Question about Sub-Zero 611 / O Bottom Freezer Refrigerator
Cannot open the bottom freezer door anymore; it seems stuck
1. Water is leaking out of the small holes on the back of the fridge; cannot open the bottom freezer door anymore; it seems stuck; temperature of the freezer: 5; fridge: 35. Whats the problem?
  • kajj Dec 20, 2007
    I have the same problem. The freezer will not open. Thus, I cannot take the back panel off as suggested since it is built in. Any other suggestions?
  • Anonymous Mar 16, 2014
    My fridge door was open for an extended period of time while I was cleaning it. Now it has shut itself off. Freezer is working fine. How do I get it to turn back on
    President:
  • 1,462 Answers
Sounds as though the defrost system has failed or the freezer defrost drain is blocked. take off the back panel of the freezer and see if excess ice build up. if so, defrost carefully with a hairdryer. at bottom is a drain. check if blocked with ice and if so melt off with hot water till water flows away freely. if i'm right, appliance will start to work. if fault re-occure then defrost system is at fault
Posted on May 06, 2007
Refrigerator cooling defrost freezer
Buy a freezer thermometer from any supermarket, it has a guide.
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Nov 20, 2013 | Kolpak SK8-818-CI
Freezer not freezing
Oct 30, 2013 | LG LFX25971ST Bottom Freezer French Door...
Freezer is all frozen
One solution:
This can happen if door has been left open. To solve:
Oct 28, 2013 | Samsung RF265AA Bottom Freezer French Door...
Fridgidaire freezer warming up
Sep 09, 2013 | Freezers
Freezer compressor is short cycling
Sep 06, 2013 | Electrolux Refrigerators
Warning light
Aug 04, 2013 | Bosch Classixx KGV28323 Bottom Freezer...
I keep getting water at the bottom of the fridge, under salad boxes on my Hotpoint fridge
Jul 03, 2012 | Hotpoint-Ariston HS3022VL Refrigerator
RED TEMP WARNING LIGHT ON MOTOR RUNNING
I'm sorry to have to tell you that this sounds like a very expensive fault to fix!
Either your fridge/freezer has degassed (lost the refridgerant gas) through a small leak in the pipe system behind or inside the freezer compartment, OR the compressor (what you called the motor) has started to fail.
Either way, these are very expensive repair jobs. It's possible to replace the compressor within about an hour, but if your model is out of guarantee, there will be around a £50/60 Call-out charge and the compressor will cost between £75 and £150 depending on the model.
Alternatively, if the fridge/freezer has lost gas, the engineer would have to try to find the leak - this could be IMPOSSIBLE if the leak is within the pipework inside the back of the fridge or above/below the freezer compartment.
I'm sorry to say that it's looking like you may have to part with a lot of money - or say goodbye to the fridge/freezer you have!
Nov 17, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Have a hotpoint rsf60 fridge/freezer,noticed over temp red light on, defrosted as ice buid up on top shelf of freezer.light still on red temp set at 3/4 ?
The red warning light will not go out?
1. Has the fridge freezer just been
installed? If so, this is normal and the
light will go out when the correct
temperature has been reached.
2. Has the fridge freezer been loaded
with a large quantity of food? If so,
the light will go out when the correct
3. Have the doors been closed
properly?
Jul 01, 2008 | Hotpoint Refrigerators
Refrigerators Logo
858 people viewed this question
Top Sub-Zero Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Archie Ferrarini
Archie Ferrarini
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
