Question about RIM BlackBerry Pearl 8100
My phone Wants me to reset it
My blackberry pearl says "APP Error 523" and it says to "reset" but then i will lose everything on my phone. WHAT DO I DO??????!!!?!?!!!?!
    Sergeant:
  • 367 Answers
Try to connect to it using the desktop software. you can download this from either your service provider website or, blackberry.com If you can connect to it back the phone up using the software then reset it to factory and put the backup on phone using the same software ... it will be for pearl 8100. If you cannot connect to phone you can try the service provider to see if they can recover it. But I am guessing the software below will be able to connect to it
Here is another solution step by step:
1. Install the software from the CD (that you received with the device), or download it from the service provider (AT&T).
2. Delete or rename the vendor.xml file, here: C:\Program Files\Common Files\Research In Motion\AppLoader (you're windows file options needs to be set to 'show system files', to see said file...
3. Open Desktop Manager (DM)...
4. Connect the Red Pearl (since am sure that's what you have!)...
5. Doing this will force the pc to see the BlackBerry as new hardware, and thus force it to reload the Operating System (OS)...
6. During the process, select YES to do a backup...
7. The whole process should take about 30-45 minutes...
But, since this has happened so many times, I have to ask myself, is it something you're doing that it causing this? I know the Red Pearls from AT&T have had issues from DAY ONE!
Posted on Jan 02, 2009
App 523 error reset
1) Make sure you have Blackberry Desktop Manager installed.
http://na.blackberry.com/eng/services/desktop/
2) On your PC, go to Start > Run and copy and paste the following line exactly (meaning with the quotation marks):
"c:\program files\common files\research in motion\apploader\loader.exe" /nojvm
3) The Application Loader Wizard will appear -- click "Next."
4) In the "Connection:" drop-down menu, you should see "USB-PIN: UNKNOWN". Click the "Next" button.
5) You should then see a list of applications ready to be installed for your Blackberry. Hit Next and Finish and you are well on your way to getting your Blackberry back to life. Congrats! Just don't disconnect anything and let the lengthy process finish completely.
NOTE: If you do not see a list of applications mentioned in step 5 and instead see the message "The Blackberry Desktop Software does not have Blackberry Device Software for the device that you have connected to the computer. Contact your wireless service provider or system administrator," then you must download Blackberry's Operating System for your carrier and device.
http://www.blackberryfaq.com/index.php/BlackBerry_Operating_System_Downloads
Just select the appropriate carrier and network type, select your Blackberry model from the list and download the latest version. Install this download and follow the above steps again and you should be on the right path.
Additional information:
http://www.blackberry.com/btsc/KB24395 "Error 523", "App Error 523", or "JVM 523" appears on the BlackBerry smartphone
Article ID: http://www.blackberry.com/btsc/KB10144
KB10144 How to force the detection of the BlackBerry smartphone using Application Loader
I got that from: http://supportforums.blackberry.com/t5/BlackBerry-Curve/App-error-523-reset/td-p/1743575
Mar 23, 2014 | RIM Blackberry 8310 8320 8330 Curve 8100...
App Error 523 Blackberry Pearl 8100
you need to wipe the device with JL commander and reload the software using desktop manager
Jul 19, 2010 | RIM BlackBerry Curve 8300 Smartphone
Screen keeps going white and giving me a app error 523
Your Blackberry probably just needs a firmware restore. Here's a guide on how to restore the blackberry firmware, the website is at : Restore Blackberry to factory settings.Download the Blackberry Desktop manager and run the application loader. Make sure you check to delete old applications in advanced tab. Carefully all you datat will be wiped.
Dec 28, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
How do i solve the APP Error 523 on blackberry tour. I have no password set, i have the OS version 4.7 on the blackberry device. The device loads and shows the error APP Error 523 and reset. Upon reset it...
I had this same problem it was from a third party application that I had downloaded. Go to blackberry.com, and select support and search your APP error it will walk you through a guide on getting it fixed--although your phone will reset back to default.
Sep 27, 2009 | RIM BlackBerry? Tour 9630 Smartphone
App error 523
On the BlackBerry smartphone, the following error message appears after pressing the mute button, accessing an application, or performing a hard reset:
523 app. error. Reset.
To resolve this issue, the BlackBerry Device software will have to be reloaded.
Note: The BlackBerry smartphone will not show a Connected state in the BlackBerry Desktop Manager. Please proceed to open and run the Application Loader.
Jun 29, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
Blackberry 8310 app error 523
how can i fix error 523 on a blackberry 8830
Jun 26, 2009 | RIM BlackBerry Curve 8310 Smartphone
App error 523 reset
I got error code 523 after did the device software upgrading. Please advise. tks
Apr 07, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
139 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
