Question about Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
My tv blinks 9 times and wont come on? - Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
  • Sony Master
  • 5,138 Answers
Replace 3 Diodes D6301-D6116-D6117 .
HAPPY NEW YEAR!
Posted on Jan 01, 2009
I dont have a remote for my tv and it wont turn on manually the led light blinks 9 times and stops and starts again what should i do?
The blinking lights are a service code. You should first try to unplug your TV and leave it unplugged for at least 4 hours... then plug it back in again.
If the blinking light is still there and no picture, time to have the TV serviced. Good luck!
Oct 10, 2010 | Panasonic CT-34WX54 34" TV
My sony wega KV-32FS120 wont turn on and the stand by is blinking 9 times
Does the tv blink 9 times and cut off and then try to come back on? If so change the switching regulator,also i would change D6116,D6301. they are all on the G board.use a desoldering iron,Oh,make sure the tv is unpluged from outlet.Also check for bad wiring connections,bad solder joints.Use a good solder for good connection like 60%Tin and 40%Lead Rosin Core.hope this helps...
Feb 20, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The tv wont turn on. the red light blinks 9 times.
There is a problem with one or two of the diodes on the G board.
Zero Crossing Detector 9 times 9:0 or 9:1
Probable cause • D6116 or D6301 is open (G Board)
symptom • No picture
I hope this helps and good luck!
Oct 31, 2009 | Sony KP-51WS520 51" Rear Projection...
TV blinks 9 times and wont turn on please help
Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive). hope it works
shaun
Aug 24, 2009 | Sony KP-46WT520 46" Rear Projection...
Tv doesn't want to start
The power light blinks about 9 times and the tv wont turn on what does this mean? its a magnavox 51mp392h/17
Aug 05, 2009 | Sony Televison & Video
Set wont turn on, stand by lights blinks 9 times
Have the same thing happening with ours... we were told by a repairman that it needs a new D Board. He told us that if we could fix the TV for under $500 that it was worth it, if not (which of course, we can't when you add in labor cost) don't fix it. I like the TV but I can buy a brand new flat screen for that!
Good Luck
Mar 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony Wega KDP-57WS655 Standby light blinks 9 times and wont turn
Service Manual of KDP-57WS655 says if TV standby light blinks 9 times then problem is Zero Corssing Detector and you need to replace diodes, D6116 or D6301 which are open on G Board.
Nov 24, 2008 | Sony Grand WEGA KDP-57WS655 57" Rear...
Tv wont turn on blinks 9 times then 1 time
I was inform that it could be a sensor (bad diode), you have to get a multimeter tester and test the diodes and if current flows from both sides then replace that diode.
Nov 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca hd52w59
does the power indicator light up? Does it blink 3 times then go off/ let me know and I may be able to help you that model is famous for bad flybacks
Apr 27, 2008 | RCA HD52W59 HDTV Projection Television
My TV will not turn on!
I have a tie dye of rainbow colors on the whole screen. Is the screen shot?
Dec 08, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KP-46WT520 46" Rear Projection HDTV-Ready Television Logo
90 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
