Powerline interference now
I have had cb radios for 8 yrs. 3 months ago, like a switch, a loud screeching and arking started almost steady, non stop, full bars on my radios. Had power co. they hear a noise (RF) with theire antanna, it did it once, so as he lives 2 hrs. away, I bought a noise finder, the arking was from my pole in front of house, they finally replaced it, insulators, transformer, and steady noise still there, can't get noise person back yet, of course this isn't important to them. I have talked 1 time in 3 months, have $3,000. in my stuff. Wwhere do I go from here? I can hear it in my Pick up too, its not just in house, neighbor 2 driveways down hears in his. Weather doesn't make difference, goes all nite, if it quits, may be 10 min. or few seconds. I like my radios. thanks, Linda
    President:
  • 1,990 Answers
Did you ask the Power Co. if they Boosted Power through these lines Recently? Is there a new Housing Addition anywhere close that would warrant a Boost in Power? This would be the Problem I think.
Posted on Jan 01, 2009
Very loud screeching noise in rear when backing up
You may have picked up some gravel in the rear brakes. Does it happen every time you back up? Does the car act strangely when backing up, like it needs to work extra-hard to move? Does it happen when your foot is on the brake? When your foot is off the brake? Is one of your neighbors missing a cat?
Jul 30, 2014 | 2006 Cadillac CTS
CB base Station picking up interfence with inverter
Inverters are full of diodes and diodes are extremly noisy devices. Also the filtering in CB radios is not the best as manufactures try to keep costs down to compete. Try unplugging the antenna from the radio and see if the noise stops. If it does not stop, then buy an inline filter to go in the supply to the radio and place it as close to the radio as possible. If the noise DOES STOP when the antenna is unplugged then it is coming in through the antenna and there is not much you can do but maybe buy a much higher quality radio with better filtering. You might try moving the antenna. Magnet mounts are not as good at blocking noise as high quality permanent mounts. Work to get your SWR as low as possible. Use high grade low loss coax from the antenna into the radio and use high quality connectors like the Amphenol brand. It takes time and effort to solve this type problem and some times nothing works.
Jul 17, 2012 | Cobra 29 LTD CB Radio
My Nissan Murano started to screech upon accelerating from a stop at an intersection. The grinding screech lasted for about 10 seconds, but then loud clunking started and driving was affected with jerks...
i have same issue... good luck to you and me we bought a car with so much unreliability. people have reported spending thousands on unusual repairs on this vehicle. oh god all i want to do now is sell it and get something that can be true to my wallet.
Sep 11, 2009 | 2003 Nissan Murano
Loud screeching noise coming from car after stops.
the screeching noise is most likely caused by a slipping belt or pully. transmission probably needs fluid and filter changed.
Jun 02, 2009 | 1990 Ford Tempo
Bose Wave Radio AWR1 1W
seems to be a common problem with these radios. check my post at what to look at . the mosfet guy.
Oct 03, 2008 | Bose Wave Radio
Background noise
I'm not an expert but I am a daily operator. First check your ground connection, just because the radio turns on doesn't mean the ground is good enough. If this unit is mobile there are several things you can do to reduce the noise. First you need to find out if the noise is coming in thruogh the antena or the power supply; turn on your radio and vehicle, unhook the antena. If the noise goes away or is reduced you know that it is RF noise. this is interference from some outside source, powerlines, TV, just about any thing that uses electricity or electronics can cause noise. relocating the antena may help. Check you antena connections. Check your SWR. This is only a few of the things you can check.
Apr 06, 2008 | Connex 4600 Base CB Radio
Horrible Noise
It may be a cold solder joint on one of the stand up boards. Check all your connections and solder any bad joints.
Ed
NC Electronic
Mills, Wyoming
Jan 02, 2008 | Midland 1001Z 40-Channels Base CB Radio
Static
git a good grond on it or it will go sky hi
Dec 05, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
37 people viewed this question
 Grubhead
Grubhead
