Sony ps-lx2 turntable clicks when spinning
Bought a decent used turntable, but there is clicking sound from under the turntable when it spins, even at low (33rpm) speed. it seems to be from inside the back of the case, not under the center of the table. the model is sony ps-lx2 direct drive turntable, but this site won't recognize the model at auto select.
  • 1 more comment
  • David Jun 19, 2013
    Mine makes the same noise. The size 17 selection is not working and this may be the issue- something inside related to this.
  • Anonymous Mar 20, 2014
    how can I fix my sony pslx46p turntable (no power)?
    no rotation of the turntable
  • 42 Answers
It seems something may have come loose over time or history, but you will have to delve inside to see what it is. It sounds as though the fault should be obvious.
If you do not want to do this, a repair shop should have no problem. I assume that the deck is working ok otherwise.
Posted on Jan 25, 2009
  • Steve Moff
    Steve Moff Feb 26, 2014
    had to shop they say they can't get transistors for it
Needle Won't Stay Down
Hi, sounds like the automatic function has gone out of time. With the record player powered of spin the platter manually appox 12 times to reset. Cheers john. Stylus City
Jan 24, 2014 | Sony PS-LX250H Turntable
Can't get the darn to work
Remove the drive belt and see if the turntable spins, if it does the drive motor is faulty, if it doesn't then (if this is a new turntable) it's possibly got a locking device to hold the turn table steady during shipping.
Sep 12, 2008 | Sony PS-LX350H Turntable
My turntable is hooked but it wont work.
Bog standard TT connected to a bog standard receiver. Hmmm.
I cannot figure out where you have the equalizer placed (or why, but that is another topic).
What exactly is beeping?
Jan 24, 2013 | Sony PS-LX250H Turntable
My Sony PS-LX250H turntable will only spin at 45rpm. When i push the speed button for 33 it doesn't change. i also sometimes have to give the deck a little push to get it to spin.
I have the exact same problem for the same model. Only spins at 45 and I sometimes have to kick-start it. I tried de-activating the switch (so that it's not making a connection) and therefore in the 33 position but that does not help.
Dec 14, 2010 | Sony PS-LX250H Turntable
The turntable doesn't spin. It has never worked since I bought it. How can I fix it?
Lift up the matt and see if the belt is there and attached. If not replace it.
Dec 03, 2010 | Sony PS-LX250H Turntable
HOW DO I INSTALL A TURNTABLE BELT FOR A SONY TURNTABLE
Under the felt of the turning section, there should be two rather large holes. Insert your thumb and forefinger and pull the table off. You should also see where the existing belt is running. Insert new belt around the motor first and replace the table section. Now, through the two holes, manouver the belt onto the table section until it spins freely
May 30, 2010 | Sony PS-LX250H Turntable
Turn table wont spin.
if its a direct drive turntable then the motor is under the spindle as the spindle is a composite part of the actual motor? Its most likely burnt out i`m afraid? sorry
Jul 14, 2009 | Sony PS-LX250 Turntable
Can't get sound from turntable to pc speakers
go to control panel, sound audio devices, hardware , USB Audio Device Properies, Properties, click the + next to Audio Devices USB Audio Device Properties, make sure that is highlighted, click do not map through this device, apply restart program. Under device properties make sure sound playback is set to default driver ie: Realteck Ac97 audio etc... Hope this helps
Dec 30, 2008 | Sony PS-LX300USB Turntable
Sony ps lx2 volume problem
This deck requires a phono (RIAA) pre amplifier before an amplifier to feed your speakers.
Nov 24, 2008 | Audio Players & Recorders
New needle for sony ps-lx250h?
Yes It's possible.You can purchase it on amazon, click here and take a look: Amazon com sony ps lx250h needle. I hope this was helpful. Cheers
Jan 24, 2008 | Sony PS-LX250H Turntable
403 people viewed this question
 Grubhead
Grubhead
