Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
No wireless light on modem. No remote access for laptop
I set-up a home computer with Centurytel today and everything works fine on the pc. However, the router is not recognized by my laptop as a wireless connection. Also, the wireless light is not on on the modem/router
That will actually turn off the wi-fi you need to open an internet browser tyep in 192.168.1.1 to the address bar click on configuration then wireless select enable from the drop down menu and save it should be on and working now
Posted on Jan 28, 2010
    Scholar:
  • 96 Answers
The wireless side of the router must be disabled. The easiest way to fix that is to do a hard reset of the router. Have a look at the back or base for a "reset" switch ...might be behind a little hole in the case. Press it in for a few seconds and the router should reset to factory. That should re-enable the wireless. If not ...then the router may be faulty.
Posted on Jan 01, 2009
Please I cannot connected to internet
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards in all the laptops/computers needs to be configured withthese router's wireless settings. Then the laptops/desktop computers cancommunicate with your wireless router and access the Internet via the DSL or cable modem.
May 26, 2011 | Computers & Internet
My daughter works at home as a Customer Service Rep. for Generation Networks (Ancestor.com). She has a terminal from work and it is configured for her to work from home. She has done that for over a year...
This is only a problem with the firmware of your modem/router that you need to update it, because a network device like a modem and router that is working fine for severla years and suddenly stop working you just need to update the firmware of it and it should be working fine again, to update the firmware of the modem/router just need to call the manufacturer for that....
Hope that helps.........
Oct 05, 2008 | Computers & Internet
I use an AT&T 2Wire 2701HG-B Gateway Modem and whenever I use the laptop wireless option, the modem tends to repeatedly reset itself, affecting internet use both on the laptop and a home computer which...
http://www.fixya.com/support/t4987959-att_2wire_wireless_router_keeps
Here is a solution I posted today for a similar issue. Might fix your problem.
Jan 13, 2011 | Computers & Internet
No internet through router
you should refer to your ISP or to the Router manufacturer on how to access the GUI of the router. problem could be both devices are using same IP. there is a collission issue there. you should change the gateway IP to one of your devices.
Apr 01, 2010 | Linksys Wireless-G WRT54GS Router...
I have a dsl modem and an actiontec gt701-wg gateway
Yes this is a normal method to setup a wireless network.
To set-up and secure the wireless router from unauthorized access, follow these steps :-
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 31, 2009 | Actiontec (GT701) Modem
The router is running fine all hook ups are fine changed the wireless card took that to a computer place and it was running fine at the shop when I got the pc home unable to access the internet even though...
The cable internet is not "seeing" the computer. The router is blocking it. That is why it works if you plug it into the modem directly. How to solve this is to turn everything off and unplug power to modems and routers for 3-5 minutes. Then replug in routers. Then restart computers.
That is why it worked at the computer store. Everything was shut down and restarted.
Also, sometimes it is necessary to call the ISP (for example Comcast) and have them re-send the signal. Also going to Control Panel Network Connections and choose "repair the connection" will reset the signal.
Be patient it will work.
Aug 15, 2009 | NetGear RangeMax WPN824 Wireless Router...
My laptop shows full signal but refuses to connect to the router. The wireless phone rang two days ago and knocked me offline on wireless. Can someone please help? Nobody else's wireless device works...
It sounds like the wireless setup in the router may have gotten corrupted. From the wired PC, using a browser type 192.168.2.1 to access the router. It will ask you for a password. The default is to leave it blank. If you've set one, you'll need to give it the one you set. That'll get you into the router. Check the wireless setup. Everything else should be ok, or you wouldn't be able to access the internet from your wired PC.
If you can't find anything wrong, you can try rebooting the router and the modem. Shut both down as well as your wired PC. Wait 30 seconds. Boot the modem, the router and the PC at 30 second intervals.
Jun 11, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Orange blink of death!!!
Hello houng_lee,
I have the exact same modem, if the modem/router light is blinking, that indicates a problem with the modem. You indicate that you have internet connectivety, so you should have modem light solid blue. When you look at the Wireless light it's probably off. Which means that at this point you have internet connectivety, you should put the cd in and run through the wireless connection wizard on the CD. It will check to see 1) if you have internet connection, 2) the type of connection you have (comcast) 3) if you have any wireless devices to be hooked up. 4) That all connections are working properly.
If you have a laptop that you want to connect to the wireless router, have it next to the router, so once you've finished setting up your Wireless security and issing a WEP number for local access, you can test your setting immediately with the Laptop. I always suggest that you create a WEP number for securty reason, If you perfer not to create a WEP number, and leave it as an open access (which is fine, and easier to setup) make sure that you shut off broadcasting, So your neigborhood doesn't jump online once they see an open access router.
If you've tried these steps let me know what problems your getting during the wizard setup. It will tell you if everything is setup correctly, or their is an error. Right now, I think the problem is your setup, and it's not communicating correctly. But, the wizard will tell you that as well.
Let me know,
Good Luck
Mark
Feb 17, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Cannot access internet with a linksys router
Make sure DHCP is turned off on the modem or else you will get ip conflicts. Also make sure it is plugged into the wan port on the router
Jan 15, 2009 | Linksys Wireless-N WRT150N Router
Trouble setting up work laptop to use Internet thru home computer
Do you have any firewall installed on your computer?
If so, try disabling it. If it doesnt work, keep going.
does your modem have a green light on the "internet" or "activity" status? if not, you have a problem in your modem.
hope it helps.
Aug 07, 2008 | Belkin (F5D7132) 802.11b/g Wireless Access...
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
91 people viewed this question
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
arnold balmaceda
arnold balmaceda
Level 1 Expert
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
