Question about Audiovox D1708ES Car DVD Player
Skipping problem We actually have a model similar to this (PVS69701). It had started skipping when hitting a bump in the road, but now it even skips when we are parked. We have tried a DVD player cleaner and have tried numerous brand new DVD's in it, so we know it's not the DVD itself. Any ideas what we can try next?
  • Jim Jr Nov 24, 2007
    Similar problem here. Audiovox PVS69701 from Target restarts about 3-5 minutes into every DVD movie we play. Suggestions?
The problem is likely due to the "door closed" switch not engaging properly. To get better engagement, superglue a tiny piece of a credit card to the tab located in the lower lh corner near the DVD when the player is open. This is opposite of a portrusion that presses the tab down whne the unit is closed. The unit is restarting because it thiks it is being opened due to the switch not sidengaging from time to time.
Posted on Dec 30, 2007
Hi, I just need to know how to thread this machine properly or, where can I get a manual please?
Search the internet for:
Make + Model + the word "Manual"
or contact manufacturer support. Most machines are threaded similarly, so even if you can't find a manual for your model, a manual for a model similar to yours will be helpful.
You can also search YouTube videos for threading instructions.
When threading, be sure to always raise the presser foot during the upper threading process. This releases the tension disk and allows the thread to seat properly.
For skipped stitches, try installing a brand new needle.
What to Do If Your Sewing Machine Is Skipping Stitches
10 reasons for skipped stitches
Basic Maintenance Tension Skipped Stitches
May 19, 2016 | Sewing Machines
Cd player skips
CD disk bad. (audio disc bad or scratched)
or CD dont really support disk media format , is this a CDDA or MP3
some early MP3 disc drives do MP3 very poorly
or skips when you hit bumps in the road.
only that disc skips.?
Dec 23, 2013 | 2005 Toyota Sienna LE
CD skipping
That's normal in most cars!
Jan 22, 2013 | Mazda RX-8 Cars & Trucks
I have a Dynamic D600 in an '09 Ford F150. Whenever it hit a rough spot in the road, the green light will stay on but the amp will quit playing. I can reach back and tap the amp with my hand and...
are you playing CDs while this happens?
ill bet your CD is skipping on bumps.
play your radio or ipod input and run some rough roads...ill bet your 'pause' goes away.
May 05, 2011 | SPL Dynamics Car Audio & Video
Car cd player skips on bumps
This can happen for several different reasons.
1. The dampers (oil filled shock absorbers) are leaking and need to be replaced. You can check this by taking the unit out and opening it up and then remove the CD deck. In each corner of the CD deck you will see a small rubber looking device that the internal mech floats on when a disc is engaged. It is attached to the internal mech by only a small metal peg. Check each corner for these. Make sure they are not leaking anything. It is usually a white looking substance that feels like grease. Ant time even one of them go bad or get popped out of place, it will skip on every bump.
2. Try cleaning the lens. Sometimes a dirty lens will make the CD player skip much easier than it is supposed skip. You can buy a cleaning disc at most retail outlets that sell CD and DVD players. Run it as directed in the instructions.
3. one or more springs are streched out a little. These mechs have many springs in them and if one is a little streched it will cause skipping. If you find a loose spring, it will need to be replaced.
4. Weak laser output. A weak laser will also cause a unit to skip. If this is the case the laser pick up will need to be replaced. There is no fix for a weak laser other than replacing it.
5. Spindle motor problems. A spindle motor with even a tiny bit of oxidation in the windings can cause skipping when you hit a bump.
There are also a few other things that can cause this same issue. It is not an easy thing to fix without some training on this type of equipment.
Is this an "Aiwa"  or is this a factory unit that cmae with the car when it was brand new. I don't think that Aiwa is an OEM radio, but I could be wrong. I fix aftermarket radios only.  So I am not real familiar with all the OEM models.
If this is an aftermarket Aiwa radio, you should take it to a service center to get an estimate. If it is an OEM radio, it is most likely going to be very expensive to fix and a good aftermarket radio would really serve you better.
I am sorry if this is not the answer you were hoping to get, but it is the truth so I hope you will not punish the messanger for bringing bad news.
Anything less than a "helpful" rating is a very bad rating meaning that you got no help or that the help was not related to the problem. I spent a lot of time putting this information out here for you for free, so I only ask that I get a decent rating for my trouble.
If you require any more help feel free to post another comment on this thread with any questions you may have. I will be happy to answer them for you.
Dave
Jan 22, 2009 | Aiwa CDC-X227 CD Player
JVC KD-SH99 Skipping
try cleaning the lazer lens, also remember it is old and is most likly toast., the longest I ever owned a deck that didnt go out was 4 years.
Nov 12, 2007 | JVC KD-SH99 CD Player
Skipping tracks
Did your music subscription service expire? That would cause it to read every song as zero. Definitely try the rest method first. Disable auto-synchronization feature for all programs that you sync the device to.
Oct 15, 2007 | Apple iPod nano
Car cd player kipping
Is it anti-skip resistance? If not some players have hard problems playing when heavy bumps. Also is it installed correctly? Was all shipping plugs taken out?
Sep 10, 2007 | Aiwa CDC-X227 CD Player
Audiovox D1708ES Car DVD Player Logo
291 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Marvin
Marvin
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
