Question about Sirius Satellite Radio Receiver
Cannot set fm frequency on radio
I have found an FM frequency on my car radio that is not being used.
I cannot get it to show up on my stratus 5 satellite radio.
I have tried everything and read the online things 10 times.
How do I set the satellite radio to a new frequency. It only shows the preset one that does not work in my area. The other 4 show as Empty.
The online suggestions for my area for frequencies to use are being used by radio stations.
Thanks
Bonnie
I have a Stratus 5
  • 6 more comments
  • bonnie_june_ Jan 01, 2009
    There is only one frequency showing on the Receiver and that is one that is being used by a radio station.
    How do you "enter" a frequency?? That seems to be my problem
    There is no dial on the Receiver.
    I can scroll down to 5 entries.
    All but one show as "Empty'
    No nothing will input, should it?
    Ok, but how???
    I have done plenty of research online and still cannot figure it out.
    I have a sirius stratus5
    When I go to the Frequency selector it shows only one station:
    81.5 and that is being used by a radio station here. The others say
    "empty" and I cannot see a way to put the FM station frequency in
    there.
    I would appreciate your help if you can find anything else.
    Thanks
    Cannot find the Frequency tuning step by step!
    nope
    so I think I have to go to a more open space and set my radio again and hope it picks the station up
    I am thinking that the satellite radio will pick them up automatically
    and then I will have them on that list to pick from
    Has to be the problem
    I live in mountains so I may not be able to use this sat radio
    thanks for the help
    President:
  • 1,990 Answers
Go through the Settings Menu on the Reciever until you see Frequency Select It and then turn the dial until it matches the same frequency that you are using on the Radio.
Posted on Jan 01, 2009
  • 5 more comments
  • Travis Humphries
    Travis Humphries Jan 01, 2009
    You should be able to Enter a Frequency or Dial in another. If not you may have gotten a Bad reciever. I went through 4 before I got a Good one for my Truck.
  • Travis Humphries
    Can you get anything to show on the Blank ones if you try the Buttons?
  • Travis Humphries
    Yes, You should be able to tune into any Frequency That you Want to.
  • Travis Humphries
    Hard to tell you without a Picture or Description of the Reciever. Give me a little bit and let me do a little more Research Ok.
  • Travis Humphries
    Ok, I can;t get it on here due to the Size But, Go to www.Sirius.com and Scroll down to Help and Look for your Reciever. They have step by step Directions and Pictures to help you with the Frequency Tuning!
  • Travis Humphries
    4. Press and hold the FM Presets/MENU button (see Figure 25, left). The MENU
    OPTIONS screen will appear. Press the Channel UP/DOWN buttons to highlight FM
    TRANSMITTER and press the Select button to select it.
    5. The FM TRANSMITTER screen will appear (see Figure 25, right). Press the Channel
    UP/DOWN buttons to highlight FM PRESETS and press the Select button to select it.
    6. The FM PRESETS screen will appear (see Figure 26, left). FM1 will be highlighted. (FM1
    is factory-set to 88.1MHz. This may not be the best frequency for your area.)
    7. Press the Select button to select FM1. The FM FREQUENCY screen will appear (see
    Figure 26, right).
    8. Use the Channel UP/DOWN buttons to highlight the FM frequency that matches the
    channel that you preset on your vehicle radio in Step 2 on page 43, then press the
    Select button to select it. (See Figure 27.)
    Figure 27
    menu
    I 2 3 4 5 6 7 8 9 0
    FM Presets/
    MENU Button
    Select
    Button
    Channel
    UP/DOWN
    Buttons
    Figure 25
    Figure 26
  • Travis Humphries
    Did that get it Done?
The static level is so high I am unable to hear the radio.
Under menu, select FM frequency. Try using different frequency. A nearby FM station could be bleeding its signal onto the FM frequency your unit is using by default.
Jan 09, 2011 | Delphi Roady XT XM Radio Receiver
What fm station do i use in the car
You need to find a clear radio frequency in your area then in the SIRIUS sat radio you will find a FM transmitter frequency adjustment menu. set it to the same as your fm radio and your all set.
Feb 19, 2010 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
Trying to figure out what FM frequencies are avail for my portable XM in my car? 50595 is my zipcode.
KQWC 95.7 is the only FM station that is out of webster city which is the 50595 zip code.
Jan 27, 2010 | Delphi Roady XT XM Radio Receiver
No sound when put on 88.3 fm
I didn't think this unit had an included FM transmitter - so I looked around for more info, and everything I've found indicates it does not.
It will however play audio via the built-in speaker or headphone jack. Use of a third party FM transmitter will allow playing audio (navigation, alerts, MP3 or audio books) when connected to the headphone jack and with both the FM transmitter and FM radio set to the same frequency.
The FM transmitter will work best when set to a frequency that is unused and has the least amount of interference from adjacent stations. Check by tuning the car radio across the FM band and note frequencies that have those qualities. Leave the radio on one of the clear frequencies and set the FM transmitter to the same displayed on the radio. You should try several to find the one that works best. Also, be aware that as you travel, you may enter an area where that frequency (or one close by) is in use by a broadcaster. This will require repeating the process as needed to reduce interference.
Oct 16, 2009 | Garmin Nuvi 350 Car GPS Receiver
Got a new mp3 fm modulator, no frequency is detected
u should set the fm frequency on your modulator as same as ur car radio. example, if ur radio states 100.00, set ur modulator 100.00 also.
Oct 10, 2009 | Virtual Reality Sound Labs VRFM7 MP3 FM...
How to set FM Frequency on XM Radio Delpi SkyFi
is this a skyfi 1 2 or 3. if its a two or three if you go to the menu button and scroll down to fm frequencys and select that from the drop down menu. then scroll through the built in frequencies and determine which one comes in the clearest. if its a skyfi one then your gonna have to put in a wired fm modulator because the first one doesnt come with a wireless fm transmitter.
Jan 22, 2009 | Car Audio & Video
Nokia 5220 expressmusic FM radio always says off
I have the same problem and don't see a way to set the frequency of the stations if you can't set the radio to on...............
Nov 07, 2008 | Nokia 5220 XpressMusic Cellular Phone
Sirius S-50 Portable
Go to device settings - FM Frequencies - select the FM 1 or FM 2 or FM 3, turn the dial to move the FM frequency to that which you want. Press the Sirius Dog to enter this frequency. That's it.
Oct 20, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
Have SkyiFi 2 and use with cassette adapter - but, want to use in other dar
From the XM user's manual, page 14.
1. Make sure your SKYFi2 is turned off. Unplug any accessory from SKYFi2’s audio jack.
2. Turn on an FM radio and place it close to your SKYFi2.
3. Tune the FM radio to each of the following FM frequencies: 88.1, 88.3, 88.5, 88.7, 88.9, 106.7, 106.9, 107.1, 107.3, 107.5, 107.7, and 107.9.
4. Note the frequency that has no FM station or the least amount of interference.
5. Turn on your SKYFi2.
6. Press the “menu” button.
7. Use the scroll wheel to select “FM Frequency.” Press the “XM” button to confirm.
8. Use the scroll wheel to select the frequency noted in step 4. Press the “XM” button to confirm.
9. Press the “menu” button to return to the main menu and then again to return to the play screen.
10. You should now hear XM programming over your FM radio. If the sound is not clear or you hear
interference or static, try another frequency by repeating the process above.
Jun 11, 2008 | Delphi XM SKYFi2 1016211B1 Satellite Radio...
Sirius Satellite Radio Receiver Logo
251 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
