Question about Hitachi 50UX26B/27K 50" Rear Projection Television
Hitachi 50 inch how to remove screen cover' - Hitachi 50UX26B/27K 50" Rear Projection Television
  • Hitachi Master
  • 5,138 Answers
Pull off Front speaker cover you will then see bolts holding face plate remove all screws then slide screen upward and Off.
HAPPY NEW YEAR!
Posted on Jan 01, 2009
Having a problem with plasma tv hitachi
It will depend on the age of the set but the lines are either a bad board or a bad display unit .
Dec 12, 2012 | Hitachi P50H401 50 in. Plasma HDTV
Lines across screen
If the lines are slightly diagonal and in red, blue and green you have a problem in the ABL circuit. if the lines are only one color you may take the front grill cover offf and remove the panel. look fro the black box 2 inches square with 6 little controls on it. 3 are for focue 3 are for screen the middle on of the screen is the green adjustment the other 2 should be labled r and b respectivly. what ever the color of the line turn the control labeled screen and r b or g for that color ever so ligtly counter clock wise.
Mar 30, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Bug parts or debris between screen cover and screen.
All from the front. Pull off the bottom speaker grill. No screws just pull straight back. There are rubber post that hold it. Next remove the screws on the bottom of the screen assembly. With them off you should be able to slide the screen assembly up about 1-2 inches and take off. This model does have auto convergence so the screen may have wires hooked to the back. With the power off disconnect the leads before setting the screen assembly down. Cleaning should be with a plastic cleaner not windex. If you do have to remove screen parts it's fairly obvious. Be sure to reassemble the same order and make sure you have help these parts are delicate when separate.
Mar 22, 2009 | Hitachi 50UX57B 50" Rear Projection...
Hitachi ultra vision, removing the front screen
Remove front bottom cover then remove all screws holding screen on Now slide screen up and out.
Dec 25, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Wasp inside Hitachi 50" rear proj. tv
Pull bottom cover off front you will see screws holding screen on remove all of them then slide screen upwards and OFF.
Nov 27, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Hitachi Model 50V500A RED BLOOM
Pls check this picture..
If you have same issue I would recommend pls change light engine.
Good Luck
Dals123
Oct 06, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Replacement lamp
Remove the front cover from the TV set. This is held by a snap on. Pull the front cover outwards until the quick snap on disengages.
Remove the screw securing the lamp cover with a Phillips head screw driver
Remove the two screws that hold the lamp in place. Remove the lamp unit by holding the lamp handle, then pulling outwards.
Exercise caution when removing the lamp unit to avoid injury to your fingers
Replace with the new lamp.
Place the removed lamp into the empty box of the replacement lamp. Do not touch the front glass of the new lamp or its
receptacle. This may shorten the life of the lamp and reduce the picture quality.
• Push the lamp unit back to its original position.
• Tighten the screws firmly on the lamp unit. If they are loose, the TV may not operate correctly. Install the front cover. There is also a video on youtube just do a search on how to install a projection lamp. Hope this is helpful
Aug 22, 2008 | Hitachi 50V715 50" Rear Projection...
50 inch hitachi green screen all the screen has a strong tint of green tried picture adjustment dont even get it close
I have the the same problem with my 60 inch Rear HD projection Hitachi. The bad part is we just bought a bulb 2 months prior to the green showing up.
Jul 02, 2008 | Televison & Video
Replacement protection scrren
Status Part Number Description Substitute List Price Dealer Price Obsolete KR01227 SCREEN/SHIELD $374.31 $299.45
Jun 16, 2008 | Hitachi 50FX20B 50" Rear Projection...
2 inches of picture from top is brighter and picture in tthat area is distorted
Hmmm, could be anything from dirty optics, to a convergence problem....accordianman
Nov 04, 2007 | Hitachi 50UX57B 50" Rear Projection...
Open Questions:
Televison & Video Logo
94 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
