Question about RCA L37WD12 37 in. LCD HDTV
Unusable signal no sound or picture tried using input options and rebooting the tv worked fine a couple of hours ago
  • Anonymous Jan 15, 2009
    tv working fine then changed channel and tv has only unusable signals. tried to reset channels using manual and channels will not load
  • mwolrules Mar 29, 2009
    Sudden loss of sound, or sound and picture.....also loss of cable signal.
  • 3 Answers
We had that problem last week.i bought a new remote control and it worked fine.
Posted on Jan 01, 2009
Rca unusable signal
Your TV could be on the wrong input source. if your using red/white/yellow cables look for an inpout button or source or even TV/Video. your tV has many inputs on it and you can only acess them 1 at a time, this allows you to toggle through the input sources and when you get to the right on you'll have picture and sound
Sep 29, 2013 | RCA Televison & Video
TV has no picture, but sound works fine
Are you using the AV input for the XBox or other cable? If you use AV, then use the same input that the Xbox does not show picture, plug in a DVD and see if it works. If it does not have a picture, so 100% your TV has problem.
Aug 11, 2009 | Sony Televison & Video
RCS Scenium
What is your TV input connection? Are you using Antenna? Cable? Dish?
The Unusable Signal sounds like the TV is not getting a signal. Does your TV have a built in HD Tuner?
If you are using Antenna you might want to try setting up the connections and it should search for quality channels that you get good signal strength. If you are on channel 2 and there is no over the air channel 2 it may say "unusable signal".
Sep 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Unusable Signal
Hello Mike:
The issue that you are having is with your small signal board and it needs to be replaced, it sounds like the microprocessor on that board is getting locked up.
Aug 19, 2008 | RCA L42WD22 42 in. LCD Television
Unusable signal
Had the same problem unplug the tv for hour. Had ours at the tv repair shop and it worked fine there brought it home now we have a great picture but no sound.
Jun 01, 2008 | RCA P52930BL 52" Rear Projection...
61" RCA Projection TV, no picture, "unusable signal" message
Read the suggestion of unplugging the TV for at least 4 hours to re-set to factory specs and that took care of it!
Apr 03, 2008 | RCA HD61LPW165 61" Projection HDTV
"UNUSABLE SIGNAL"
l have a 42 in tv rca connected from a direct satellite and i have no picture or sound tryed different connecters only black screen with unsable signal
Jan 07, 2008 | RCA HD65W140 65" Rear Projection...
"weak signal" on my RCA scenium
Hey! I have the same problem as you. But! this would happen only when I got a power outage. Unplug the TV for a couple of minutesand all was fine. For the last 5 day I have no TV. I have tried everything. All the out on the TV and I still get unusable signal. My rep told me to unplug for 24 Hours. Still didn't work. My menu option work as well and every time I put the TV on, off or if I change the input sound will come on for 2 seconde and stop. If I find the salution I will let you know. Gilles Ottawa
Jan 20, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Model 2780R intermittant Picture & Sound Failure
The set has loose power conections to the tuner and judging by the model it might have other loose conections in the chassis,the loose conections need to be resoldered and might not be easy to find,try taping the side of the set to see if it reacts while is doing the problem.Be safe and call a technician unless you are familiar with tv service.
Sep 20, 2006 | Sony KV-27FV16 TV
RCA L37WD12 37 in. LCD HDTV Logo
191 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
