Question about Acer Aspire 7520-5757 Notebook
Wireless internet connection
Everytime I need to restart...or start up my laptop...the internet connects for a moment and then I lose the connection. It says its not connected to a network and when I try to connect to a network...it says there are none available. I get my wireless internet through my fathers d-link. However...the odd time..if I'm quick enough sign into msn or something online, and I play music from my music file, it will stay connected. I also lose my connection and have to start all over again if my laptop hibernates. I end up haveing to play music on repeat with the mute on to avoid losing my connection.
My e6400 laptop with dell 1510 wireless minicard sees networks via netgear dg834gt router but will not connect. I have changed channels, updated drivers, checked diagnostics on card, played with settings...
Power on the laptop computer and wait for the operating system to boot. Right-click the wireless Internet icon in the lower right corner of the desktop. This brings up a new pull-down menu. Select "View Available Wireless Networks." This brings up a selection of different possible Internet connections that are in range of the computer. Select the wireless Internet connection you want to use. If a password is required, you need to type it in now. Wait for the laptop to connect to the Internet. In a moment the computer is going to state it has successfully connected to the Internet. click Start, Run type in cmd and click Ok to bring up a command prompt. Type ipconfig /all and press enter and see if it gives you an IP address similar to 192.168.1.100. Check your wireless connection properties under My Network Places. Right click the wireless connection icon and choose properties. From there make sure Internet Protocol {TCP/IP} is listed, highlight it and click properties. Make sure Obtain an IP address automatically is checked and Obtain DNS server address automatically is checked. Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled if still no joy Let's first try to start the wireless service i.e. WLAN AutoConfig service manually. To do this, login to the computer as an administrator.
1. Click Start, type services.msc and hit enter.
2. Locate WLAN AutoConfig service, double click on it to open its properties window.
3. Under General tab, change the Startup type to Automatic and click Start button.
4. Click Apply and then ok. For more information about the wireless settings, check this link: http://technet.microsoft.com/en-us/library/bb878035.aspx Hope this helps.
Jan 19, 2013 | Dell Latitude E6400 Laptop
Tip
How to connect to always automatically connect to your SSID
Ever turn on your computer and try to connect to the internet? Ever see all the many SSIDs in your neighborhood listed in your wireless radar or your "Windows Wireless Connection". Then you'd scroll down to double click on your SSID so that you can connect to the internet. Imagine doing this everytime you have to connect to the internet. Wouldn't that be annoying?
The Objective
The objective of this Tip/How-To is to have you turn on your computer and connect to the internet automatically via your SSID (Wireless Network Name). Hence, you wouldn't need to manually find your SSID everytime you need to connect to the internet.
Pre-requisites or Must haves for this Tip to work
  1. A computer with a wireless adapter
  2. A wireless router
  3. An active internet service
  4. This tip is designed for Windows XP. I will post one up for Windows Vista and Windows 7.
  5. This tip is designed to work with Wireless Networks (SSID) that do not have any passwords or encryption.
Active Tip Dictionary (throughout this TIP)
SSID
is the technical term for your broadcasted network name. This is basically what you will see listed in your WIRELESS NETWORK CONNECTIONS manager.
To make your computer connect automatically to the internet via your SSID, we will need to manually tell your computer to connect to your SSID and then we will need to save this setting so that your computer will automatically connect to your SSID everytime you turn on your computer.
Let's Begin.
Start your computer by turning it on.
Click on your Start Button.
Move your mouse over to Control Panel and then left click on it.
Double click on the Network Connections icon.
Double click on Wireless Connection. Now in the picture above you see Wireless Connection 3 but on your screen you should see Wireless Connection.
Now click on Properties.
Click on the Wireless Networks Tab.
Now scroll up and down under Preferred networks until you find your Wireless Network Name (SSID). For me, it's called linksys therefore I will select linksys.
Now click on the Connection tab.
Under Automatic connection, click to check "Connect when this network is in range". This will tell your computer to connect automatically to your Wireless Network Name (SSID).
Click OK to save this setting.
Click OK again to get out of the Properties window.
Click OK again to get out of the Wireless Connections window.
Then click Close to close out of the Wireless Connections window.
And there you have it, you have setup to automatically connect to your Wireless Network (SSID) everytime you turn on your computer.
Now restart your computer and give it a few seconds, and voila, you are automatically connecting to your Wireless Network (SSID). Now you can surf the internet. You can set this on all your computers at home that have a wireless card.
Remember to give me a good rating and vote for me. If you require further tips and tricks, feel free to contact me through the contact box. I will post up your tip.
on Apr 05, 2010 | Computers & Internet
I wold like to use wireless my laptop
Jan 16, 2013 | HP Pavilion Computers & Internet
Theres a red x on my wireless icon on my laptop
The red x means you have no internet connection.
Jan 05, 2013 | Acer Computers & Internet
Having problems connect my child DSXL to the Internet please advise
This will get you a wireless connection to the internet if you have the approprite internet wireless modem.
if still no joy
Hope this helps.
Nov 27, 2012 | Computers & Internet
Cannot get wireless service
if still no joy
hope this helps
Sep 15, 2012 | Computers & Internet
I have a wireless connectivity issue from my laptop. When the power cable is connected, the internet works. When I disconnect the power cord, I am disconnected from the internet. This problem has only...
I would say you need a new battery, if when you disconnect the charger your losing your wireless connection, you need more power to hold the wireless connection or that make sure when you remove your charger press your wireless button near your volume control on laptop to make sure its on, blue, not off red ok
Jun 29, 2009 | Acer Aspire 3680 Laptop
Can't get Acer Aspire One on my house wireless net to share files
Make sure the firewall software on the acer allows the wireless connections, try turning the firewall off for a moment and also disable the wired connection.
Make sure the network is safe or allowed most likely firewall blocking.
Mar 08, 2009 | Acer Aspire One Netbook 8.9" Notebook
Having problems with wireless connection.
you are connecting through what adsl router then you have to configure the router
Oct 01, 2008 | ASUS Computers & Internet
My computer experience errors, suddenly hangs up, freezes whenever i do video calls..
This may not be with the computer, it could be with your internet provider. If you have a bad or unstable internet connection, then a minor glitch or quick loss of connectivity will cause you to lose the call, even if the glitch is almost unnoticeable. If connected wirelessly, then try a cable and hardwire directly to the net, a wireless glitch could do the same.
Aug 02, 2008 | Dell XPS M1330 Notebook
Acer Aspire 7520-5757 Notebook Logo
97 people viewed this question
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
