Question about Optics
Meade lX90 scope finding problem
I am trying to get a donated Meade LX90 working for a non-profit educational program. I went thru the set up, but when it gets to finding anything it is way off. I tried training the motors. The Az (side to side) menu seemed to work right, but when I got to dec (up and down) it bombed. No up and down in that mode. It does go up and down when it tries to find North (which I think is off maybe 5-10 degrees) it moves up and aims in that direction so the up and down motor works, but not when in the training mode. Maybe that's the problem? I got the finder aligned with the scope OK. The GPS reports its working OK. I reset the time which was off. Any ideas you have would be great.
Thanks
Den
  • 3,186 Answers
Go back to square one-- in this order
RESET the hand-controller
Calibrate Motors
Train Drives in BOTH axis
Enter Time, Date, and Site-- Daylight Savings NO -- right now in the USA
Calibrate sensors (if you have this option)
Then do a two star Automatic alignment-- you will need to CENTER each alignment star and they may NOT be inside the eyepiece but nearby.
Here is a manual-- http://www.meade.com/manuals/TelescopeManuals/LXseries/LX-90_manual.pdf
Posted on Jan 03, 2009
I have a piece of meade carp that I have been trying to get a fix for many years. The scope currently performs a very useful service here, it keeps a door open. The problem is that the prism does not...
The Meade 8" SCT LX90 is a very good all round unit. Although angry, you will find it is well worthwhile persevering.
The back plate, called the optical back, takes an eyepiece holder into which you can also fit your diagonal prism for comfortable viewing. It is part 3 in the diagram here, Fig 1
http://www.meade.com/manuals/TelescopeManuals/LXseries/LX90-LNT.pdf
All you need is the right size holder for this scope, such as
http://www.bhphotovideo.com/c/product/202598-REG/Meade_07182_Eyepiece_Holder_aka_Visual.html
Any telescope shop can sell you one, but take care to get one that also fits the barrel of your prism, which will be either 1.25" or 2"
Apr 04, 2012 | Meade 8" LX90 LNT Schmidt Cassegrain...
Meade LX90 GPS - When the telescope slews to a new location (tour or manual slew), the telescope then slews up a few degrees. I have to manually slew the scope down several degrees and hope I've...
Calibrate motors and then TRAIN the drives-- this sets the gear backlash.
You should Calibrate motors every time you take it outside and Train drives at least once every year. The symptom you describe is called "rubberbanding".
Train the drives.
Mar 03, 2011 | Meade 8" LX90 Schmidt-Cassegrain Telescope...
I have a meade lx90 8inch 3 years old with autostar 497--when i try to raise the scope up it keeps drifting down also having problems with intermitant slewing on set up-both motors working ok
This is called "rubber-banding". Your scope needs to be re-trained.
So, setup a target during the day at least 100 feet away from the scope (200 feet would be better, Calibrate motors using the same power source you use at night, and Train Drives. Later after dark, do a Calibrate sensors on Polaris.
You should train drives about once per year, and calibrate sensors about twice per year.
You may want to update the firmware before you Train Drives. The latest version is 43Eg available on the Meade.com web site. You with need the Autostar Updater Software also available on the Meade web site under Customer Service---- Downloads. Version 5.9
www.meade.com
Oct 27, 2009 | Meade LX90 Telescope
Problem with alignment of Meade LX90 8" telescope
Start from scratch-
RESET the hand controller.
Calibrate motors using the same power source you will use outside.
Re-train the drives
Use either the 110 volt power cord, or buy a 12 volt power pack and the proper Meade 12 volt cable. (www.scopestuff.com carries the right 12 volt cable)
If your scope is NOT the LNT or GPS model you must level the tripod before you align. Go to home depot and buy the $3 small plastic two way bubble level, or the bulls-eye style bubble level.
Further trouble, I suggest going to the LX90 Yahoo group forum, and asking questions there.
Good Luck
Aug 30, 2009 | Meade 8" LX90 LNT Schmidt Cassegrain...
The dec, knob must have streped on my 2000 LX90.
Look at this for a possible fix--
http://www.scopestuff.com/ss_ezck.htm
Jun 23, 2009 | Meade LX90GPS: 8" LX90 GPS Telescope
Lx90
The best thing I can suggest is to find a local astronomy club and have them help you.
To find a local astronomy club just go to the nearest Observatory or Planetarium and ask them where to find one.
Also you can go to WWW.ASTRONOMY.Com , click on COMMUNITY, and on the pulldown click on 'Astronomy Groups.'
Apr 07, 2008 | Discovery Channel Meade 8" LX90-GPS...
Power
If you still have the red Led light on the scope's body, then...I ended up replacing the hand controller.
Tom Net
Mar 25, 2008 | Meade 8" LX90 LNT Schmidt Cassegrain...
Elevation motor stopped working....
You might look at the Jan's Meade lx90 site.
http://hometown.aol.com/kewtasheck/index.html
I have the same problem.
Feb 07, 2008 | Discovery Channel Meade 8" LX90-GPS...
MEADE LX90 TELESCOPE
I ended up replacing the Hand Controller with a new one.
After that it started working. I brought the new one on E-bay.
They seem to have the best prices. Forget about talking to Meade. Their innate ability to reply to your phone calls or emails just doesn't work. I will ***** buy a telescope from them again.
Aug 31, 2007 | Meade 8" LX90 LNT Schmidt Cassegrain...
Optics Logo
130 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
