Question about Whirlpool LXR9445JT Top Load Washer
Two part question, two part solution (I hope). First the Whirlpool, most of the drain problems I have encountered with the Whirlpool top loaders can be attributed to a few things: 1. Defective Lid Switch - washer will fill normally, but will stop suddenly when it begins to agitate. The tub will remain filled with water and will not drain. Cost: about $30. 2. Defective Motor Coupling - Since you mentioned washing a blanket, heavier loads can put some wear and tear on the motor coupling, and wear them out. The couplings from the manufacturer are usually comprised of all of plastic and have been known to strip. After market couplers have a steel grommet in the center to prevent this. Symptoms: Washer will fill, but will not agitate. You will hear a loud rattling noise during the wash cycle with the drum remaining still. The tub will still drain sometimes, but won't spin. Cost: about $15 3. Clogged Drain Pump - Located inside the machine under the wash tub in the front. The pump is small (white of gray plastic) with two hoses connected to it. The pump does not come apart, so you will have to remove the hoses to inspect inside. If your tub is full of water, however, a wet/dry shop-vac will come in handy to remove the water, FIRST!. Symptoms: Washer will fill and agitate, but will not drain during the rinse or spin cycle. If clogged, severely, the pump shaft connecting to the drive motor will strip and the pump will need to be replaced. Cost: about $40. Now...the Kenmore. Fill problems where the water does not shut off are usually attributed to a bad pressure switch. The pressure switch would be the load level selector on the console. Before you call the switch bad and order a new one, however, inspect the clear plastic hose from the switch all the way to the bottom of the wash tub. This is known as an "air-dome" hose and sometimes will crack or develop holes in them. If the air is allowed to escape from the hose, the air pressure will never be substantial enough to shut the pressure switch off. It may be an easy fix of just replacing a rubber hose. Good luck and I hope this helps you.
Posted on May 06, 2007
Jul 26, 2018 | Washing Machines
Mar 18, 2016 | Washing Machines
Apr 07, 2015 | Motorcycles
Aug 01, 2012 | Whirlpool Dishwashers
Dec 08, 2009 | Magic Chef Washing Machines
May 09, 2009 | Frigidaire ATF6000ES Front Load Washer
Aug 24, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
May 11, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Oct 30, 2007 | Kenmore Elite 45986 Front Load Washer
Mar 27, 2007 | Whirlpool LTE5243D Top Load Stacked...
278 people viewed this question
I have a Whirlpool Washer. It will wash, but will not spin. It use to wash with the lid open, but now it will not drain nor spin the water out. Please help. I have drained the water out, but it still has a bit in it. I have tried to turn it to spin in order for it to drain, but nothing happens. Could it be the lid switch and if so, where do I find it on the Whirlpool washer?
