Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
I have an Amana side by side....the refrigerator worked good, but the freezer stopped cooling. I also noticed during the same time, the water dispenser/ice dispenser quit working as well. Power works
It happened overnight. One day is was working great, next day, food in freezer is defrosting, no water or ice dispense in the door.
    Top Expert:
  • Amana Master
  • 9,472 Answers
What is the make and model number?
Posted on Oct 16, 2012
  • 2 more comments
  • Dan Whitcomb Oct 16, 2012
    Richard Roth:
    it is a SQO23V, not sure about the make other than Amana
  • Richard Roth
    Richard Roth Oct 16, 2012
    Sorry, I don't get any results for that model number. Look inside the refrigerator section to see if there is a model # posted there.
    that model number is from the sticker inside the door, I have a picture of the paper on the inside of the door, but can post picks, have to post videos.
3 Suggested Answers
SOURCE:
  • 72 Answers
SOURCE: Our freezer is not cold, food is defrosting, ice
Look at the back of the freezer wall from inside the freezer. Is there frost on it? If there is, you need to replace one of the components of the defrost system. If there is no frost then you need to have a repair made to the sealed system, it is either out of gas or the compressor is running inefficiently
Posted on Jun 20, 2009
heatman101
  • 43501 Answers
SOURCE: frozen food defrosted and ice maker stopped
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
adafd
Posted on Sep 30, 2010
My 10 year old side by side refrigerator freezer stops working and then after a few hour it works.
The defrost timer/board/ termination thermostat is hanging up and holding it is defrost too long....
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana Refrigerators
Fridge stopped being cold, freezer still working
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 25, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Amana model SXD25QA3W. Not cooling. Compressor runs.
Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
Good luck but likely 15-17 years old....... New one ???
Aug 17, 2009 | Amana SXD524VW Side by Side Refrigerator
Side by side Amana freezer/refrigerator thawing.
The doors not being shut can make it freeze up,Just thaw again and make sure the doors get shut each time and see what happens,just post back details if it doesn't work after thawing
Aug 05, 2009 | Amana ASD2625KE Side by Side Refrigerator
REFRIGERATOR MOTOR CONTINUES TO RUN AND WATER IS LEAKING.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
u
Mar 22, 2009 | Whirlpool ET8CHEXSQ Dryer
Freezer and fridge not cooling properly
Clean it up. Check under it and behind, clean ,vacume and or blow out all dust and check the fins on the bottom, a soft brush and portable air compressor work really well but very dusty, take out side if possible, or just vacume really well.
Jan 26, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Refridge not cooling
freezer side is working good but cooling side is not cool
Sep 24, 2008 | Amana ARB8057CSR Bottom Freezer...
GE Refrigerator stopped cooling
I had the same problem. Replaced the damper switch and the motherboard. Then noticed the freezer has frosted over behind the panel in the freezer. Defrosted the freezer and all was working again. The same problem came back about 3 months later. This time the problem was diagnosed as the heater has gone bad in the freezer. Now waiting to have this replaced.
Jun 18, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Water stopped dispensing, still makes ice
Yes Teri, you can.
What has most likely stopped the water is that it has frozen in the line coming into the back of the freezer section. You simply need to turn the box off and do a good cleaning. during the time that the box is off, the water line will have time to thaw. Put everything back together, turn the box back on and give it a try.
May 25, 2008 | Amana SXD524VW Side by Side Refrigerator
Amana Refer. runs all the time.
Have you ever cleaned the condenser coil in the back or under the bottom of the refrigerator. Dirty coil will cause this problem, also make sure the little fan motor in the back is working if it stops you can get the same condition. If not these two conditions you may be starting to have a refrigerant problem.
The unit gets low on refrigerant and just dosen't cool properly.
May 17, 2008 | Amana Refrigerators
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
139 people viewed this question
Top Amana Refrigerators Experts
Steve Allison
Steve Allison
Thomas F. Schneider
Marvin
Marvin
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
