-2-90.jpg Click File, Save As, Select your C:\ drive, and save the file as hibernate.bat 26318734-bxzhjmonsmllydp0qa2riq2g-2-104.jpg
Oct 19, 2016 | Computers & Internet
My m14x keeps shutting down when i usethe keyboard
Open Control Panel, Power Options, Set to High Performance, Open Advanced Power settings, Set Sleep and Hibernate to Never, adjust other advanced settings to your preference. If this fails to fix, Return it at once while your warranty is valid. After Dell bought Alienware they sort of went south.
Jan 23, 2013 | Dell Alienware M14x (dkfobs15) PC Notebook
My dell Studio laptop takes too long to wake from sleep mode and the monitor just flickers when i try to switch on
If you use Windows 7, u might have hybrid sleep activated. This is similar to hibernate. When u choose SLEEP, your computer goes to hibernate. Sometimes this hibernate just hangs. You have to reboot computer.
Try pressing the power button for several seconds (10-15). It should power off the laptop.
If not, unplug the charger and remove the battery for a few minutes. Then try to start it up again.
May 13, 2011 | Dell Studio 1537 Laptop
Keyboard is unresponsive and locked. NumLock light locked on.
Try unplugging keyboard from computer and plugging it back in. Then restart computer.
Mar 02, 2011 | Dell XPS M1730 Keyboard
Resumes windows from hibenate but the screen is blank
Try this: ( windows 7)
Usning an EXTERNAL USB keyboard, reboot the laptop and enter the
"Restart with low resolution display"
Login as normal
Go to Control panel and change resolution to normal settings
Visit the Dell site and download the latest drivers for the graphics card.
If this does not help, try changing the hibernation settings:
Start / Control panel / Power options/ Hibernation tab/ click to clear the "enable hibernation" box
This wont cure the problem, but it will give you a workaround
Dec 31, 2010 | Dell Inspiron 1525 Notebook
Unresponsive keyboard
Replace the keyboard. They're readily available on ebay. Also, try plugging a usb keyboard in & see if it still happens. If it does then forget replacing the keyboard. Instead you'll be needing a motherboard.
Mar 15, 2010 | Dell Inspiron 1545 Notebook
How do I get a monitor out of hibernation mode? It is not responding and did not reset when I rebooted.
Try using the power button, which usually takes the computer out of hibernation. Also, the mouse and keyboard can sometimes wake the computer from hibernation as well.
If the computer is still stuck in a hibernated state, hold the power button in for about 5 seconds so the computer fully shuts down and power it back on.
Good Luck!
Aug 06, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Keyboard shortcut
use the following keys on the keyboard in a combination..
But make sure the computer is not powered off.. it should be in the standby or hibernating mode...
take care..
Nov 24, 2008 | Dell Inspiron 2650 Notebook
Gateway 7210GX Notebook Logo
163 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
