Question about Toshiba Gigabeat MEGF40S MP3 Player
Gigabeat MES 30V hangs when initializing after connection to PC
This unit is approx. 2 years old, and with the exception of battery draining while not in use, it has worked well until now.
When connecting to the PC for synchronization, the Gigabeat hangs during initialization, and it's necessary to cycle the battery switch (initiating a re-boot) to get it operating again.
Operation is otherwise OK, but the PC indicates a "defective device".
There's been no change to the operating system or media software, both of which were previously compatible.
Any helpful advice will be truly appreciated.
  • 3 more comments
  • Adamm1972 Jan 01, 2009
    Exactly the same thing happened to mine this morning :(
    Could it possibly be some problem with the date setting, it's the only thing that comes to mind?
  • Anonymous Jan 01, 2009
    I have the same problem. It started Dec. 31, 2008 at about 10pm est. Looks like microsoft has a problem with their portable software which also hit ZUNE devices on Dec 31st.
  • imagen737 Jan 02, 2009
    My son indicated that after a battery discharge cycle, his Zune is back to downloading normally, with no other required adjustments.
    Unfortunately, after resetting the date on my PC, the Gigabeat still hangs during "initialization", and can only be re-started after a battery disconnect cycle.
    'Glad to hear that some others have had success. Thank you for the suggestion.
    Unfortunately, I'm still without a solution at this time.
  • Anonymous Jan 16, 2009
    mine doesnt give me the option to change my pc connection
I seem to have got it working again. I discharged the battery as much as possible and changed the clock on my PC back one year. Thus far it is working Ok. :)
Posted on Jan 02, 2009
I have an older Kenmore.....Model C110 753702 approx 15 years old. I think the control switch is broken. It will complete all cycles except the last one (drain) Possible solutions?? Thanks in advance......
I don't believe the control assy. is the problem, I would be more apt to think the drain impeller could be broken in the drain pump or there is something stuck in it.
Jan 26, 2010 | Kenmore Dishwashers
Toshiba Camileo h20 battery problem Toshiba Camileo H20 camcorder bought in July O9 Worked fine on 2 week holiday and have recharged the battery 2 or 3 times since. Latterly battery charge didn't last very...
It's eight years old now, and if as you say it has had intermittent use, then the battery will probably have died unless charged at last once a month.
Mar 27, 2017 | Toshiba Video Cameras
Battery Drain when parked.
First off, how old is the battery? It is possible it might be stratified and its just no longer holding a charge well. I've had batteries that are 2 or 3 years old and then they just go dead if I don't start them up every day or so. (Some batteries are just made better than others) If the battery is brand new, then check for some possible wiring shorts. Try looking at the engine running in the dark and try moving around the wiring harness to see if by chance you see any sparks or arcs of electricity. Other than that, you might have to have a qualified auto electric mechanic to check it out for any abnormal power drains.
Jul 30, 2009 | 1995 Dodge Ram 3500
Gigabeat Room Can't Detect Gigabeat on Vista
The key is to have the GB watcher run under XP mode and administrator rights. When you start up the GB Room right click on the program and run as administrator. It runs every time for me. I have the F20.
Mar 30, 2009 | Toshiba Gigabeat MEGF40S MP3 Player
4yr old gigabeat 30gig won"t connect to PC
Try re-installing windows media player 10. It did the trick for me.
Feb 26, 2009 | Toshiba Gigabeat S30 MP3 Player
Battery drains rapidly, clock settings lost, frequent reboots
I would fit a new battery as it is more than 5 years old.
Jun 10, 2017 | Dell Axim X51v Pocket PC
Computer does not recognize Gigabeat Device
the solution is simple. Simply Run both Gigabeat watcher and giga-room programs as administrator if u have windows vista.
How to do this :
Click on start in the taskbar at the bottom right of your screen,
then click on all programs,
then click on the Toshiba Gigaroom Folder,
then right click Gigabeat watcher and click on "Run as Administrator"
then right click "Gigaroom" and click on Run as Administrator
and then look in the bottom right of the taskbar, the little Gigabeat watcher symbol should be there with a green square instead of grey. If its green then it means Vista has recognised your gigabeat and u can now transfer music to it via gigaroom. i hope this helps people as i was on the verge of buying XP myself again... Peace all and HAPPY GIGABEATIN!
DREZO 9/3/2009
Oct 12, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Toshiba Gigabeat MEGF40S MP3 Player Logo
117 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
