Question about Sharp R-320B Microwave Oven
No power Sharp R-320B Microwave Oven , just quit .......no power ..... tried different outlets and determined the problem is either the power - cord , or the machine .........is there a "reset" button somewhere ? what's the most common cause ? the thing's 10 years old , should i just dump it ? The LEDs don't work either ........ thanks in advance , Willi (408)2478879
  • thinkfasto30 Jan 03, 2009
    trhanks ! that was it !! it works now !!!
    Willi
    Sergeant:
    Champion:
  • 338 Answers
There should be a 20amp fuse that probably blew
Posted on Jan 01, 2009
How do I determine if the fuse is bad on a Frigidare #FMT118EPB Microwave? Thanks.
Michael, if the fuse is bad, it will take out everything on the microwave. You will not have any lights inside or on your display. You can find the fuse inside of the cover by following where your power cord goes into the unit and following usually the black wire to the fuse. Hope this helps!
Dec 04, 2014 | Frigidaire FMT118EPB Microwave Oven
Sharp Carousel Microwave Mdl 1875 for our RV is dead
>> We also tried plugging our toaster into the microwave plug outlet, and the toaster wouldn't work in that outlet, but worked just fine in a different outlet in the RV.
This means the outlet you plug your microwave into needs to be fixed in addition to fixing the oven. Breaker? Fuse?
>> I understand from another RV forum that microwave ovens for RVs have "special circuitry and cooling features" not found in regular countertop ovens for household use.
Not really in my experience. Any microwave supplied with clean AC power and proper venting space will be fine.
But I'd bet your microwave can be fixed affordably.
The main internal things which can result in this model being dead (no display, no light when you open the door, no beep when you press a pad on the keypad) would be the 20A fuse and the magnetron temperature fuse. There could also be bad connections on the noise filter board.
Also, sometimes a power surge can cause the power to be interrupted to the low voltage transformer on the board, and I regularly repair those boards. I can also write a technical statement to your insurance company or to an RV park as needed.
At my Web site, I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The relevant service manuals for this model are here and here.
You can order Sharp parts from Sears or Encompass.
Contact me directly if you need more help.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
Mar 08, 2017 | Sharp R1875: Over the Range Convection...
Sharp Carousel R-7A85 Won't Turn On
Yes! but the fuse went for a reason, the problem could be a bad door switch to a more serious problem.
May 29, 2012 | Sharp R-7A85 Microwave Oven
Where is the reset button located on spacesaver micro wave oven
  • locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
  • Mar 24, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
    No power to microwave
    Hello
    Check the Power Cord
    Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
    Switch the Outlet on
    Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
    Reset the Oven
    Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
    Check the Fuses and Breakers
    See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
    Oct 04, 2011 | Microwave Ovens
    I was cooking mac and cheese and it made a loud noise and just quit working nothing shows up checked breaker and it was fine so was outlet. Sharp R 1470
    Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
    Basic Microwave Oven TroubleshootingTips
    heatman101
    Mar 19, 2011 | Sharp R-1470 Microwave Oven
    I have a sharp carousel over the range microwave oven R-1505LK no power the outlet is ok did lose power to the house and the microwave didnt come back on where is the fuse located
    The fuse is usually located inside the cover near where the power cord enters...
    Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
    Microwave Oven Basic Troubleshooting Tips
    heatman101
    Nov 16, 2010 | Sharp R-1505 Microwave Oven
    Microwave/Convection just quit
    Is this oven new? IF NOT HOW OLD?
    Did you plug the oven into different outlets or try another appliance to make sure the outlets were working?
    Sometimes two or more outlets can be on the same breaker, or on the same GFCI, and if either tripped, the oven of course would not work in either outlet, something to double check.
    If it is new, of course take it back. If not and you prove you have power, there is a fuse in about every microwave I have ever looked in.
    get the manual or download one, and it will tell you where to look for the fuse, it is common for a fuse to blow in these ovens, so more searching is needed before the next step.
    Will
    Jan 04, 2009 | Microwave Ovens
    Microwave Ovens Logo
    162 people viewed this question
    Top Sharp Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
