I recently purchased logitech x240 it has 3 speakers a big subwoofer acable for that with a green plug i plugged into the green colored plug in ion back of computer i get no sound i checked control panel sound should be working i tried different plug ins on back of computer still no sound can you help?
  • 1 more comment
  • smk24 Jan 01, 2009
    there were speakers used on this pc and they worked fine
    ifollowed your instructions green to green on back still no sound front icon is visible in lower right corner
    tried connecting sony am/fm radio to earphone input of one satelite speaker no sound at at all
    everything checks out plug in to green icon in lower right
    volume levels ok still no sound
    Scholar:
  • 96 Answers
Hi
Ok so basically you have the subwoofer box which contains the amplifier for the speaker system, and two "satellite" speakers. The two satellite speakers should connect to sockets on the subwoofer box and then as you say the lead with the green plugs goes from the subwoofer to the greean socket on the PC soundcard. As long as the subwoofer is powered up your speaker system should work.
That's ok as far as the actual speaker hardware goes. Now lets look a the computer itself. Did you have speakers on the machine before, and did they work ok? If yes, and you are totally sure the speakers are wired up correctly and powered on, then we have to assume your new Logitech speakers are broken and it;s time to return them to the shop.
If you didnt have sound before .... is the computer's soundcard installed and working? Is there a small speaker icon down by the clock on the taskbar? If not then it points to the drivers not being installed. If this is the case we will need to find out what soundcard you have installed and find some drivers for it.
If the speaker icon does appear, has it got a red X on it?...if so you speakers are muted in the sound mixer. If you are on XP right click the icon and select Volume Control. The only thing that should be muted in the mixer that appears should be the microphone. If the master volume has a check in the Mute box, then click in the box to uncheck it. The speakers should now work . For Vista it's slightly different. Right click the icon again. Choose Playback. Look to see what the default palyback device is (green tick), Right click this and select the "Levels" tab. Here again you will be able to see if anything is muted.
Also check that none of the volume sliders are on minimum and that the volume control is set to a proper level in whatever media player you are using.
Well these are all the basic checks and I hope you have found this helpful. If it does seem to be a driver issue then I suggest you open another thread along those lines and we can try and help you track down some drivers.
Posted on Jan 01, 2009
  • Derek Fuller
    Derek Fuller Jan 01, 2009
    You need to take the earphone OUTPUT from the radio to the AUDIO INPUT on the subwoofer to check the Logitech speakers. What you did was plug the radio into the earphone OUTPUT of one of the satellite speakers which would not work at all.
    Please try again by plugging the radio OUTPUT into the subwoofer INPUT. If you still get no sound we can assume the Logitech speakers are dead.
    Oh ... i assume you checked the volume control on the subwoofer was turned up?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, a couple of ideas to consider, explore and/or check:
  • try connecting the green plug of the Logitech X240 to another audio source such as the headphone jack of an MP3 player, DVD. This is to confirm that the new X240 works. Alternately, you can even try touching the tip of the plug with your finger, there should be a humming sound;
  • are there any other indicators such as a panel light to show that indeed the X240 is receiving power and is activated;
  • try using a pair of headphones on the computer. This is to determine that the PC's hardware and driver are operational;
  • if your PC is a desktop, try hooking the green plug to the green jack of the PC in front (if available).
Good luck and Thank you for using FixYa.
  • 2 more comments
  • Louie  Role
    Louie Role Jan 01, 2009
    Acknowledgment should be given to IrishDruid for his solution copied by Dipu007 from here on May 24, 2008.
  • Louie  Role
    Appreciate the postback and update.
    Further ideas:
    • there were speakers used on this pc and they worked fine - indicates that the PC's sound hardware and driver are operational;
    • green to green on back still no sound - chances are the X240 is defective. Could you follow the green cable to where it goes to the X240. It should be to the INPUT;
    • front icon is visible in lower right corner - confirms that the PC's sound hardware and driver are operational;
    • have you tried hooking the X240 to another audio source as initially proposed?
  • Louie  Role
    The "earphone input of one satelite speaker" is meant to be connected to just that an earphone/headset.
    I am suspecting that for some reason the wiring/connections are off. p[ls double check your connection. The input of the X240 is the same as the one used by the iPod cradle.
  • Louie  Role
    If as you said, everything checks out, the connections are correct, the PC has sound using another speaker, and the has no sound even when X240 is connected to a Sony AM/FM radio's earphone jack, then being new, claim warranty/replacement. Sorry to be bringing you the bad news.
    Any indications at all that it is working or at least receiving power? Might just be a fuse.
    President:
  • 2,110 Answers
  1. Verify that all cables are plugged in correctly. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the center/sub audio port is orange. If you do not have a surround sound card, make sure you obtain the proper adapter (discussed in the next paragraph) or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
  2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. For 5.1 systems, the card should have a front, rear, and center/sub, output. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, you can use the M3D button on the controller unit (if you own a z-560 or z-540) or use the source selector switch (if you own a z-5300 or x-620). If you do not have any of the models above, you can use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
  3. Try connecting the speakers to a portable sound device such as a walkman or portable CD player. Plug the speakers into the headphone jack, but make sure the volume is lowered so the speakers are not over powered. You can do this for both the front, rear, center/sub speakers to verify that they work. If the speaker system works on the walkman, then you are experiencing a configuration issue with your sound card. Please contact your sound card manufacturer.
  4. Check the system Volume Control located in the System tray. Make sure that the volumes are at a reasonable level and are not checked for Muting.
How do i hook up logitech speakers #z313 to my desktop i need a diagram
Phone jack on woofer goes into computer tower (should be color coded green) and power cable on woofer plugs into 120VAC. Speaker phone jack plugs into back of woofer. The speaker cable has an on-off switch and volume control as well as a phone jack for your headset.
Nov 14, 2012 | Logitech SPEAKER SYSTEM Z313 PC Multimedia...
Z313 no sound
Phone plug on subwoofer plugs into phone jack on back of tower! Plug and jack are color coded green. If you plug into wrong jack you get no sound or intermittent sound. Also speaker cables have an on-off swith so make sure you are switched "on" or you will not get sound.
Oct 30, 2012 | Logitech SPEAKER SYSTEM Z313 PC Multimedia...
Hi .. i have just bought a logitech x 530 speaker and only 2 of the speaker parts work .. can you please give me some solution advice?
Hi names Rui i like to help you by giving you step by step instruction in propely hocking up your logitech speakers:
Instructions
1. Connect the black plug of the rear right speaker into the black plug on the subwoofer.
2. Connect the yellow plug on the rear left speaker into the yellow input on the subwoofer.
3. Connect the red plug of the front center speaker into the red input on the subwoofer.
4. Connect the white plug of the front left speaker into the white input on the subwoofer.
5. Connect the d-sub connector plug from the front right speaker into the d-plug connector on the subwoofer.
6. Connect the green, black and orange input to the matching plugs on your computer. If you have a four-channel sound card, connect the green plug from the input audio cable to the front plug of the card and the black plug to the rear plug. Do not connect the orange input. If you are using a two-channel sound card, connect the green plug from the input audio cable to the "Line Out" jack on the sound card. Do not connect the green and orange plug.
7. Plug the subwoofer power chord into the electrical power outlet.
8. Place your subwoofer on ground around your computer desk. Position the front center speaker on top of your computer monitor.
9. Place the left and right front speakers on the sides of the monitor. Position the left and right rear speakers behind you, making sure they are pointing toward the front left and right speakers.
10. needs to support 5.1 surround. Normally, more than three sockets for sound indicates that it does. Then you need to use the software that comes with the sound hardware to configure it for 5.1 - Default will be 2.1 or just 2.
Check the control panel out. This is a lot easier under Windows 7.- Here you can access what you need via the speaker icon on the system tray (right click)
There is NO problem with your OS or hardware, this is pretty standard...
hope this will help you solve your problem.
Jul 18, 2011 | Logitech X-530 Computer Speakers
How do i connect the boston BA745 comp. speakers to my gateway desktop?
Assuming you have the BA745 2.1 speaker set up, all of the cables connect to the subwoofer and then to the computer or the satellite speakers (these are built into the speakers IIRC). Take the cable with the black box (2 pins) to red and green. The red and green plugs go into the matching color ports on the computer and the pins on the black end fit into the jacks between the those for the two satellites. Plug the single end speaker cable into the subwoofer port all the way to the right on the back of the subwoofer. Plug the wire with the two plugs into the matching color jacks (blue to the left, red to the right). Then plug in the power adapter cable in the farthest left jack and plug in the other end to a surge protected power strip (that is plugged in and turned on).
Oct 24, 2010 | Boston Acoustics BA745 Computer Speakers
How do i attach the speakers to my computer
The manual for you speaker system is located here;
http://logitech-en-emea.custhelp.com/cgi-bin/logitech_en_emea.cfg/php/enduser/std_adp.php?p_faqid=8793&p_sid=jIAa2a-j&p_lva=8040&section=troubleshoot&crid=439&lt_product_id=211&tabs=1%2C3%2C2%2C5&p_search_text=X+530
On page 2 of the manual it says that all of the speakers plug into the subwoofer, then the subwoofer is pluged into an ac power supply, then # 4. on page 2 of the diagram shows that the Audio input cable to your PC is the green, black & orange plugs!!!!! YAY!!!
If you do not have a Dolby 5.1 sound card with green black and orange plugs, you will have to buy one. The can be had for a little as $15....
Thanks,
James
-----------------please vote 4 thumbs up 4 me!!!--------------------
Apr 24, 2010 | Logitech X-530 5.1 Speakers
HOW TO HOOK UP ALL MY X-530 LOGITECH SPEAKER ON MY PC
You'll only be able to get true surround sound utilizing all the speakers if you have a sound card with multiple outputs (usually color coded as Green, Black, and Orange). Plug the satellite speakers into the subwoofer and run the three input wires (Green, Black, Orange) to your multi-source output.
If you only have one output on your PC (common), you should just connect the green wire and press the "matrix" button on the system. This will just duplicate the sound output into the other channels but is not "real" surround sound.
Hope that helps.
Feb 07, 2010 | Logitech X-530 5.1 Channel Speaker System...
Logitech x-140 speakers connection
Did you try the black plug? Also, look at the right hand side of the tray and see if you have a Speaker icon. And if you do have a speaker icon, make sure that your sound is not muted.
Oct 25, 2008 | Logitech X-140 Speaker
Speaker hook up
Shari,
It is my hope that I can help. This applies to the type of sound card on your PC.
- If you have a 2-channel sound card: Select 2 on the source selector switch on the subwoofer. Connect the green plug from the audio input cable to tyhe front jack on your PC sound card. With this input setting, your speakers will upmix the 4-channel signal and create a center signal for your speakers.
- If you have a 4-channel sound card: Select '4' on the source selector switch on the subwoofer. Connect the colored jacks on the audio input cable to the jacks on your PC sound card, making sure to match the colors.
- If you have a '6'-channel sound card: Select '5-1' on the source selector switch on the subwoofer. Connect the colored jacks on the audio input cable to the jacks on your PC sound card, making sure to match the colors.
Your sound card is located on the back of your PC Tower.
Good luck
Jun 24, 2008 | Logitech Z-5300 Computer Speakers
Surround Sound Center Speaker/Sound Card issue
You need to use a digital interface cable between the sound card and the speakers to get all of the 6 channels to work properly.
Sep 24, 2006 | Inland 58019 ThunderSound 5.1 PCI Sound...
26 people viewed this question
 Grubhead
Grubhead
