Question about Patton (HASF1016UC) Stand (Pedestal) Fan
Looking to replace Patton fan motor, model 1010mp, style TJ74SP
Information on the motor itself is: Patton Electric Company Inc.
New Haven Indiana 46774. Model 1010MP, Style TJ74SP, 120 volts, 60H, 350W, 3.0 amps. Air circulator motor. If you know where I can get one please let me know.
  • Anonymous Mar 27, 2014
    I need to replace a screen for the fan on my range hood. It is a series 17000 120 volt 60 cycle 2 amp. That's all the infor on the hood! Thanks!
    Scholar:
  • 51 Answers
If you are up to disassembling your motor, you will find a thermal cutout near the windings which frequently fails open. Replacements are readily available, or just jumper it out. If the bearings are shot or the windings burned you're out of luck. Trust me, a new motor will cost more than a whole new fan.
Posted on Jan 01, 2009
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
NEED REPLACEMENT MOTOR FOR PATTON 1010MP-HY FAN. WHERE CAN I PURCHASE THE MOTOR?
CTG ' Order 1010MP from PATTON ELECTRIC CO INC Now from CTG !
It looks like you can purchase a motor here.
Make sure you have the correct data from your motor.
There is also a contact button so you can probably call, too.
Good Luck,
Your FixYa Texpert,
Gary
Aug 17, 2011 | Patton U2-1487 Floor / Box Fan
I have a Patton model 1010MP-1 Pedestal fan. The motor model number is 30ACP. The switch has three wires running to it (Red, Grey and Black). The switch itself is a Zing Air and has a L, 1 and 2 on the...
I was looking for this but figured it out myself. The guy wire is hot, the red goes to the low coil and the black goes to the high. So, if you wire the gray and black together, you get high as soon as you plug the fan in.
Aug 10, 2011 | Dryers
NEED VALUE OF CAPACITOR ON MODEL 1010MP FAN. CAN'T FIND ANY INFO ON THE PART.
You can use any capacitor of value about 3.3mF to about 6.8mF with an AC voltage rating of about 230 to 250 volts.
These are the bipolar type capacitors and is generrally available at all electrical or electronic spare parts shops.
Hope this helps.
Aug 29, 2010 | Patton (HASF1016UC) Stand (Pedestal) Fan
Where do i find a replacement motor for my patton model u-2-1887 fan? 120v/60hz/270w/2.6 amps. or where would i get the motor rebuilt?
Before you replace it, try oiling it -- look at the little oil hole on the back of the motor housing. Or try taking it apart and cleaning it, then oiling.
Did it work before, but gradually slowed down and then refused to start? See other threads on this topic for that fan model.
Jul 15, 2010 | Patton U2-1887HO Floor / Box Fan
We have a kenmore electric dryer runs with no heat. repair manual said to check fuses. House panel has circuit breakers none tripped manual says there are two house fuses in the dryer circuit. If one of...
Older fuse panels would have two fuses, one provides power from each 120 volt leg in the panel, therefore providing 240 volts for the heater coil. The motor in the dryer only requires 120 volts, so it may possibly still run if it is on the side with a good fuse. In newer panels that have circuit breakers, you may only have a single handle, but the breaker is a 240 volt breaker (which controls both 120 volt feeds at the same time). You will likely notice that this and all other breakers that are 240 volts are twice the width of a single 120 volt breaker. There is no "second fuse" for you to check, as the circuit breaker takes the place of both fuses in an older style panel.
If you are able to confirm that you have good power at the power connection at the back of the dryer (120 volts between black and white, 120 volts between red and white, 240 volts between red and black wires), then that typically only leaves the heater coil itself or the timer to check. Check continuity on the heater coil first, and visually inspect it for a broken or shorted coil. It is usually the culprit.
If the coil checks ok, carefully check the voltage at the terminals that feed power to the coil. Depending on the model, there may also be a thermal fuse or thermostat that is inline with the power feed to the coil itself. Check this to make sure that it has continuity as well.
I hope this helps you with your repair troubleshooting. Good luck!
Mar 13, 2010 | Kenmore 62602 Electric Dryer
I have a marley elect wall heater the little motor is shot
These motors are now made by Century electric motor Co. -who bought A.O. Smith, who bought UPPCO motor company.
The parts can also be requested Marley EP still manufactures a similar heater
HOW TO ORDER REPAIR PARTS
In order to obtain any needed repair or replacement
parts, warranty service or technical information, please
contact Marley Engineered Products Service Center tollfree
by calling 1-800-642-HEAT.
When ordering repair parts, always give the information
listed as follows:
1. The Model Number
2. The Part Description
3. Date of Manufacture
Dec 11, 2008 | Marley PJ1257 Heater
Patton fan motor
I found something on amazon, take a look here: Emerson Fans Moving Air In Style . I hope I have helped. Cheers
Sep 17, 2007 | Rival U2-1403 Fan
Patton (HASF1016UC) Stand (Pedestal) Fan Logo
6,024 people viewed this question
Top Patton Dryers Experts
Tom Chichester
Are you a Patton Dryer Expert? Answer questions, earn points and help others
