Question about Pioneer VSX-D912 Receiver
Our pioneer vsx-D912 reciever sounds like a short is occuring.
We have checked all speaker wires and connectors and everything looks fine. It almost sounds like the speakers are blown, but when we switch them to the "B channel", they sound fine. Could channel "A" be blown?
  • pbaloche Jan 01, 2009
    Thank you. I wish there was a fix rather than having to go and buy another receiver. Anything that can be doe to fix channel A?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, a couple of ideas you may want to consider:
  • a 7.1 receiver as in a Pioneer VSX-D912 would have several amplifier sections. By themselves, they are independent of each other and their only common denominator would be the power supply and sound processing/controller;
  • doubtful if the power supply would be suspect if all other channels/speakers works fine;
  • if the "channel "A" is intermittent them likely a loose connection or most likely a cold solder on the A/B selection board/switch;
  • worst case scenario would be a faulty sound processor/Dolby selector.
Good luck and Thank you for using FixYa.
Posted on Jan 01, 2009
    President:
  • 2,110 Answers
1 Switch the receiver into standby.
2 While holding down the ADVANCED
SURROUND button, press and hold the
STANDBY/ON button for about three
seconds.
3 When you see RESET? appear in the
display, press ‘
ST –
OK?
shows in the display.
4 Press
SOUND RETRIEVER
to confirm.
OK
appears in the display to indicate that the
receiver has been reset to the factory settings.
    Genius:
  • 1,199 Answers
This doesent sound like channel A is broken! this is a common problem in this model a and the switch that controls channels A/B needs to be replaced ( A cheap repair) and then all should work for you!
Thank you for useong Fix YA
    President:
  • 1,990 Answers
How loud have you been running the System Continuously. Channel A sometimes gets hot and will shut down. It carries the Largest load on the System. Had to replace mine a few years back. Put the old one in my Work shop and now Occasionally Channel A will kick in and Work But, Not Often.
  • Travis Humphries
    Travis Humphries Jan 02, 2009
    Unless you can Locate a Local Repair location to Repair it. I would get a New one. Not necessarily Cheaper to Fix and you will be Without for the Time it Takes. Really depends on how much you like the Reciever!
I have a Pioneer VSX-1022 Reciever - I get no sound when it is on the "TUNER"
These models have a problem where it is very easy for the tuner pcb to become disconnected from the main pcb. About the only way I've found to fix it, is to take the back panel completely off and reseat the board.
Apr 11, 2013 | Pioneer VSX-1022-K Network Ready Receiver
MANUAL FOR PIONEER STEREO RECEIVER MODEL VSX-D901S
Hi
Check the following link. Its athe manual for VSX D 912. May be the same for your one.
http://audio.manualsonline.com/manuals/mfg/pioneer/vsx-d912.html
Ajin
Jan 19, 2012 | Pioneer Audio Players & Recorders
Pioneer Amp VSX-D912 when I keep the volume at 40 , Power turn OFF
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a possible root cause for intermittent shutdown.
Jun 07, 2011 | Pioneer VSX-D912 Receiver
No signal going to my subwoofer. All other channels work fine. How can I verify if problem is with Pioneer VSX-D912 reciever or my subwoofer?
First, did it EVER work?
No? Review the speaker setup in the receiver and make sure it knows you have a sub and is sending LFE to it.
Yes? Feed it a signal directly from a CD player or something. Start with a quiet sound passage as you probably will have no control of the volume.
If you need help beyond this, name the sub and how it's connected.
Jan 18, 2011 | Audio Players & Recorders
Is there a pioneer vsx d912 color manual online?
Here is a copy of the user manual of this unit , just click HERE.
Dec 04, 2010 | Pioneer VSX-D912 Receiver
Pioneer VSX-5300; sound cutting out
try open each speaker test may be speaker or wire short....if all ok check pcb solder side....
Dec 31, 2009 | Audio Players & Recorders
System turns on but only hear feedback fomr speakser no sound
do the headphones work?that means the pre amp is working.
the speaker protection is maybe activated from shorted wires on the back,there should be a click 5 to 7 seconds after turning it on.
that is the relay that connects the speakers.check the speaker a and b switch. people are not aware of this,but alot of amplifiers ADD the a and b speakers,to prevent too low an impedance from parallel wiring.unless there is 4 speakers,no sound.
May 22, 2009 | Pioneer VSX-D409
Only Left Speakers Work
CHECK THE MENU,,SETTUP ,,NO RECIEVER NEEDEED,,IF NOT CHECK THE RAC JACKS
May 14, 2009 | Pioneer VSX-D511 Receiver
Pioneer vsx-d307
You have a flashing "mute" on the display?...accordianman
Oct 04, 2007 | Pioneer VSX-D307 Receiver
Pioneer VSX-D912 Receiver Logo
66 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
