Question about Sony PS2 Dual Shock 2 Controller (PrePlayed) (PS2PRSODUSH2)
My PS2 controller's L3 analog stick is broken.
My PS2 controller's L3 analog stick spins around when i twist it and it makes a snapping sound when i push it forward or backwards. It also doesn't let me steer or walk on games. How do i fix this?
  • Anonymous Apr 19, 2009
  • Anonymous May 09, 2009
    i have the same problem i have a pelican controler one time i got mad and pushed real hard then it kinda worked
    Scholar:
  • 118 Answers
I think I know exactly why. I bet you have a Pelican controller huh? Those analogs wear out after a while. You need to go buy another one, lol, sorry. They are only 10 bucks. Please rate!
Posted on Jan 31, 2009
Hi, I just put a 5mm LED inside my dualshock 3, behind the ps button, but now when I connect it to my ps3 the left analog stick is always pointing left. so on menus it will always scroll left. I dont know...
You just have to keep pushing down on the top of the stick and releasing it,like the PS2 had L3 and rolling it around.I get that with PS2 controller.I basically just go spastic on it for about 10 seconds and it stops.Do you know what I mean?Push down on the knob,not literally in the down direction.If you have questions,just reply.
Jul 18, 2010 | Sony Dual Shock 3 Controller for...
I'm looking for the L3 on the controller. I have
Hi a lot pf people get confused over this button but you know the two thumb controls that you can turn in all directions the round controls well you can press these down the left ball is L3 and the right ball is R3 so press the ball down and thats the button your looking for.
Jul 10, 2010 | Sony PS2 Dual Shock 2 Controller...
I bought a Sims 2 pet CD for PS2 and I need a manual to play.
The Sims 2: Pets
GAMEPLAY CONTROLS
Directional Buttons Up = Motives. Down = Wants and Aspirations. Left = Quick Text. Wants of Nearest Pet. Right = Relationships.
X Button Select. Action.
Triangle Button Cancel. Close Menu.
Square Button Pan Camera (Hold)
Circle Button Snap Camera to Sim
L2 Button Sim Switcher Menu (Hold)
L1 Button Freeze. Fast-Forward.
R2 Button Toggle Walls On/Off
R1 Button Freeze. Fast-Forward.
Start Button Pause
Select Button Toggle Control Mode
Left analog stick (L3 Button when pressed down) Move
Right analog stick (R3 Button when pressed down) Zoom. Rotate Camera.
PLACEMENT MODE/GRAB MODE CONTROLS
X Button Place or Grab Object
Triangle Button Cancel. Back.
Square Button Remove Object and Put In Inventory
Circle Button Toggle Blueprint Mode
L2 Button Clone
L1 Button Rotate
R2 Button Undo/Redo
R1 Button Rotate
BUILD/REMOVE MODE CONTROLS
X Button Place/Remove Wall, Wallpaper, or Floor
L2 Button Clone Wallpaper or Floor
R2 Button Undo/Redo
Combo #1 L1 Button or R1 Button + X = Build or Fill Room
Combo #2 L1 Button or R1 Button + X = Remove or Uncover Room (In Remove Mode)
acquired from (Gamefly.com)
Jul 06, 2009 | EA - Electronic Arts The Sims 2 Pets for...
Right analog stick not working
Check the controls on the game's control section. If you play another game that uses the right analog control and it works on that game then it's the control set up for FIFA. Make sure that the analog control light is on when the game boots up. Sometimes if the analog control light is not on when you turn the game on and you turn it on afterwards, the analog stick controls don't work properly. That happened to me on NFS Pro Street. If this helped you leave feedback please. FIXYA!
Feb 19, 2009 | Sony PS2 Dual Shock 2 Controller...
Ps2 dual shock2 controller buttons not working
Removed accumulated dust sticking on the board were the buttons touches.use cotton balls with alcohol or use clean damp cloth.If nothing's happen check the cord I'm sure it is twisted badly, open your ps2 use this controller and try to twist back the twisted cord if it stopped sometimes when your twisting it then you have to replaced the cord(make sure that your using the original ps2 controller not imitation)pls. rate
Jan 17, 2009 | Sony PS2 Dual Shock 2 Controller...
Can't connect nerf ps2 controller to its receiver.
the L3 button is Left thumstick pressed inward
R3 is right thumstick pressed inward ;P
pls rate .
Dec 16, 2008 | Pelikan Performance Designed Products...
My dualshock 2 controllers analog are very hard. how to fix it
Hi warren111,
When you say hard, did you mean the controllers analog stick is very "stiff" or loose to the point that you can't move the characters onscreen or the characters move involuntarily. If this is your case then you may have to try another PS2 dualshock 2 analog controller in your PS2, If the problem doesn't happen with another controller, then you may consider buying a new PS2 dualshock 2 analog controller since most likely the controller is already defective.
Also try other games, see if the problem only happens with a particular game. If it does then you will have to check the settings of the game, and see if you can adjust the settings of the buttons or analog stick.
If the problem you're having is more with the "comfort" of the controller you're using then you should consider looking at 3rd party controllers for the PS2. One company that makes them is Logitech, they have a line controllers that work for the PS2 there are other companies so check out gaming sites to get reviews on them. But I would suggest though that if you're shopping for a controller because of this reason, you should try to test the controller out in a game shop first. So that you can get a feel of it before buying. If you like the controller and you're comfortable with it then tha's the time you buy it.
Hope this helps!
Peace! :)
Oct 22, 2008 | Sony PS2 Dual Shock 2 Controller...
L3 and R3 problems
L3 and R3 r yr analog buttons just simply push down on them
Oct 01, 2007 | Sony PlayStation 2 (PS2) Console
Sony PS2 Dual Shock 2 Controller (PrePlayed) (PS2PRSODUSH2) Logo
1,859 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
