Question about Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor
Dell 1800fp monitor problem
My monitor was working fine had no problems then one day it just quit working gets no power to it. I changed the power cord but that does not work either. I press the power button and the green light that shows it is on does not turn on at all. I have never messed with repairing a monitor before so not to sure what to check or change on it. Would you have any ideas and if it would be worth trying to fix it as opposed to buying a new one. Thanks for any help you could give me.
  • TXKim Jan 04, 2009
    Yep! I have the same problem. It was working signs of distress and then WHAM! It was gone! Anyone know of a solution?
  • jimwarters Jan 26, 2009
    Just came back from a week long trip. Pressed power button to turn monitor on. No luck. Have changed power outlets and power cord. My system is protected by a surge suppressor and battery backup. No unusual power conditions shown by battery backup.
  • 4 Answers
Check the main board from which your monitor gets its main power from to see if it is working or supplying the required power needed by your monitor to work.
if it is not working or supplying the required power,get a new one and try again.
after this procedure and your problem still continues,if you can afford,i will advise you to get a new monitor rather than repairing the old one since the old one if not properly repaired will give you more problems in the near future which will cost money you to repair
thank you for contacting us with your problems you are always welcomed
Posted on Feb 14, 2009
Dell 1800FP monitor. Will not power up at all. Checked power cord on another machine, works fine. Monitor is from 2002, but was working perfect till yesterday. Is this worth fixing?
Take it apart and check the fuse. Sometimes is just a simple component damaged.
Have it checked in a specialist electronics house if you prefer.
Sep 17, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell 1800FP
change the power cable then check, if the problem persists take it to the service technician the fault may be in the power supply
Jun 14, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell 1800FP, no signal found (analog). Green LED on, get message
check if your signal cable is properly connected to your system unit and make sure that non of the pins of your signal cable is broken.if any of the pins are broken,try and change the whole signal cable and re-connect it again
after following the above instruction,reboot your computer
thank you for contacting as with your problems,you are always welcomed
Jan 26, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
19" Dell Monitor
some of the AC plug for dell monitor need to force little more than others. make sure the plug on the button is fully seated. (pull it out and reseat it).
the power button is the first one on the lower right hand corner.
Oct 22, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
My dell ultrasharp 1800fp monitor keeps flashing on and off, its not a power problem as the power button stays on and when i disconnect the the monitor cable from my pc the no signal message stays on the...
Inside there is a IC chip on the power pack that goes bad, replacement is called for also look for bad capacitors when you are inside looking around, those need to be replaced as well
hope this clears things up. dells third party who built these units did a rotten job on this model. that chip always fails.
Aug 19, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Ice 2as01 is broken again
Resolder diodes D903 and D906 in the secondary of power supply. The diodes are the two mounted to a heatsink. These are the reason the 2AS01 goes out in the first place. The solder joints on these two diodes breaks loose. If you don't solder them, the 2AS01 will go out again.
Aug 04, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell UltraSharp 1800FP is black on start up but green light is on
i had the same problem i found out it was the inverter i replaced it and it was like new. i do have 2 inverters if you are intrested
Jul 30, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell 1800FP
What's wrong with your monitor?
Feb 10, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell UltraSharp 1800FP - display leak - blue craziness
That one is going to take component level troubleshooting. It could be the power suply, but I might first suspect the video board.
Jan 02, 2007 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor Logo
233 people viewed this question
Alun Cox
