Question about Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
How do I remove dishwasher from cavity?
Hi my ds 603 is not working the drawer seems to be stuck on something and does not roll in and out like it used to do and when it is turned on it fires up the circuit breaker. I am trying to remove it from the cavity but can not do so, do you have any hints?
  • bmw007344 Jan 01, 2009
    Thanks have now removed the dishwasher and it is going to repairman as soon as they reopen after the holidays!
  • 76 Answers
Dishwashers are screwed into the bottom of the counter over it, and if you've had floor work(tile added,floor raised,etc) the you will have to raise the feet, and maybe remove soem tile....some dishwashers are also screwed into the side cabinets as well
Posted on Jan 01, 2009
My drawer on my fisher & paykel drawer sticks
I found a ball bearing stuck in one of the draw runners ? see if this link still works
Sep 29, 2014 | Fisher and Paykel 24 in. DS-603 Built-in...
Top drawer of my 8yr old fisher paykel dishwasher got stuck opening and now cant get it back in , botom drawer works but no power to top drawer can it be fixed ?
Not sure if your dishwasher problem has been fixed yet.
The lid seal actuator motors on the top drawer are stuck due to lack of power and therefore you cannot close the drawer. Don't try to force it in as this will cause damage.
First thing to do is to restore power to the drawer. The power comes from the filter board sitting at the base of the dishwasher. You will have to disconnect power to the dishwasher and get both the drawers out. This will give you access to the power filter board.
Refer item 15 in this diagram. It is likely the board is faulty and it supplies the lid seal actuator motor power to both drawers. (separate connections).
You have to take the front cover of each drawer out to remove the drawers from the rails. But be careful not to damage the cable and hose when pulling out. Keep a chair or something next to dishwasher to hold the top drawer.
Once you fix the filter board and restore power to actuator motors, push the lid seal up by hand to make sure it does not block the lid.
Hope this fixes the problem.
Oct 24, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
Have the Fisher & Paykel single drawer dishwasher ds 603 and put it on a normal cycle last night. It started as per normal and sometime during its cycle it stopped and the drawer now seems locked. ...
It is very likely the thermal fuse has blown or the power supply board has had it. Either way the power to the controller and the drawer lid seal motors is cut off. This is why the drawer is in locked state as the motors have seized.
You have no choice but to force open the drawer to get access to the affected parts. Make sure the mains power to dishwasher is turned off as the base will be live.
Replacing the power board is easy but if the thermal fuse is blown then you are up for a large cost as it is integral in the heating element.
Refer this document for details of parts and location. Heater is item 17 on page 18 and powerboard is item 15 on page 13. (the document is for double drawer model but it just doubles up on parts)
You can get a rough idea of the parts cost from this site. Depends where you live.
Hope you are able to get it fixed.
Jan 27, 2011 | Fisher and Paykel 24 in. DS-603 Built-in...
Dish drawer won't drain
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
Dec 01, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
What does an F1 erroor message mean. I have a
F1 means "flood. there is a flood sensor underneath the drawer, and if there is any water under the drawer the control will show that error. Check the drain hose linkage for cracks. Remove drawer and dry the area underneath.
Jul 14, 2010 | Fisher and Paykel 24 in. DS-603 Built-in...
My top drawer of my Fisher and Paykel dish washer wont close tight. It seemed to be jammed and not closing unless it was pushed closed hard and then it jumped a bit now wont close tight and has no...
Make sure the unit is level. Remove drawer. On the inside of the cabnet there are the drawer runners on iether side. Behind these there are a pair catches. If one or both of these are latched back when they shouldn't be, ie. when the drawer is open, they will obstruct the drawer from closing fully and fail to hold it closed.
Hope this helps
Dec 13, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
Bottom drawer will not close seems like it is hitting the lid
Turn off the power with the power button or by unplugging the unit to reset it.
Dec 11, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
Wash impeller wont rotate on fisher paykel model 603
I suppose you have a double drawer dishwasher and this problem is with one of the drawers.
One cause of the impeller not rotating would be that there is some loose cutlerry lodged between the impeller arm and the base rack. This is easy just remove it.
HOwever, the other option is that the impeller itself is stuck. Try opening the filter base plate and removing the impeller rotor to check if no debris is lying around (usually food scraps).
The instructions to open the filter plate and exposing the impeller is in the user guide. If cleaning does not help then check nothing is stuck in the filter sump and the narrow passage connecting filter sump and the rotor cavity which is preventing the rotor from rotating.
The worst case scenario is the impeller rotor is faulty. You can buy this and replace yourself , ie, if you worked out how to remove it.
Good luck
Nov 17, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel 24 in. DD603H W Built-in Dishwasher Logo
128 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
