Question about Dell Inspiron 6000 Notebook
My daughter was on my dell inspiron 1501 laptop, all fine, i asked to use it for 5 minutes, i unplugged it from the adapter and used it in another room, i returned it still on my daughter plugged it back in, in front of me and as she plugged it in the whole screen went black the thing went dead. now nothing, no lights at all What do i do?
  • Anonymous Jan 18, 2009
    one day i turned on my dell inspiron 1501 and half of the screen was black and is still is can some one please tell me how to fix this problem...
  • Tom Arsenault
    Tom Arsenault May 11, 2010
    How long did you wait to see if it reboots?I know my battery is messed up and if I use my laptop without ac it dies in about 5 min. Screen goes black, cant do anything. Let it charge up and it will work.
    Hope you have the same luck.
    Tom
    Sergeant:
    Champion:
  • 357 Answers
For the first problem, try reseating the memory and the battery, see if any thing happens if you leave the battery out and plugged in using the AC adapter only.
Good Luck.
For the second problem, try removing the battery for about 10 minutes then after installing the battery power up and see if the display if full again, if so grate, if not, you will probably need to have a tech fix it, as either the display is bad or maybe the connector inside the laptop became loose and should only be repaired by a qualified technician.
Good Luck.
Posted on Mar 09, 2009
Dell inspiron 1520 won't turn on.
Remove the battery from its compartment on the side of your Dell Inspiron laptop computer.
Remove the power adapter from its plug on the side of the Dell Inspiron (if your laptop is currently plugged into a wall outlet).
Press down and hold the "Power" button on the laptop for one to two minutes. This will dispel the excess electrical current that is built up inside the laptop.
Put the battery back inside the compartment of your Dell Inspiron.
Plug your power adapter back into the side of the Dell Inspiron. Press "Power." Your laptop computer will now turn on.
hope this helps
Oct 08, 2012 | Dell Inspiron 1420 1501 1520 1521 1525...
I am using a Dell Laptop and it is inspiron 1501. But its battery is not charging. I get 2 error message the adapter can not recognise... The battery can not recogise.. Something like that. The laptop gets...
try to remove the battery from the computer, after unplugging it, plug in the AC adapter without the battery and check if it will turn on. if it doesnt then 2 possible reason
1. the AC adapter is busted, you can try a known good Dell AC adapter. if its still now working with a know good AC adapter then
2. its the motherboard that needs to be replaced.
Hope this help
May 19, 2010 | Dell Inspiron 1501 Notebook
Dell 1501 Error- AC Adapter is not recognized
myabe the battery is faulty have you tried replacing it?
Sep 07, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 will not boot with battery or adapter
Take the battery out and try with AC only, if no change, then you will likely need a motherboard replacement
Jun 04, 2009 | Dell Inspiron 1501 PC Notebook
Hi, my daughter has a dell inspiron 1501 used from my sister. and well it was working fine . then we did not have it on for while and now when it comes on asking for the password it doesnt work. we use all...
When your computer boots and the login screen appears press control(ctrl) + alt + delete twice. This will bring up a window asking you for your username and password.
Type "administrator" without the quotes as the username and leave the password field blank. Press OK.
When you are logged in as an administrator change the password for your old username using control panel>user accounts.
If this doesn't work then you need to reset the administrator password. Visit this link -> >LINK<
Mar 08, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Feb 01, 2009 | Dell Inspiron 1501 Notebook
My daughter was on my dell inspiron 1501 laptop, all fine, i asked to use it for 5 minutes, i unplugged it from the adapter and used it in another room, i returned it still on my daughter plugged it back...
The inspiron has known issues with overheating and heatsink fan issues.. Contact dell tech support if under warranty or just buy a new motherboard cause yours is probably dead now.
Jan 18, 2009 | Dell Inspiron 1501 Notebook
Replacement battery for Dell Inspiron 1501 won't charge
If your old battery was doing the same (not charging), then is is because the charger is not charging the battery. Do you have a friend with a Dell laptop? Maybe you can use a borrowed charger to test and see if it will charge the batteries. To answer your question , no Dell does not have anything built in to prevent you from using a 3rd party battery.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 28, 2008 | Dell Inspiron 1501 Notebook
Dell inspiron 1501 wonnect wireless network?
inspiron 1501..the DVD no play more.write
Dell Inspiron 6000 Notebook Logo
44 people viewed this question
Alun Cox
