Question about Sony PlayStation Portable (PSP) Console
The PSP will not come on. every now and then I get a flicker of
It is only four days out of the box. It will ot even light the orange light indicating it is trying to charge.
  • 395 Answers
If its only 4 days old take it back to the store and exchange it for a new one
Posted on Jan 01, 2009
Hi My PSP's orange ligth won't turn off just always lightning when turn on my psp it's lightning with green light
Hi khangal74,
If you dont have issues playing your usual psp games, you dont have to worry about the orange light. That is normal. It means that your PSP is saving the data to your memory stick. Also make sure that your WLan switch is turned off ( that also causes a blinking orange light ). However, if you are experiencing a flickering orange light and your screen remains black ( and you cannot play any games), it means that your PSP is having issues reading you memory card.
Do these:
Remove the memory card and turn your PSP on without the memory card (it should turn on with no problems) Now, slowly re-insert your Memory stick. (You may need to do this several times until your PSP recognizes your memory card) If this still does not work, your Memory stick is busted or may be infected with a virus and therefore needs to be replaced.
Wishing you with positive results. All the best to you.
Jul 23, 2011 | Sony PlayStation Portable (PSP) Console
Hey, i have a problem with my sony PSP when i start my PSP the green power light is on but there is nothing to display and the memory stick light keeps flickering too , please help ???
Hello there
You'll need to hard reset your PSP and restore it to its factory settings. Once this is done, your PSP should work perfectly.
Hold the power button on the right side of your PSP down until the device completely powers off. Wait at least five seconds after the power is off before proceeding to the next step.
Press and hold the Select and Start buttons located in the bottom right corner of the PSP.
Press and hold the Square and Triangle buttons (located on the directional pad) while continuing to hold the Select and Start buttons.
Press the power button while holding these four buttons. When the flash (logo) screen appears, you can release the four buttons and your PSP will be reset to its factory settings and the screen will no longer be blank.
Oct 10, 2010 | Sony PSP (Piano Black)
Orange light in front is flickering almost constantly. What might this mean? The food seems frozen -ice cream is fine as are breads and meats.
It is normal for those lights ot flicker.. as long as the unit is working then do not worry about that...the light really is just showing you that you have power to the unit...
heatman101
Aug 26, 2010 | Kenmore 15 cu. ft. Chest Freezer 16542
My PSP will not turn on unless it is plugged into the outlet. When I try to turn it on by itself the power light flickers green for two seconds and then disappears. Also, the battery is fully charged. When...
replace the battery as it may be out of CYCLES even tho it says its fully charged if the battry is new your going to need a new element inside usually this consist of a new logic board under the battery pack.
good luck
Apr 27, 2010 | Sony PlayStation Portable (PSP) Slim...
Orange light will not stay on when the tv is off.
replace the power cord, do not use tv till you replace the power cord ok, you will eventually short circuit the tv or even worse blow the internal components
Jun 22, 2009 | Vizio L32 32 in. LCD HDTV
My psp wont turn on... i dont even know if its charging...i dont know anything about the psp. my psp didnt come with instuctions!HELP!!!
the way 2 know if tis charging is wen u plug in ur charger 2 ur psp on da right a orange light should appear and stay ther eas long as its charging . wen it goes away it should be blank. if this doesnt happen on urs i dont know why. it should have come wiv a anual in ur psp box unless u have bought a used 1 from someone in dat case dey mite have not given 2 u for whatever reason. i hope dis helped=)
Jan 14, 2009 | Sony PlayStation Portable (PSP) Console
Psp won't turn on
im am soorrrry but go to gamstop and buy a new battery thats all
Apr 16, 2008 | Sony PlayStation Portable (PSP) Console
Brand new psp battery will not charge
Did you charge it first? You need a good initial charge. Depending on the charger, it could be about 6 hours.
Also, remove the battery and check the metal contacts on the top and make sure that they are not covered by anything. Some come with a film to protect them.
Mar 10, 2008 | Sony PlayStation Portable (PSP) Console
Psp and water
you have two possible problems here.
1. there are still water in the console
2. some component burned because of the water.
in the first case (if out of warranty time) open all the psp,clean it and let all components dry for 2 or 3 days somewhere nobody will touch it. and remount and test again.
in the second, you must take it to a technician to take a look and check the possibility to change ir.
Nov 25, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
21 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
