Question about Sony Playstation 3 (PS3) Console
Does the ps3 have a reset button?
When i hooked up my ps3 to my tv it says no signal it was working prior to me turning the ps3 off, now it doesnt have no signal is there a reset button anywhere that i can try
  • 24 Answers
Yes if u just hold you finger over the power button for about 5-7 sec it will reset it.
Posted on Jan 01, 2009
Dynex HDTV says not supported when PS3 is connected via HDMI
Have you tried changing the video output settings on the PS3? It may just be on a setting that the TV does not support. For instance, if the poutput setting is 1080P, and the TV only supports up to 1080i, you would get a "not supported" signal. Hook the ps3 to a tv that it works on...turn it on, go to settings- display settings-output settings- select HDMI as the connector type- if it asks for 3D tv size...select the size- now you need to set the resolution...select all resolutions that the TV supports, since it is a dynex...it is likely a 720p TV. So I would start by selecting only 720p, and then hook the system to the Dynex TV and see if it works now. If it works, you can go back in and attempt to select 1080i or 1080p to see if they work... but again, being a Dynex, it is probably only a 720p TV... The PS3 is likely trying to output a 1080i or 1080p signal...which that TV doesn't support.
Mar 21, 2014 | Video Game Consoles & Games
I own a Sony kdf-55e2000 , when I try to hook up a ps3 through the hdmi imputs i get a message reading "unsupported signal please check device output" i can here the sound but no picture.Is there any
try only having the hdmi cable hooked up to ps3 and tv, turn off ps3 and hold power button for 5 or 10 seconds and you should hear 3 beeps, this should reset the ps3 and detect the settings, if this doesnt work you mmay have to manually change audio and video settings in the ps3 settings menu to hdmi output and auto detect which settings work.
Jan 05, 2013 | Sony Grand WEGA KDF55E2000 55" Projection...
I just hooked up my PS3 to an HD cable. My movie sound works, but now the game sound doesnt... Help?
Hi forever_drea
PLEASE RATE MY ANSWER IF YOU FIND IT HELPFUL !
1- Turn off the power of your PS3 and then turn it back on again.
2- During that, hold down the power button until you see something on the screen.
3- And that's about it. What it does is, completely resets the video settings to 480p I think, the basic configuration, which enables it to work on any TV or monitor.
4- Once you get something on your TV / monitor screen, you can configure your PS3?s video settings to match the TV you are hooking up to.
Go to this link to get more helpful tips on how to set the right video settings;
http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Jan 30, 2011 | Sony Playstation 3 (PS3) Console
My PS3 worked fine for 2 months, then just like that I get "no signal" on the tv screen. Nothing has been changed (cable or tv). I've tried holding the on/off button down till the unit turns back off, but...
Your A/V cables might not work anymore. Do you have any spare A/V cables....like from a ps2? Try the cable on your ps3 to see if you can get a signal then. If you don't get a signal it is a problem either with your ps3 or the TV. Try using a different TV, if it continues to happen than it's your ps3. I highly doubt it's your ps3 and doubt you will get to this step, but if you do what you need to do next is buy an HDMI cable and hook it to your ps3 and tv. If your tv doesnt accept HDMI than i dont know what to tell you. If you do this step and it still doesnt work than sorry it didnt work. Hope this helps, good luck.
Jul 25, 2010 | Sony Playstation 3 (PS3) Console
PS3 doesn't connect to tv
Try holding down the power button for 3-4 seconds when you turn it on.
This should allow you to reset the AV inputs on the ps3
Aug 23, 2009 | Sony Playstation 3 (PS3) Console
No signal
look for the av button on the remote thats the default ps3-any other console channel if that doesnt work look threw all the channels it could be av/or a little 0 with a arrow threw it just look
Aug 16, 2009 | Sony Playstation 3 (PS3) Console
PS3 doesnt work w/ hdmi
Have you tried reseting your option settings for video output? It could be set up for standard definition. There for not sending a 1080 signal through the HDMI, instead sending a different signal for SCART. There is a master way to do this as well. Think holding the off switch and turning of the master power button at the same time does it (do a search).
Jun 26, 2009 | Sylvania LC195SL9 19 in. LCD TV
My ps3 doesnt show any screen on my regular tv anymore !!!
You will need to change the display settings back to normal for a standard TV. Obviously a little tricky if it's already hooked up to the TV that won't display a picture! If you do a manual (or is it called total reset?) this should revert it back to standard TV settings. To perform the reset hold the power button down for 10 seconds (I think it's 10 anyway) or until you here a couple of beeps and it should reset the display settings to it's default.
Hope that helps? Sorry I cant be more exact on the reset details.
Mar 26, 2009 | Sony Playstation 3 (PS3) Console
HDMI for PS3 Doesnt work
do you get picture on tube tv if so hook up to tube tv go to settings and set for hdmi then turn off and take to hd tv hook up with hdmi cable and should work you need to set hdmi in settings as it will be set for s-video at 480p I do believe
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
PS3
You need to reset your video settings when you move to a regular TV. Just hold down the power button, it will beep twice and go back to stand by mode. They boot up again and your video setting should be back to normal ( for standard TV).
Bimmerhp
Dec 07, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
562 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
