Question about Gateway MT3705 Notebook
Green indicator light on charger won't come on
Battery is dead. Is there any other way to power my laptop?
    President:
  • 1,179 Answers
It may be possible with the AC adapter. Some allow it & some do not, but best solution is replace the dead battery with a new fully charged battery. Hope this helps & please remember to rate my answer. Thanks.
Posted on Jan 01, 2009
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
When I put it on the charger it indicates that it is charging but when I take it off it won't turn on at all.
Hello! Does it turn on when you have the charger plugged in? If so, you have a dead battery. The laptop maybe indicate that battery is charging, but if she is dead, it won't give you enough power to turn on. Try that!
If it works with a charger on, you need to replace the battery. Need any more help?
Apr 03, 2013 | Computers & Internet
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
How can you tell if your laptop battery is dead,or that your charger is bad?
Hi, if your mains plug has a fuse, I would check the fuse, if thats ok, put a multimeter on to the end of the of the charger lead and check for around 19v, it will say the exact voltage output on the sticker on your charger.
The green light malfunction indicates a issue with the charger not the battery.
Hope this helps
Best of luck
May 31, 2012 | Dell Computers & Internet
My laptop won't work on battery now!!
look at the bottom of the laptop where you install the battery, there's should be what looks like metal contacts where the battery connects to the actual computer. make sure that when you installed the battery you didn't accidentally bend 2 of them so they were touching eachother. you may have created a direct short which is what caused your heat and the smell. try to plug the battery back in and be careful that you don't bend the metal contacts.
May 18, 2012 | Apevia Acer Aspire 1670/1671 Notebook
Works when connected to charger but no power from battery changed battery still the same
if you disconnect the charger and the battery died then that means that your laptop battery is broken and it won't work untill you get a new one.
Apr 10, 2012 | Panasonic Toughbook CF-27 Notebook
Nothing comes on picture blank
Ok
A few things to try
1.) Check the laptop on an external monitor, do you get a picture
2.) Is there power to the laptop from the battery and the charger? Try to see if the charger indicator lamp is blinking green rather than steady green
3.) Can you hear hard drive / fan noises and are there any lights on the laptop?
If the charger is blinking, indicates that power is not making the circuit, check tightness of charging port, if tight, assume fault on motherboard / blown main fuse
If picture on external monitor and not on laptop, assume backlight on screen dead or possibly the inverter
If no noises from HDD or Fan and No lights on laptop, then fault with motherboard
If you do get fan noises etc, but get BLINKING lights on laptop, assume possible fault with graphics chip, repost with details of blinking lights / colour and specific model of laptop
Jan 12, 2011 | Samsung Computers & Internet
Battery pack or charger
Hi!
When you insert the battery , plug the power into the charger and the light turns ON (red or green) - the charger is OK. One indication that the battery is dead is when you charge it, after just a few minutes the full charge indicator will turn ON ( with Canon chargers the light for full charge is green). If that's the case, purchasing a new battery is the only option.
Have a nice day!
Oct 02, 2008 | Canon PowerShot SD600 Digital Camera
Gateway MT3705 Notebook Logo
104 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
