Question about Dryers
Finding pilot light for a Kenmore dryer model # 97581110
Recently, my dryer stopped getting hot to dry our clothes. I am thinking that the pilot light went out, because the same day, there were very strong winds that could have come into our basement and blew out the pilot light (dryer is near basement door). On this particular dryer, there isn't a access door on any side of the dryer, except for a finger circumference sized hole on the front, below the dryer door on the left front of the dryer. Otherwise nothing. Any assistance in finding were to find and light the pilot light will be very helpful. - Brian
  • blshields Jan 01, 2009
    model number 97581110 (Kenmore Electric Dryer). Thanks
  • Dan Webster
    Dan Webster May 11, 2010
    model number pwease
  • Dryers Master
  • 8,205 Answers
Most likely it is the heating element.
Posted on Jan 01, 2009
  • 640 Answers
Brain brain,,first dryers dont have pilot lites,,,ahhhh happy new years,,,if you fellow this you will be working in a few mintues ok,,,now unplug the dryer and go to the back you have to remove that bnack panel,,1/4 nut driver will do fine,,now look down you will see a white plastic piece with two wire to it,,,its called a thermal fuse,,not the metal thermstates,,ok its plastic and white,,,now still unpluged put the two lead together or change that fuse,,,now you have heat..
  • onthethejob1
    onthethejob1 Jan 01, 2009
    you have wrong model numer this is a gas dryer..
    Sergeant:
  • 311 Answers
Theres no standing pilot in dryers is it on a heat setting or air dry .then look thru that small hole while in aheat setting on the timer. when you press the start button you will hear two clicks the see the glow ignitor glowing.if its not glowingyou would need to check voltage at the ignitor if no voltage problem will be thermol cut out fuse
I recently had a water leak in the crawl space of my house. It is being dried out with several fans,and a dragon, blowing hot air under the hose. This will continue to go on for another week. Now I&#
Very likely.
Here's why.
Because of the real danger of overheating and fire, dryers are "loaded" with overheat switches which will shut thr dryer off if they get hot.
One reason is that lint catches fire so easily.
Here's hoping you problem will resolve soon!
Be blessed
Jan 27, 2013 | Kenmore Dryers
Dryer gets hot on the outside of machine
Clean the lint out of the pipe that goes out side, also the grate on the outside, If that dosent do it take the back off and see where the lint comes out, take that apart and clean the lint out. I have had this problem before and just recently. The dryer has a saftey fuse, when the dryer gets too hot to shut off, thats why your clothes are not drying. 1st try the pipe that goes outside including the end(outside).
Aug 15, 2012 | Kenmore 400 6942 Dryer
I own a Kenmore clothes dryer, serial #ME2475807, model/stock #96573220. Recently the heat stopped working. It still spins the clothes around, but does not heat up to dry them properly. I think it needs a...
Unplug the dryer and take the back off
The backsides is where the element is located.
The back side components look like this:
Their are 2 limits mounted on the heater chamber:
More here
Sep 12, 2011 | Kenmore Dryers
I have a Kenmore 80 Series Gas Dryer. We replaced the motor and blower wheel in October of 2010. Recently the the dryer has been stopping while drying clothes. No matter what cycle I put it on, it almost...
Hi, In looking at your problem please do the following. Go behind the dryer. The vent hose that is attached to the back of the dryer has to go straight to the wall outlet. It must not have any bends whatsoever. Its a straight shot to the wall. This should take care of it shutting off and being too hot. You may need, after the above, to change out the cycling thermo. Thanks for your inquiry and hope this helps. Have a Good Day!
Jan 18, 2011 | Dryers
My dryer wont get hot . think the pilot is out . .. how do i relight the pilot
send the model number,you can't light the pilot anymore,they are electronic ignition now,is it gas or electric?find the model number around the opening where you put the clothes into dryer
May 08, 2010 | Kenmore Dryers
Kenmore 11066912690 dryer stops working
if you are using the sensor drying cyle this could cause the unit to stop. it will detect the most dry clothing first usually light clothes that dry faster.if not and you are useing timed dry the most likely cause is a faluty timer,or a thermostat sesnor is going bad and turnoing off the dryer before the clothes are dry
Sep 16, 2009 | Kenmore 62602 Electric Dryer
My kemore dryer model 11071812001 not drying clothes
Sounds like the problem is the solenoid coils on your gas valve. easy to replace and inexpensive + common. their are 2 coils on the valve that have 2 wires each going to them. Let me know if you have any other questions,
Phil
Jun 10, 2009 | Kenmore 73952 Gas Dryer
No heat coming on to dry the clothes
Try this link I hope it helps, I know it helped me a ton!! ps don't forget to rank my help. Thank you and have a nice day!
http://fixitnow.com/wp/2004/11/13/mailbag-how-to-troubleshoot-a-gas-dryer-with-no-heat/
May 06, 2009 | Dryers
Kenmore Dryer
If this is a gas dryer, the rattling noise you hear is usually an indication of the gas valve coils failing on the burner assembly. Your dryer will normally have two of them. One is the main coil, and the other is a pilot position coil. It is recommended that you replace both of them at the same time (usually sold as a set). Searspartsdirect.com carries your parts. Just type in your model number and look under the "Burner Assembly" heading. For comparative shopping, repairclinic.com may also carry your parts. Sometimes at a cheaper price. If this is not a gas dryer, please post back with your model number, so I can assist you better. I hope this helps answer you questions.
Aug 17, 2008 | Dryers
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
164 people viewed this question
Top Dryers Experts
Richard Roth
Richard Roth
