Question about Apple iPod nano
Unable to download songs
My ipod can't put songs from itunes onto my Ipod. But the ones that were already on it I can play.
    Problem Solver:
  • 12 Answers
What kind of error message are you getting? Have you tried restoring the factory settings from iTunes? (that will erase the contents of the iPod though)
Posted on Sep 19, 2007
SOURCE:
I will try and make this as short as possible and hope you understand what I am asking. I just got an Ipod Classic last month and signed up with Itunes and then downloaded about 1300 songs from my cd...
You can't "backwards sync" (put music from your iPod back onto your computer) through iTunes. When you went to sync after you got your fixed computer back, I'm assuming iTunes tried to copy what was in iTunes (nothing) to your iPod, which probably is what caused these problems.
Assuming you still have the music on your iPod, I would recommend transferring the music from your iPod back to your computer (to a folder other than iTunes), restoring your iPod to factory settings, then moving all of the music files into iTunes and re-syncing your iPod.
There are two programs that are available to transfer songs from your iPod back onto your computer. The first is iDump and the second is YamiPod. I have found that iDump is the better of the two.
The link for iDump is:
iDump
Hope this helps!
May 14, 2011 | Apple iPod classic MP3 Player
Hi I have a playlist on my itunes which when I download it onto my ipod, one of the songs is missed off. This song shows and plays on the playlist on itunes, and is on the main menu of my ipod, just not...
  1. Plug in your iPod to your computer and run iTunes.
  2. Sync your device.
  3. Re-check to make sure that song is under that specific playlist (if its not drag it onto the playlist)
  4. Make sure the box next to the song in iTunes is checked meaning it will sync with your iPod and your playlist.
  5. Apply the changes you have made to the playlist by re-syncing your iPod.
  6. If the box is checked and you sync your device the song should be listed under your playlist.
Mar 06, 2011 | Apple iPod 16GB nano Silver 4G...
My ipod a1137 is showing data but i am not able to play the song
Hi, your ipod displaying data and not playing might be because you did not transfer the music properly or the format of the music does not play on an ipod.
You will need a converter to help you convert songs into an ipod format. Download from the below link:
effectmatrix.com/total-video-converter/
You can follow the instruction below to know how to transfer music into an ipod.::
Most common problem for new ipod user is how to put music onto ipod. So I created this ipod tips to solve this problem. Windows media player is not able to upload songs to ipod. You must use Apple iTunes to get music onto your iPod. Windows Media Player can see the iPod as a hard disk. But not able to copy upload music from pc to ipod.
The steps to put music onto an Apple iPod with itune.
When you plug ipod to your pc first time through USB, you might get this pop up message. If you have already installed itune .
You need to restart your computer to install ipod and then the next time you start up, your iPod will not generate any messages of this nature.
You need to install itune on your computer if you have not installed itune. You can simply go to apple.com/itunes to download the latest version. It also comes with ipod CD.
The next step is to launch the iTunes program. And it will recognize the ipod that you have plugged in
It shows one message to give name to ipod, You can stick with the default name for your device or give name to ipod.
I also uncheck "automatically update music" because I like to control what happens to my iPod manually.
When you're done with this configuration step, click "Next" :
register your iPod, or just click "Finish".
Step 1
Now, finally, you can see iTunes and also your ipod inside your itune:
Click on whatever name you've given to your own iPod, and you'll see your music list, which is completely blank:
Now click on the "Library" link on the left column and you'll see what albums or music you've copied into your iTunes library. Or click on the "Browse" button on the top right (it looks like an all-seeing eye) and a new panel will show up with lists of songs, artists and albums.
Now select the song you want to put on to your ipod. then dragging and dropping that onto the name of the iPod on the left side panel of your itune. Now your song are copied to ipod.
Hope it helped.
Feel free to pass your comment.
Good luck..
Feb 25, 2011 | Apple iPod nano
Itunes mistakenly put other songs onto my ipod touch and deleted all of the ones i already had and wanted, i didnt want the ones that were downloaded and i cant delete them what should i do because i cant...
I have had this problem before and it is a simple fix. What I think has happened to you is that you iPod is automatically syncing songs which I personally dont like. To change this plug in your iPod and then in iTunes click on your iPod in the left side bar and then make sure that 'Manually manage music' or similar is checked and then you should be able to go into the ipod and delete songs etc. and if you want to add music simply drag it from the library onto the iPod in the side pannel.
Hope this helps
Oct 08, 2009 | Apple iPod touch
How to download a music cd onto the nano ipod
install iTunes on your computer if not already done so. open iTunes. put the CD in your CD drive of your computer - iTunes will ask if you want to add this CD to your library. Choose yes. plug your ipod nano into your computer USB while iTunes is still open and you see it appear as a device in iTunes. highlight the songs you just added to your library (choose Recently Added on left hand side then highlight them on right hand side) and then drag them onto the ipod device in left hand side. songs will be transferred to ipod.
May 18, 2009 | Apple iTunes
Downloading
You need to use itunes as your music management software and ipod management software. You can download the latest itunes version at www.apple.com/itunes.
From here you can purchase items through the itunes music store, or add your own music by adding files from your computer, or putting a cd in your computer and coppying it into itunes so you can put the songs on your ipod.
Hope this helped,
Nathan.
Apr 14, 2009 | Apple iPod nano
I put music from my computor onto the ipod when it is plugged into the computer it plays the song but doesn't recognise any song are it when it is not plugged in?
I am assuming you are a new user with your ipod.
You can play and view your music on the ipod only if you transfer the files thru itunes.
You can go to the apple website or download.com and download itunes.
After downloading it.Install the software and add your music onto your ipod through itunes.
Now your ipod will recognise all the songs you add.
IT WILL WORK.HAVE FUN.
and if i helped u solve ur problem in any way...please help me by clicking on the fixya rating..
thank you.
Mar 10, 2009 | Apple iPod nano MP3 Player
Ipod nano can't read or play songs
Did you use iTunes to put the songs on? This is totally essential to being able to see the songs on your iPod. download iTunes here
Oct 24, 2008 | Apple iPod nano 3rd Generation
Cannot delete songs
Your playing with fire when you don't use ITunes to put music on your Ipod. The best way to delete them is to restore your Ipod back to factory settings using Itunes.
May 19, 2008 | Apple iPod nano 3rd Generation
Apple iPod nano Logo
53 people viewed this question
Top Apple Audio Players & Recorders Experts
Parshiv Luthra
Marvin
Marvin
Dapid Candra
Dapid Candra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
