Question about Sony Handycam DCR-DVD108 DVD Camcorder
Flashing C:13:01 reinsert memory stick
Wont allow me to take photos
  • Anonymous Feb 06, 2009
    I am having the same problem and I am not sure why this is happening. No matter what I do, I can not access the saved images or use the camera. Any suggestions would be greatly appreciated. I guess I will need to buy another memory stick in the meantime.
    Thanks,
    Jack
  • 317 Answers
SOURCE: memory stick for sony cyber-shot
You might try cleaning it with alcohol.
If that doesn't work you'll have to insert the card into a pc and use some kind of data recovery software to do that. I would recommend R-Studio or Get Data Back. Unless you know someone that could do it for you.
Posted on Nov 04, 2007
  • 74 Answers
SOURCE: Reinsert the memory stick...
you will need to re formatt the card and this problem should be solved
Posted on Aug 12, 2008
ginko
  • 19396 Answers
SOURCE: Sony Cyber Shot DSC-H9
If you tried replacing the memory card, removing batteries, and cleaning the contacts already, then it means the memory card socket contacts inside the camera are defective.
Usually this is caused by a bad connector or a bad cold joint on the memory card slot wirings, or on the small pcb board inside the camera.
To fix the problem the camera must be taken apart, the wirings to memory card slot tested for continuity, and the lose contact re-soldered.
If the camera is less than one year old, or still under guaranty, the repair will be covered in complete.
Ask a quote for this job at any repair shop, or call the number listed on the owner manual to get service.
Posted on Oct 02, 2008
  • 411 Answers
SOURCE: reinsert memory stick
contacts of the memory stick clean it
Posted on Mar 01, 2010
SOURCE: Error message: Reinsert the Memory Stick"
The problem is with the memory card. It probably just shorted internally and is no longer useful. The amount of memory is not the problem, as I used a 4GB card for a long time and my card finally went bad. You will just have to get another memory card and MAYBE find someone to be able to retrieve your data.
Posted on Jul 05, 2010
Having taken the memory card out and reinserted it the camera is not showing any photos and keeps telling me to reinsert memory stick with c:13:01 flashing on screen
Not specifying the make and model makes answering this more difficult than it should be.
Luckily, I know that the c:13:01 error is a Sony code because it happens so often! Officially it means that there's a circuit board error, but in practice it usually means that the memory stick has not made good contact with the camera circuitry.
First thing you can try is to simply remove and reinsert the card quickly a good few times, if it doesn't work by the 20th try then it's never going to work that way.
Next, remove the memory stick and use a clean pencil eraser to thoroughly rub the electrical contacts to clean them. Blow away all traces of the rubber. It's vital that the eraser is clean to start with as any traces of conductive graphite can transfer from the eraser onto the contact area and make matters worse.
If that fails then simply try wiggling the memory stick once it's fully inserted. If that fixes it then it's not a very reliable fix and can fail again.
The final option is to dismantle the camera and remove the memory stick drive caddy to clean both the memory stick contacts and the flexible pcb connector contacts. It's not usually easy and risks permanent camera damage, so only do this if the camera is definitely out of warranty as you'll then have nothing to lose in trying. You haven't stated the model so I cannot give you specific model guidance, but if you click this link you'll see a photo guide for one Sony model, courtesy of Digital Photography Review. Once your camera is out of warranty it's value will usually be far lower than the cost of a professional repair, so DIY may be your only choice.
Good luck, and please take a moment to rate my reply.
Mar 07, 2011 | Cameras
I have a memory card that still has memory an my camera is telling me to reinsert the memory stick
Wasn't quite sure what you question was, lemekaralph. Is there nothing said about why the stick should be reinserted? The best idea, based on what I think you're asking, may be to either use a USB card reader or a laptop or PC that has a card reader to load any photos off to a computer and then right click on the stick in the Computer/My Computer Window and click on format. It will clear the card completely and then allow you to put the card into the camera normally.
Make sure you've copied the photos onto the PC if you want to keep them before formatting and, after the stick is accpeted by the camera, reformat it again IN the camera - do that because Sony suggest formatting for best results should be done in the camera.
Good Luck!
Oct 09, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
Memory card has a problem after taking important pictures.. displays reinsert memory stick error and wont read on computer either... any idea if photos can be recovered?
Make sure the memory contacts show up a visible clarity. If there is no detection in any of the card readers, inthe camera and inthe PC, it seems likely that your card has some errors on it,
If the card is detecting the memory but is not showing any pictures, the use a file search in the search mode with the drive selected for pictures/images.
If not it will be best to have it checked with a photo studio to concur the findings since you have important images on it.
Sep 23, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
The pro duo memory stick cannot be used by my camera or read to see the photos
Make sure that contacts are clean on memory stick and reinsert it in camera.
Dues camera show any error sign when memory stick is inserted?
Did you tried memory stick in any other Sony camera?
Let me know to diagnose the problem.
Thanks.
Jul 11, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Reinsert memory stick
Mar 01, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
Aug 09, 2009 | Sony Cybershot DSC-S950 Digital Camera
I have the sony a100 alpha... it wont take a photo. 4 red zeroes
Check the memory stick if its full and delete some photos......then try and take a shot.
the four red zeroes are counters for the number of shots u have taken.....it simply indicates you have a full memory stick.
Mine played the same trick on me too.
Jun 22, 2009 | Sony Alpha DSLR-A100 Digital Camera
SanDisk Memory Stick Pro Duo problem
it may be lost, safely remove your hardware befor you get off from the computer
Nov 02, 2008 | SanDisk 2GB Memory Stick Micro M2 Memory...
Memory card formatting error
Yeah, if you format the memory card, you will lose all data on it. try to scan memory card with updated anti virus software and always use memory card by camera to PC.
Jul 20, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Reinsert Memory Stick Message
i have sony cyber shot keeps saying reinsert memory stick cant veiw any pictures taken nor download cant take any new pictures have i lost all my pictures how can i get them back
May 03, 2007 | Sony Cyber-Shot DSC-T5 Digital Camera
Sony Handycam  DCR-DVD108 DVD Camcorder Logo
329 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
