Question about HP 17bII Calculator
Addition Problem with HP 17BII
Recently my trusty HP 17BII has stopped working correctly when I try to add a number to another number. If I push the "+" key several times, I can usually coax the calculator to do the calculation. Has anyone experienced this issue and, if so, is there any known fix? In fact, I just realized that the addition and subtraction keys are both behaving this way. Multiplication, division, exponentiation, etc. all seem to work as expected.
  • cxbravmann Jan 01, 2009
    I inadvertently mis-spelled my email address. The correct address is cbravmann@msn.com
  • cxbravmann Jan 02, 2009
    I've tried the suggested steps (other than opening the machine so I might be able to "clean the circuit below..." the keys. I've tried to open the calculator but the front and back seem stuck to each other and I am reluctant to break the plstic cover.
    Incidentally, to get to the main menu, I held down the gold key and the exit key simultaneously; there is no @A key combination on my 17 B II. Also, when running the self-test, I eventually got an error code of "FAIL 00020"
    President:
  • 2,110 Answers
Do a self test
1. Turn the calculator on.
2. If you have the optional infrared printer, turn it on. Certain diagnostic
information is printed during the test.
3. If possible, return to the MAIN menu (press @A).
4. To start the self-test, hold down C while you press the fifth menu
key from the left. Once the self-test has begun, do not press any keys
until you are ready to halt the test.
5. During the test, the calculator beeps periodically and displays various
patterns and characters. Watch for one of two messages that are
displayed before the test automatically repeats:
􀂄 If the calculator passes the self-test, the calculator displays
􀂄 If the calculator displays     followed by a five-digit number,
the calculator requires service.
6. To halt the self-test, hold down C while you press the third menu
key from the left. The calculator displays             . If you
press any other key instead, the test halts and the calculator displays
a     message. This results from an incorrect key being pressed,
and does not mean that the calculator requires service.
7. If the calculator failed the self-test, repeat steps 4 through 6 to verify
the results. If you do not have a printer, write down the messages that
are displayed in step 5.
Posted on Jan 01, 2009
  • 2 more comments
  • Sibananda Jena
    Sibananda Jena Jan 01, 2009
    iF THIS DOESN'T SOLVE UR PROBLEM THEN
    open the calculator key pad and clean the circuit below that...
  • Sibananda Jena
    If the calculator doesn’t respond to keystrokes or is behaving unusually,
    attempt to reset it. Resetting the calculator halts the current calculation,
    clears the calculator line, and displays the MAIN menu. Stored data
    remains intact.
    To reset the calculator, hold down C while pressing the third menu
    key from the left. Repeat if necessary. The calculator displays
    to confirm that reset has occurred.
    The calculator can reset itself if it is dropped or if power is interrupted.
    If the calculator still does not respond to keystrokes, use a thin, pointed
    object to press the reset hole near of the battery compartment.
    Warning
    Never press the reset button twice within 1 second as
    this could result in a memory lost.
    Reset hole
    Resetting the calculator halts the current calculation, clears the calculator
    line, and displays the MAIN menu. Stored data remains intact except
    setting those conditions: double-space printing off, printer tracing off,
    printer without the ac adapter, and beeper on.
  • Sibananda Jena
  • kimkreuger Aug 03, 2011
    Please, how do you open the calculator key pad???
  • HP Master
  • 2,794 Answers
If you have and error code on a fail test you need to contact HP to find out what it is. If the self test worked you should get and ok message. This is probably related as to why the + key isn't working.
Posted on Apr 08, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially and based on your description, faulty keys, or to be more specific, the "+" and "-" contacts underneath the pad are fault or perhaps just dirty. it would be a matter of opening the unit and peforming a clean of the keypad. Not unless the unit has been dropped, then possibility of a defective component of a broken flat cable is small.
Good luck and Thank you for using FixYa.
  • 679 Answers
Swap out your keyboard and see if it goes away, never over react to these things, you may finf that it has nothing to do with what you first thought. It may be as simple as a ne variant of a worm or virus that attacks certain keys or combination there of. First try running a good virus/malware program, you may getone here,http://www.avg.com/, there is a free version on the site, try running that first, once we eliminate a software issue, we may concentrate on the obvious. Thanks Gym
Posted on Jan 02, 2009
Change decimials on hp 17bii
If you want to change the radix mark, press DSP then the softkey corresponding to the one you want. If you want to change the displayed number of decimal places, press DSP then [FIX] then select the number of digits you want after the decimal point and press INPUT.
Nov 11, 2013 | HP Office Equipment & Supplies
Where is the CPT key on the HPb11 Financial calculator?
There isn't one. Unlike calculators from other makers, the 17bII knows whether you've just input a number or not. Simply press the desired item without entering a number to calculate it.
For example, if the book says to press CPT then PMT to compute the payment, simply press the PMT key on the 17bII.
Sep 07, 2013 | HP 10bII Calculator
The far right column of keys on my HP 17BII calulator suddenly stopped working. Can this be repaired?"
they are under $100.00 at office deport and other stores on the internet. basically it is a throw away item.
Jun 10, 2013 | HP 17bII Calculator
I can't change the language in HP 17bII calculator
Press SHIFT [MODES]. Press the [INTL] softkey, then press the softkey for the desired language.
Jan 30, 2011 | HP 17bII Calculator
I just got a new computer, tried to add my old trusty LaserJetIIIP, but isn't on the list of printer models. Any ideas?
Your printer may be "trusty", but the real operative here is OLD.
The IIIp was introduced in 1991, that makes it almost 20 years old.
It isn't supported anymore. If your new computer is running Win7, you might
want to try the 'universal print drivers'. Just plug the printer in and see if
the OS picks it up.
If it doesn't, you are going to have to retire the beast.
Jan 27, 2011 | HP LaserJet IIIp Printer
I lost the user manual for my HP 17BII calculator. Can you tell me how to obtain a replacement or is there a free download available?? many thanks
You can download a free manual from the manufacturer's web site at
http://h10032.www1.hp.com/ctg/Manual/c00442250.pdf
Dec 07, 2010 | HP 17bII Calculator
Numbers are not adding correctly
This calculator uses RPN (Reverse Polish Notation).
To add two numbers a+b
  1. you enter the first addend, a
  2. you press ENTER,
  3. you type the second addend, b
  4. finally you press the ⁺ key to get the result.
The syntax of the operations is the same as for the addition.
Feb 19, 2010 | HP 12c Calculator
The months to pay off a loan are incorrect on my 17BII
This is something you should see your financial institution over, but when i work the math your looking at a 60 month loan total principal divided by # of months in the term i get a $972 monthly payment, $58 going to intrest out of each payment.
Apr 29, 2009 | HP 17bII Calculator
HP 17bII Calculator Logo
1,008 people viewed this question
Ben Johnson
