Question about Rainbow 75th Anniversary Canister Vacuum
Rainbow SE makes funny noise when first turned on.
  • Rocky
    Rocky May 11, 2010
    What kind of noise?
    Main unit or the nozzle?
    Makes noise and then works fine?
    Makes any strange noises when turned of and motor is slowing down?
    Rocky
  • 75 Answers
Try putting water into it.if not then you should make sure the seperator is in.or is connected properly
Posted on Jun 29, 2009
I have an E2 Rainbow vacuum that suddenly began making a funny noise in the motor. Are the bearings going out
Rainbow has issues if you don't run it all the time or you leave water in the basin. I have seen these machines short out due to moisture. Anytime that you mix water and electricity it is not good. for what those machines cost, you should contact the dealer and see if they will service it.
Jan 13, 2016 | Rainbow Vacuums
Rainbow power head works but canister dont model d4
Chances are the motor died or went bad.
You would have to get a new motor.
You can find one here:
Rainbow D4 SE motor 120V
Or a more cost effective refurbished D4 motor unit here:
Rainbow D3 D4 SE motor unit
GoodVac.com
800-775-6586
Jul 04, 2014 | Rainbow E series Canister Wet/Dry Vacuum
How does the Power Head wire up to the switch on the Rainbow SE?
Here is the wiring for a D4 switch:
Rainbow D3 D4 SE power switch
Rainbow no longer makes the switch with 6 wires, it comes now with only 4.
GoodVac.com
800-775-6586
Jun 29, 2014 | Rainbow 75th Anniversary Canister Vacuum
How does Aqua Mate attach to Rainbow SE vacuum?
You can download the manual here...
Rainbow Vacuum Manuals
We are also available if needed at Contact Us
RainVac
Jun 18, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow motor makes loud noise
Depending on the age of the Rainbow, it could be the bearings. Does the noise happen with just the Rainbow or from the power nozzle?
RainVac
www.rainvac.com
800-523-0510
Mar 10, 2012 | Rainbow E series Canister Wet/Dry Vacuum
I just purchased a rainbow D4C, after purchasing i was told i should have purchased the SE model. whats the difference?
There is only one difference between the D4 and the D4 SE, which stands for D4 (Special Edition). It is the exhaust plug screws in on an SE and snaps in on a regular D4.
Then the SE-PE came along, which stands for (Special Edition-Performance Edition) which has a more powerful motor, with larger motor brushes, for more power and runs on 9.8 amps, where the regular SE and D4 run on 8.8 amps. It also has the newer PN-2 power nozzle, which is very much like the latest E and E2 series Rainbow vacuums, instead of the earlier rectangular ones, that have the bottom metal plate, which will rust. You can upgrade your D4 to one of these, though you will need the electric hose with gas pump style handle, with the built in power corn in it.
They are all D4 models.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Apr 02, 2010 | Rainbow 75th Anniversary Canister Vacuum
Rainbow SE makes Squealing Noise when switching it On/Off
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=528929
Rainbow SE makes Squealing Noise when switching it...
Posted by ray_s51 on Apr 20, 2008
My Rainbow SE works and runs strong but when I switch it on and off for approx. 20 to 30 seconds the motor makes a loud squealing noise. Do I need to oil something or what? Nothing smells, it does not make the noise all the time, but it does more often than not. Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum.
The Rainbow has 3 fans in the bottom of the motor and if they are weak they will make noise from the motor unit. Watch out… the repair of the Rainbow may exceed the cost of a new motor of which will solve your problem of noise and separator --- compare the cost and the labor and make a decision. The separator is part of the armature, the separator should be able to be removed and that might be one of the things making noise. As normal maintenance the separator should be removed and cleaned after every use and re-installed, then place a newspaper or towel under the motor unit and turn on the Rainbow and spin the moisture out of the motor unit. This should be done every time you use it. If you have further questions please feel free to contact your local vacuum cleaner dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Apr 20, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow 75th Anniversary Canister Vacuum Logo
228 people viewed this question
Top Rainbow Vacuums Experts
Chris Nomland
Chris Nomland
JoeVacs
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
