Question about Garmin eTrex Legend GPS Receiver
GPS Coordinate Conversion
The GPS coordinates on Google Earth are not the same format as the ones my Lowrance GPS uses. How do I convert from the Google format?
Just take the last 2 pairs of numbers and divide them by 6.
Example if it is 37 38 it would then be 623.
Posted on May 01, 2009
  • Garmin Master
  • 638 Answers
Http://www.fixya.com/support/t1466333-convert_gps_coordinates_from_google
Posted on Jan 07, 2009
Can gps coordinates be used with TomTom go live 750
If you mean, can you enter latitude and longitude coordinates on your GO 750 LIVE GPS device .... yes.
First you'll want to set your unit to accept coordinates. From the main menu, tap Change Preference, then select "Set Units" and select a Latitude and Longitude format in the "Coordinate display" screen, and then tap Done.
To navigate to a location using latitude and longitude coordinates, follow the steps below:
  1. From the Main menu, tap Navigate to...
  2. Tap Latitude Longitude.
  3. Enter the coordinates and tap OK.
May 09, 2013 | Tomtom GO 750 LIVE GPS Receiver
How to find a position from GPS coordinates?
If you know the proper geographic coordinates of your destination, You can easily navigate around your destination using the longitude and latitude coordinates or other coordinate formats.
  1. Touch WHERE TO on the screen,
  2. Touch COORDINATES from the list,
  3. Touch FORMAT to change type of coordinates. Because different maps and charts use different position formats, the nuvi allows you to select the correct coordinate format for the type of map you are using,
  4. Enter the coordinates and touch DONE.
That is how you find a position using the coordinates, but you have to be very familiar with coordinates to be able to use it.
Complements of the season to you over there.
Dec 25, 2010 | Garmin GPS
How do you enter coordinant into GPS to find a
the 1212 will not do what you want it to do...its just not capable of taking longitude and latitude.you can get copy of your manual for your 1212 here
.probably the easiest way around this problem, is to get the address somehow (was there a phone number provided with the rv location list)
if you know the approximate location, you can use google maps to zoom in and get a street address
google maps here
you could also use google earth if you have it..if not, you can get it here very cool even if youll only use it once.
you can enter longitude and latitude in google earth
let me know if you need more help
good luck
May 05, 2010 | GPS
Consistent error entering garmin etrex coordinate in google earth
Consistent errors are usually projection or datum related. If you are taking coordinates collected in one projection and displaying them in your GPS in another, you the points will offset. I'm not talking about the decimal degrees 00.000n 000.0000w vs 00 00 00N 00 00 00W. I'm talking about the geographic model to represent the surface of the earth. Google Earth generally uses a geographic projection with WGS 1984 or WGS84 Datum. Make sure you are using the same settings on your GPS.
Apr 09, 2010 | Garmin eTrex Legend GPS Receiver
TI-84 has problems converting between rectangular and polar. is there a fix for this?
The conversion from rectangular to polar coordinates requires the calculation of an angle . If the angle unit that the calculator is configured for is different from the one you have in mind, you get (not erroneous results) but unexpected ones.
If the angle unit under [MODE] is radian, the angle you get in the conversion is in radians. Similarly, if the angle unit is degree, the angle obtained after coordinate conversion is in degrees.
Check your angle unit and restart your calculations.
Feb 19, 2010 | Texas Instruments TI-84 Plus Calculator
How do I convert the gps coordinates from Google Earth?
In GoogleEarth, change your coordinates to decimal format. In your Lowrance GPS, change that format to decimal. You don't mention which Lowrance model so I can't find the online manual to tell you exactly how to do it.
Jan 01, 2009 | Garmin eTrex Legend GPS Receiver
ETrex Legend, GPS Coordinates from Google Earth Don't Match Basemap
Are you sure you're using the exact same format on GoogleEarth and your GPS?
GoogleEarth: save the waypoints in a KML file (NOT KMZ) to your computer, naming it appropriately.
Go to http://www.gpsvisualizer.com/gpsbabel/ and convert the KML file to a GPX file, using their converter. They will present you with a file to download. Download it and send those waypoints to your unit and you'll be set to go.
Apr 01, 2008 | Garmin eTrex Legend GPS Receiver
Loading gps marks e Trex hand held yellow
Your manual tells you how to enter waypoints
http://www.fixya.com/support/p237226-garmin_etrex_gps_receiver/manual-14514/page-16
Mar 29, 2008 | Garmin eTrex GPS Receiver
Converting GPS coordinated to google earth coordinates
Feb 10, 2008 | Garmin eTrex Legend GPS Receiver
Garmin eTrex Legend GPS Receiver Logo
615 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
