Question about Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range
Oven not staying on
I have a maytag gas oven, when I tap on the safety valve it will come on for a minute then goes out...I have put a new safety valve on it but it does the same thing...can you help..Thank you
    Sergeant:
  • 311 Answers
Hellow their you will need a new oven ignitor.it must pull enough amprage thru the oven safty valve to open.your tapping the valve is adding the warp pice in the valve so will open.you can google your model # and come up with some part suppliers.ive sold 100s of the ignitors for 45$
Posted on Jan 01, 2009
  • 135 Answers
This is usually a bad igniter (glow bar) part # 74007498. The only way to test it is with an ammeter; it should draw a minimum of 3.3 amps. If it is good (10% chance), then the gas valve part # 74009891 is the problem. Hope this helps!
Sears kenmore gas oven - bought a new oven safety valve because the oven ignitor was coming on, but gas valve was not opening. Put new safety valve on, doing same thing, if you tap the valve on top, it...
The reason the igniter would come on yet not let the gas flow is because the IGNITER IS WEAK and not drawing the proper power to open the gas valve. Replace the igniter nad the oven will work without having to tap on the valve
GENE
Oct 16, 2011 | Kenmore Kitchen Ranges
Hi, We have a Maytag gas range. I believe it's a mgr5710adw the number is wore off and unfortunately we didn't write it down in our manual. Anyway, when using our bake burner sometimes it will...
IF the model number you have listed is what you belive to be correct thepart number for that gas safety valve is 74006427 this link i have included isa picture of it. Does it look EXACTLY like the picture if yes it will work http://www.repairclinic.com/PartDetail/Gas-Valve-Assembly/74006427/895773
GENE
Sep 23, 2011 | Maytag 30" Self-Cleaning Freestanding Gas...
My Maytag CWG3600 AAB still will not light after following your suggestion that the safety valve was stuck and bought a new one. So now the ignitor and safety valve are new. I removed the regulator and...
Its old tech2332 again. I know its a dumb question but did you disconnect the gas inlet from the regulator and see if their is gas flow into the safety valve. With a new ignotor with proper amp draw from it into new gas safety valve their is no reason what so ever that oven shouls not be heating. That the only possibility that thier is go gas to valve
Aug 12, 2011 | Maytag 27" Built-In Double Electric Wall...
IGNITER GLOWS BUT NO GAS GETS TO THE BURNER. WHILE IGNITER IS GLOWING, THERE IS NO VOLTAGE ACCROSS SAFETY VALVE TERMINALS. SAFETY VALVE RESISTANCE IS 2.2 OHMS. NEW IGNITER MAKES NO DIFFERENCE. Model:...
Hello John,
Having replaced the ignitor and the gas valve having continuity the problem has be the gas safety valve bimetal is stuck. The only thing you check is amprage draw on ignitor it should be between 3.2-3.6 (as label on gas valve states) with a new ignitor and again continuty on gas valve its the gas valve its stuck and wont open.
Good luck,
Gene
Aug 09, 2011 | Maytag 27" Built-In Double Electric Wall...
Can this gas range be converted to lp gas maytag performa
moz-screenshot.pngmoz-screenshot-1.pngTurn off the gas supply.
Locate the gas valve regulator. Unscrew the top cap on the regulator,turn it over and re-install it.It should be marked NAT. LP.When correctly converted you will be able to read LP.
On the Performa all the conversion parts should just be adjustments. Remove the oven racks,remove the oven base pan,remove the oven flame spreader pan to access the safety valve. Take a 1/2 inch open end wrench and tighten the orifice on top of the gas safety valve. Tighten it until it is snug.Remove the top burners and raise the top to access the surface gas valves.Tighten the valve spuds until snug. Re-assemble all parts.Turn the gas back on and lite the burners. Turn them high and low to make sure they stay lit. If any burner is not right tighten or loosen the orifice spud for that burner only. All air shutter adjustments should be full open,
Dec 02, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Flame comes on gas dryer, but does not stay on throughout cycle. clothes stay damp.
With the limited information you gave I will assume this is a gas dryer that the flame starts for a minute or so and then shuts off. This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas safety valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Oct 01, 2009 | Maytag Dryers
Maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
12001655
Jun 25, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Belling G755 Cooker oven wont stay lit
I'll give this a go! With a cooker like this, you depress and then turn the control knob, press the ignition button and continue to depress the control knob for a few seconds. This is because a device called a thermocouple is heated by the flame and you have to continue to depress the control knob so that sufficient gas flows to heat up the thermocouple. If the thermocouple does not get hot or stay hot then the gas valve is automatically closed - stopping the gas. The thermocouple is a 'flame failure' safety device. If the gas gets cut off then the flame goes out and the thermocouple goes cold switching off the gas valve automatically. However, you are having to try and manually keep the gas going for a good five minutes. I would think that there is either a problem with the thermocouple or the gas control valve! Tony www.birminghamelectricsltd.com
Jun 18, 2009 | Belling Solitaire G755 Gas Kitchen Range
Maytag gas oven slow to ignite,makes poof sound
sounds like the safety valve gas regulator (its where the main gas line attaches in the bottom back)
Mar 25, 2009 | Maytag CWG3100A Gas Single Oven
Oven won't light
Tip - do not change the safety valve first even if the ignitor seem "ok" if you gently tap the safety valve and the flame comes on initially but fails to come on after awhile after each"tapping" - the ignitor is the most likely culprit
Jun 12, 2008 | Frigidaire FGF316 Gas Kitchen Range
Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range Logo
191 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
