Question about Sharp Televison & Video
LC-65D64U lcd screen is broken and want to buy a replacement!
I cracked my 65" lcd screen and want to buy a replacement
Agent Aaron
  • 265 Answers
SOURCE: 65in sony cracked screen
Hey stone777,
While damaged TV screens can generally be replaced, the cost to replace one can sometimes be cost-prohibitive. I would suggest that you first contact Sony directly to see if the company has the part available separately or as an assembly only. The difference in price between any individual component and any assembly that it is included in can be quite significant.
Keep in mind though that in some cases, manufacturers may not even provide the screen for purchase if the cost of the replacement part exceeds the current market value of the TV itself.
Another option you might be able to pursue is to contact an independent TV or electronics repair company to see if they would have this part available from another salvaged unit, especially if you don’t have a preference if the part is an original equipment manufacturer (OEM) part, has been rebuilt or is an aftermarket part.
Please remember though that it's generally best to have a manufacturer-authorized repair technician perform any repair that you are unfamiliar with, in order to minimize the risks of injury and damage to personal property.
If you would like, you may also always contact your local Best Buy™ store for more information on how to obtain repair estimates and part replacement. Remember that there would be fees for any such service (diagnostic and trip charges), in addition to any labor/part costs involved.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Posted on May 27, 2008
  • 33 Answers
SOURCE: LC-65D64U Sharp Aquos
Call sharp back again and tell them you first want to register for aquos advantage program, which is free. By doing that your service will go much quicker with them. You then tell them that you want to get set up for service. They will have one of their authorized professionals come and fix your tv in a matter of days. If their tech cannot fix it, they will replace your tv free of charge as long as you are within your warranty.
Posted on Dec 12, 2008
SOURCE: how to replace a broken lcd screen
see the nokia e65 de-assembly video here.
http://www.youtube.com/watch?v=No2KPrG_QuM
Posted on Mar 02, 2009
SOURCE: Replacing Cracked Screen LC-46D62U W/ One From LC-46D64U
yes it will work. you can take it apart and then get the screen out and put it in.
Posted on Apr 02, 2009
  • 3 Answers
SOURCE: need to replace broken lcd screen
http://www.formymobile.co.uk/kc910disassembly.php
Posted on Aug 17, 2009
The upper left quadrant of my Sharp Aquos LC-65D64U does not display.
Check the connections of the flat cables that connects the T'Con board to LCD pane for any loose contact. Re-seat them. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or make a search by type in the brand name of the device in the "Search Box", at the top right of the display window.
Dec 05, 2012 | Sharp Aquos 65" LC-65D64U LCD TV
Sharp Loud popping noise tv
The power supply regulator board should be replaced as card basis.
Aug 20, 2012 | Sharp Aquos 65" LC-65D64U LCD TV
The screen behind the first screen is cracked
The first screen is a protective layer if the screen behind it is broken you have a broken LCD panel.
You can replace it but is generally cost prohibitive.
Thanks
Dustin
Jan 05, 2011 | Sharp LC-32SB24U 32 in. LCD TV
My TV LCD Sharp LC-65D64U had no power ON/OFF, the Power LED blinking, Could you let me know what is the problem?
Hello
This fault on that TV was with its power supply that feeds the LCD screen drive. The unit knows if it hasn't got an ouput to the screen from the power supply and flashes to indicate the problem. I'd suggest to try unplugging and leaving for 10 minutes before trying again. Then see if you can get any menu functions to appear as you trun it on.
However, then it'll need repairing by qulified technician.
Good luck
Dec 24, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Considering buying a used 46'' sharp aquos lcd tv/ mode # LC-46e77u, but the screen is cracked and now needing to know the cost of replacing the screen
Don't buy this tv.The tv LCD screen broken,the tv is junk now,not worth as a whole tv anymore.The replacement of the LCD screen,will cost the same as a new tv.The tv LCD screen panels are limited produced,by the tvs corporation.Will cost the same as a new tv,if require changing the LCD screen panel.
Sep 06, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Which update is good for LC-65D64U
What are you looking to up-date on your sharp?
Oct 10, 2009 | Sharp LC65D64U 65 in. LCD TV
Oct 07, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I'm curious if getting a replacement lcd panel for a 46" TV is not a problem, how difficult is it to replace it yourself. That is remove a cracked one and replace it with a new one.
Jan 03, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Samsung HD 32" lcd tv
Sadly there is no repair for the damaged screen and trying to replace it may be as much as buying a new one this is because the screen is one of the main components but I recommend you check with your local TV repair man some one should give you a good price keep in mind that this repair should not exceed 65% of the current value of the TV, that is already to much.
Aug 27, 2007 | Sharp Aquos LC-15B4U-s 15 in. EDTV-Ready...
Televison & Video Logo
114 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
