Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
54lbs bow mount. Unit only working in reverse!
Never had this problem before. Went fishing the other day and found out I had a model that works in reverse.
  • 10,865 Answers
Reverse the wires coming from the battery. good luck
Posted on Jan 19, 2009
Can I turn the head 180 so it can be used on the bow its model 35
assuming that you are referring to an electric outboard trolling unit , if you can mount it there, do so and operate it in reverse to go forward
if the assumption is wrong then that is because you are extremely short on detailed information and my crystal ball is a bit foggy today
Feb 15, 2017 | The Office Equipment & Supplies
LOOKING FOR RANGER SPORT R70 BOAT MANUAL
Austin,
I have never seen a manual for this boat as a stand alone "boat manual". Typically all you get are the specs on the boat and specific systems have their own manuals. I.E. Manual for the outboard, manual for the bow mount troller, manual for depth finder, manual for radio, etc. Specs for your R70 can be found here.
bassboatcentral/rangerspecs3.htm
Sep 19, 2016 | Boating
Minn kota riptide 55 bow mount with foot control and auto pilot. problem is prop doesn't seem to spin as fast so top speed is about half to two thirds of what it was when new. unit is about 5yrs old.just...
Sounds as if the motor has either bearings going bad and/or water has gotten in the housing washed the lubricants out. Motors do wear out eventually. I'm not sure if the brushes are replacible. Have you checked for any constrictions like fishing line? And also the contacts on the controller could have minor corrosion meaning take it apart if possible and clean with steel wool or a dremel.
Oct 16, 2010 | Minn Kota Riptide St Saltwater 55 Bow...
I have a minnkota maxxum 74lb thrust trolling motor. The pedal pin in the foot control keeps sliding out on one side and I have to push this back in to stabilize the pedal. Is there something...
Good day ,
The next time the pin comes out have a close look at it if it has little raised grooves in it that is what is supposed to hold it in.
if so put a little lock tight on the pin and push it back in it should hold again
good luck
Gordy
Nov 03, 2017 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Lost forward gear heart clanking noise forwark went out reverse works fine.
I hate to say it but youve got lower unit problems. It's not the cables because you still got reverse. 2 options, rebuild lower unit which is very expensive, or start searching boat yards, ebay, and craigslist for lower units to fit your model. If you do the work yourself you can save a lot of money, but if you take it somewhere and let them do it with new parts expect at least a 500 dollar fix.
Aug 23, 2009 | Boating
Minn Kota power drive trolling motor will not steer to the right **** huard my minnkot will only steer left. I do not have a foot pedal, use the wrist remote control. even goes left when pressing down...
There is a good chance that he control board is bad. This is a common problem with these units. I have replaced my control board twice.. When the control board goes out, the some function of the unit will not work correctly while other functions work fine. The first time mine went out, the prop motor would not work. The last time the board went out, the unit would only steer right.
May 29, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Prop spins slow on any speed on the foot pedal
There is a good chance that the control board is bad. This is a common problem with these units. I have replaced my control board twice. When the control board goes out, some function of the unit will not work correctly while other functions work fine. The first time mine went out, the prop motor would not work. The last time the board went out, the unit would only steer right.
May 27, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Trolling motor doens't work
I have a trolling motor and can't seem to get it to come on. I seen it work when I got the boat. But now it won't come on.
May 06, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Reverse is gone on 1995 chevy blazer s10-goes forward just fine
reverse clutch went out rebuild transmission
Feb 21, 2009 | 1999 GMC Jimmy
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
310 people viewed this question
Top MotorGuide Electrical Supplies Experts
Craig Butler
Craig Butler
jdthefixer
Mike
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
