Question about 3Com OfficeConnect Wireless 11g 802.11g/b (3CRWE154G72)
Connected on Wireless but unable to connect on Internet
I recently installed a 3COM PCI card ( 3CRGPC10075) on my (old) Compaq Laptop ( Pentium II, Windows 98SE). I connect to my home network(XP) through a D Link DI 524 wireless/LAN router. The 3 COM Wirless Card Utility running on my Laptop shows that I am connected to my Network, which confirm that the install was correctly done, however I am still unable to connect on the Internet. From my main PC (running XP ) I use a Network Magic Network Configurator/Utility Monitor to manage my Home Netwrok. Here I am able to see the Compaq laptop has been reconginized and connected to my network on the 3COM Wireless Card. Other PC on the network ( LAN + wireless) can acess the internet expect the Compaq What do I need to do to connect on the INternet from the COmpaq? regards rayan
  • 21 Answers
If not done allready, setup the lan IP address and default gateway in win98 Click MyComputer-ControlPanel-Network-Double Click TCP/IP Adapter for your 3com device-insert LAN info for IP Adress-subnet mask, Gateway and your Internet service providors DNS Addresses info Tab's (3x different Tabs "IP Adress" "Gateway" "DNS Configuration") IP Adress will be at least one number higher than your gateway address and not allready being used by other PC's on your network and gateway address will same as your router interface address subnet mask will be the same for all PC's on your network. For 3com and Netgear routers LAN setup is usually Gateway = 192.168.1.1 Subnet Mask = 255.255.255.0 IP Adress = 192.168.1.10(choose alternate number than 10 if allready used by another PC on your network, try to use round numbers, must be a number higher than 1) Once all info is entered click OK (this may trigger a database info update message and task)now your LAN is setup and ready to talk to your network Restart PC and try browsing again. May possibly require reinstallation of the TCP/IP client (you double clicked this to setup your LAN in Win98) or reinstallation of the IIS(Internet Information Services)component found in, Add/Remove Programs-Add/Remove windows components and then try LAN setup again if this does not work first time round
Posted on May 17, 2007
Hi all, I'm trying to install a cable card for internet access in my Compaq Presario 1210 Laptop (Pentium 150 MHz, 64 Mb Ram, etc). So far I have tried several ones but without success. The laptop won't...
When you purchased the network-adapter, did it include a CD-ROM with device-drivers for Windows 98? Did you install those drivers?
Many "new" network-adapters include software that *ONLY* supports newer versions of Windows (XP/Vista/7) and no longer include support for Windows 98/98SE/NT/2000.
Look on eBay for another 3COM adapter, since that adapter worked for you.
Sep 01, 2010 | HP Compaq Presario 1210, 1210CA, 1210EA,...
Unable to make router wireless
To use a wireless network/connection you need to do.
1. Configure the router's wireless with SSID, WPA encryption etc.
2. Next configure the wireless card in the computer/laptop with the router's wireless settings so it can connect to the wireless router.
Please click on this link for my instructions on how to secure your wireless network, configure the wireless router and configure the wireless card in the computer/laptop :-
http://www.fixya.com/support/r3559128-wireless_router_security
Feb 10, 2010 | 3Com Computers & Internet
I can't get my wireless internet to work after a clean install. My Presario m2000 shows the Realtek RTL8139 Family PCI Fast Ethernet NIC on device manager, but i am unable to get it up and running. I...
It looks as though this is equipped with a Broadcom WLAN card. Try going to this link for HP/Compaq put in the required information for product number then click on software/driver downloads. then follow the steps for installing the driver. That should do the trick after a clean install of the operating system.
Dec 24, 2009 | Compaq Presario M2000 Notebook
Dell Inspiron ethernet card plug bad, either send tower to Dell for 3 weeks or replace and bypass with new ethernet card PCI, any problems with doing this?
There should not be any problem with you buying your own PCI ethernet card and install it yourself. They are not that expensive. www.newegg.com has on for only $7.99 and it will work fine in your computer. It does not need to be from Dell.
Nov 19, 2009 | Dell Ethernet Card Network Adapter
How do you get wireless internet on the 366 MHZ
your processor doesnt really have anything to do with the ability to get wireless internet. You can buy a wireless card and install it into your tower. You can buy one at any computer store or even walmart. This is assuming that you have a desktop pc and not a laptop. If you have a laptop you can buy a wireless card for it also. The easiest route would be to buy a usb wireless card, as long as you have a usb port available. Here is a link to a usb adapter:
http://www.newegg.com/Product/Product.aspx?Item=N82E16833130061&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Network+-+Wireless+Adapters-_-Zonet+Technologies++Inc.-_-33130061
Aug 30, 2009 | Compaq (103719-001) Pentium II, 366 MHz...
Can the Compaq Armada E500 go wireless?
hi,
any laptop has the capability to use wireless connection, if you connect to that laptop a compatible wireless card and install its drivers( the cd/dvd that comes with the wireless card)
to check if this card is ok or not try using it on some other laptop see if it works there and gets the networks
further Queries are welcome
Feb 18, 2009 | Compaq Armada E500 Notebook
My wireless laptop is not connecting to the internet.
  1. is there a wireless network
  2. is the wireless network open or locked down and do you have the key
  3. in windows: have you run
    ipconfig /release
    ipconfig /renew
have you looked up the network troubleshooter in the help screens
what have you altered since it did connect
Sep 20, 2008 | Computers & Internet
Compaq Presaro V2000 will not power on after mini-pci card removed
HELLO,PRESS AND HOLD THE POWER ON BUTTON FOR A FEW SECONDS UNTIL YOU GET A POWER LIGHT.ONCE YOU GET THE LIGHT,THE LAPTOP SHOULD BOOT UP NORMALLY.IF THAT DOESNT WORK,REMOVE THE BATTERY AND TRY TO POWER UP WITH JUST THE AC ADAPTER PLUGGED IN.ONCE YOU GET BOOTED,INSTALL THE BROADCOM WIRELESS CARD SOFTWARE FIRST FROM THE CD THAT CAME WITH THE ADAPTER.THE SET-UP WILL THEN ASK YOU TO INSTALL THE CARD AFTER THE DRIVERS HAVE BEEN LOADED.YOU SHOULD BE ABLE TO GET ONLINE ONCE ALL THE STEPS HAVE BEEN COMPLETED.GOOD LUCK
Aug 17, 2008 | HP Compaq Presario V2000 Notebook
3Com OfficeConnect Wireless 11g 802.11g/b (3CRWE154G72) Logo
516 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
Håkan Sterner
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
